Question about Dell Latitude D610 Notebook PC
My Dell Latitude XP laptop got knocked to the floor. It fell on the side where usb port was connected to printer. Usb port pins are now bent and port is unusable. Dell said I have to replace motherboard! Is this the only way?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 99 Answers
It depends. If i am understanding you correctly the problem is that the usb port has broken loose from its connection to the mother board.
can you boot the machine (ie everything else works but the usb)?
Check for a docking connector (usually on the bottom, or dead center on the back). Check dells site for what docking stations are compatable and connect the laptop to the dock then use the usb ports on the dock (skips around the onboard port)
if your feeling a bit more ambitious you could try plan b
This should be solved by 1) disassembling the laptop (so you can access both sides of the mother board) 2) inspect the damaged connection (are the pins broken off or just loose from the solder pads). 3) if the pins are intact, then you should be able to gently bend them back and re-solder them into place, if the pins are beyond help then you would need to remove the old one (use a braid or a ****** to get the old solder out) then plug in the new one and solder it up.
I will point out that you need to be relativly proficient with your soldering tools before bringing them anywhere near the mother board of your pc.
Posted on Oct 10, 2010
  • mideka84 Oct 11, 2010
    The computer luckily works fine. It's just this one usb port. Pins look bent. If I try connecting the bent usb cable to this connection the computer shutdowns. So I don't know if problem is just bent pins.
    Thanks for your help.
    Brigadier General:
  • 10,406 Answers
No, it's not the only way, if you have an unused PCMCIA port in your notebook. The width of the PCMCIA port is about the height of a credit-card, and the height of that port is about the thickness of a few credit-cards.
Purchase a PCMCIA adapter that has two or three USB ports.
Insert the PCMCIA adapter into the slot,
and connect your USB device to one of the USB ports.
Dell Latitude C840 issue. Have 4 input USB 2.0 PCI card adapter that is connected to side USB 2.0 serial port, but external HD and devices are still running at 1.1 speed (as if I plugged into the back USB...
Hi, I haven't got a Dell but try this site for the USB driver that is missing. With XP there is no support for USB2, an updated driver is required. Did you download the drivers from Dell? If not, that could be why as they may be old drivers.
Oct 29, 2013 | Dell Latitude C840 Notebook
Latitude E4310, start up problem. power button blinks but screen does not come up.it blinks and disappears.
First I'd try this... Remove the Battery and AC adapter, press and hold the power button for 15 seconds. Connect the AC adapter alone and try and power on. I also recommend that you check for bent pins or broken plastics on the right USB ports on your laptop.
Oct 10, 2013 | Dell LATITUDE Computers & Internet
My broken usb socket
Purchase a PCMCIA USB Adapter. Will fit in the little card slot and add 2 or 4 more USB Ports.
Oct 20, 2009 | Dell Latitude D600 Notebook
I am just wondering what printer is compatible with the Dell d810 laptop
You can use every printer that connects via USB and has drivers for your operating system. If your operating system is windows xp then it's virtually every modern printer.
If you want to use an older printer then you would have to buy a Dell docking station with LPT port. Also, there are LPT->USB printer adaptors but they work far from flawless (I encountered many problems while using them).
Oct 17, 2009 | Dell Latitude D810 Notebook
I have a Dell A940 connected to my old Dell desktop, which I want to keep. How can I get it to print from my new laptop? I cannot find any USB ports on the printer to connect.
Specs state that it is USB - probably a "USB-B" connector. Anyway, how is it connected to your desktop? Surely you can take the USB lead from the printer out of the back of your desktop and plug it in your laptop? Am I missing something here? Specs don't say it is a "parallel" connector (unless it has both). If it has both (and you are using the parallel connection (big plug with many pins) on your desktop then there should be a USB-B socket on printer next to the big parallel socket.
Sep 10, 2009 | Dell A940 All-In-One InkJet Printer
When i plug in device in to a usb port my computer freezes up
have you tried a different USB port because theres two types of usb port & one on the back has pin's inside it check that these arnt bent or touching you should use the side ports for your basic everyday external devices.
Aug 12, 2009 | Computers & Internet
XP crashed on my Dell latitude D600 laptop. I
go to mfg websight and down load all th proper drivers there is likely a mother board driver not installed that allows it to see the ports
install all of the manufacturer's drivers
dont expect that microsoft wrote windows just for your computer it is a general set of generic drivers that make most things work but not every thing
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&l=en&s=gen&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
Aug 03, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
Powersurge on USB ports
Have a close look at the USB ports, make sure you don't have any bent contacts touching the outer part of the connector and shorting.
May 04, 2009 | Dell Latitude D410 Notebook
Large data transfer laptops, cable, or USB adapters DELL Lat-C
the system must surely have a ethernet port... why dont u try a peer to peer connection.... they can achieve very good speeds...
Nov 23, 2008 | HP Pavilion dv9000z Notebook
3680 2682 Laptop fell off bed to floor w/ USB drive plug in back
hi, if the port is working fine, its ok.. but do not use this port, since its damaged, it could short the pins inside while pluging the cable, left side is better
Jan 03, 2008 | Acer Aspire 3680 Laptop
Dell Latitude D610 Notebook PC Logo
151 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
