Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
PROheat 2X won't dispense water
My PROheat 2X is brand new and it won't dispense water consistently. When I turn it off, let it sit for a few minutes and then turn it back on, it will dispense water for 1 or 2 minutes before the water starts to drible out. This is the second Bissell product we've had with a similar issue and I'm frustrated.
  • Anonymous Jun 07, 2008
    I have had the same problem with the ProHeat 2x and i have tried everything. Nothing is working.
  • fbschierbaum
    fbschierbaum Apr 12, 2012
    I now this is a older thread, but I had the same problem. I took the main fill tank off and took the two white or red spray noozles off the hoses, by removing the hose clamps and they were both clogged from the cleaning solution(i had only used it twice) and soaked them in hot water for 5 minutes. Works great again!
    President:
  • 1,673 Answers
Make sure that the gasket is on the valve at the bottom of the tank. It has to be on the tank. That valve may be bad, or maybe the tank isn't sitting square on the base. But if less then 1 year old, then it is under warranty, take it in for warranty repair. You taking it apart voids the warranty.
Posted on Jun 01, 2008
How can I operate the Bissell PROheat 2X carpet/upholstery cleaner without instructions?
Your solenoid that activates the hand unit is most likely burned up. Bissell 2X machines generally last 4 to 6 uses and a solenoid burns up. This is the only machine that we do not offer repair service for in my store. It is a terribly poor quality design.
BTW, the brushes aren't supposed to turn when the machine is in the upright position.
Sep 18, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Won't dispense water
hi if u get a tooth brush and clean at back of roller it should work ,the little ho;es get blocked
Apr 09, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hey Parker. I know how frustrating no spray can be when you're ready to clean your carpets.
Here's a complete list of troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hey, sorry to hear you're having problems with the spray.
Here's a quick link to troubleshooting steps to assist you.
Jan 30, 2013 | Bissell Proheat 2X Select Pet Upright Deep...
Bissell 9500 ProHeat 2X Clean Shot will not let water put from tank?
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 19, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 Proheat 2X won't dispense fluid.
heatman101
fgjhdjk
Jun 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel proheat no water will dispense
Check all your hoses and make sure that they are not blocked and everything can run freely through your sstem
Apr 25, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Black water leaks from bottom of ProHeat 2x
Probably be a rubber seal leak or crack at the soap water dispenser pump.
If you can take it apart and it is the seal you should be able to reseal it with gasket seal from an auto parts store.
Jan 17, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
287 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
