Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
I was being helped by daniel s earlier this afternoon with a printer problem. i tried what was suggested and the first test print came out well. the next one didnt print any black at all, and the ones after that now print nothing at all.
    Brigadier General:
  • 10,406 Answers
Some (not all) of the ink-jets that spray the ink onto the paper have been clogged. Thus, what should *NOT* be WHITE on the paper remains as WHITE, creating the "stripes".
Start the Kodak Printer "utility" software, and run a "print-head-cleaning-cycle", to unclog those jets.
If a few of those cycles fail to improve things, take the printer to a qualified technician, for a more-thorough cleaning.
Posted on Oct 10, 2010
I have a Mimaki JV33-160. I printed earlier today and noticed all of my images had lines in them. I cleaned it and printed again but had the same result. Any suggestions would be great!
could be a faulty cartridge or the printer head is not clean .. try cleaning that and reinstall the cartdge ..
if that does not help .. then call 1-877-805-1027 for expert help
Jul 23, 2015 | Office Equipment & Supplies
My printer is just copying part of the page. Leaves out paragraphs of document. I would appreciate any help.
Check your printer settings. Try a test print. Call HP Tech Support or YouTube. Also check the scanning surface. Is it printing all the way across, then missing the vertical or vice-verse?
Mar 18, 2015 | HP DeskJet F380 All-In-One Printer
HP Deskjet 970 Cxi. Printer cartridge light flashing.
Try removing the printer icon in Printers and Faxes and reinstall.
Hope this helps.
Aug 17, 2009 | HP DeskJet 970cxi InkJet Printer
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
I can't print! It copies, but won't print
First check printer as an standalone is printing self test page.
If yes.
Then Reinstall the printer software after uninstalling the earlier one completely.
Else.
Printer is bad.
Sep 18, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Verifone Trans 330 says "Printing" after the transaction but printer does not print.
First off, verify that the printer is powered on. This may be a basic thing, but many, many people don't realize that the printer either was turned off accidentally, or the power plug came loose.
Check that the cable connecting the terminal to the printer is securely connected at both ends. If this doesn't resolve the issue, pull the and check the ends of the plug on the cord at each end to make sure that the pins inside are not bent.
If you are running a Verifone printer, you can run a print test to make sure the printer is working by turning the printer's power off, and then while pressing and holding the paper feed button (green button on top) turning the power back on. The printer will start printing test characters (you can release the button when it starts printing). To stop the test, just power the printer off again and then back on.
If the above suggestions don't fix the problem and it was working fine at an earlier date - you most likely have a bad printer. You can also contact your processor's Help Desk and have them check to make sure the settings on the terminal and/or printer didn't changed somehow.
Hope that helped!
Sep 12, 2008 | Citizen IDP562-RSL2-120 Matrix Printer
HP OJ 7410 Allin1 not printing
try removing the printer, and re adding it. Sometimes when printer drivers go kaput, they don't drop cleanly. Also, check your power arrangement, as printer drivers are notoriously suspect to power glitches, just like modems.
Got backup?
Feb 07, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Stoopid Printer #*@!
Slow printing can be a result of excessive TMP files and a fragmented HDD. I would do a search for *.tmp;*.chk files, del all you find, goto IE, Tools, Internet Options, del cookies, files, and history, set history to 1 day, under settings, locateed next to Files, set diskspace to 10 MB, exit out, reboot, disable any screen saver you have, then do a full defragmentation of the hard drive. THis will take some time, best to set it to run overnight.
Once finished, do a fresh reboot, then try to print again.
Daniel (rydf)
Jan 18, 2008 | HP Deskjet 5440 InkJet Photo Printer
Everything I print is underlined
to determine if it is the printer, try these :
>windows test page (printers & faxes, printer's properties page)
>self-test ;
Please perform the following steps to ensure your printer is physically functioning.
1) Disconnect the printer cable that is connecting printer to the computer, by unclipping or unplugging it from the back of the printer.
2) Turn the printer ON by holding down the POWER button for about 3 seconds.
3) Load A4 or LETTER size paper in the sheet feeder on the back of the printer.
4) Press the MENU button on the control panel until NOZZLE CHECK appears. Press the COPY button.
5) The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
Dec 08, 2007 | Epson 1000 ICS All-In-One InkJet Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
55 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
