Question about Garden
I have a RN45B roof nail gun that wont sink the nails all the way. How do I adjust depth of nails?
  • 30 Answers
The adjustment is inside the magazine there are 3 setting depending on the length of nail. Here is a PDF of the owners manual for that tool, the procedure to set the depth is on page 6. http://www.bostitch.com/catalog_images/web_pdf/103280.pdf
If after setting the depth you are still having issues you can adjust the pressure on your compressor. The operating pressure for that unit is 70 - 100 psi. Do not exceed 100 psi and remember to disconnect your hose before loading/unloading or making adjustments to your nailer.
Posted on Oct 11, 2010
Whats the difference between a roofing nail gun and an ordinary nail gun ?
A roofing nail is designed to be easier to be removed, they have a smooth shank and wide head that hold down shingles. A siding nail has a ring shank. A roofing nailer is used to quickly pin down shingles across a roof, the depth at which they are drive in is generally shallower than a siding nail.
You can read a little more about roofing nailers here Best Roofing Nailer Shooting From the Hip Woodworking Tool Guide.
Aug 02, 2017 | Air Tools & Compressors
Bostitch rn45b wount drive the nails in all the way in and I don't see any adjustment like on my rn46
The bostitch nailer rn45 has an adjuster for depth on the front. Rotate the black knob for proper depth. If adjuster does not have an effect, most likely the driver oring is worn. Ez check for worn driver oring. Open side door and remove nails. Point nose of gun up then down again. If the driver moves up and down, replace the oring. The driver should stay in the upper position at all times. Good luck.
Oct 15, 2014 | Air Tools & Compressors
Bostich RN-46 seems to be over sinking the nails even went set to low depth
Adjust the air pressure on the regulator to about 90 lbs. or lower. maybe higher than 90 but that should help you set the depth.
Jun 05, 2014 | Stanley Factory Reconditioned Bostitch...
Paslode im250
There should be a depth adjustment on the gun. This allows you to control how deep the nails sink. The adjustment is usually on front face of gun and just above the tip. You might want to contact paslode to see if they can give you any ideas .
Feb 27, 2014 | Tools & Hardware - Others
Miss fires and wont sink nails depth set deep and pressure over 120 psi
If no air is leaking from gun, miss-fire is usually caused by worn or too tight piston oring or lack of lubrication. Easy test. Disconnect airline, remove nails, point nose of gun up then down. Driver should stay in uppermost position. If driver moves up then down within gun replace piston oring and retest. Set pressure to about 100psi. Good luck with repair.
Oct 14, 2012 | Porter Cable Coil Roofing Nailer
How do i control the depth the nail shoots in a bostitch coil nailer
The bostitch nailer pictured along along with your question is a RN46 roofing coil nailer. It has a dial on the front of the nose for adjusting depth. Some older nailers (roofing nailers) do no have a means of adjusting so were set at the factory for best performance. The question of depth usually comes up when lower bumper fails and the nail is driven too deep. Easy test. Remove nails and find a very soft piece of wood. Dry fire the gun against soft wood and measure how deep the driver is entering the wood. Harder test. Remove the head and use any handy tool to push driver down to bottom. Measure how far the driver extends past nose (should be about 1/8 to 3/16). If more, replace the lower bumper. Good luck
Jun 21, 2012 | Stanley Bostitch Nail Gun
Paslode 900600 Trim nailer not sinking nails
The firing pin can be completed or part of it crooked worn and can have a little burr on its way and stuck in the cylinder somewhere o-rings worn and hardened, have a tilting piston on the firing pin somewhere in the cilinder
Jul 27, 2017 | Air Tools & Compressors
Can i use any brand coil nailes in my nv 45ab2 coil nailer
Yes. Roofing nailers all use about the same size and spacing on coil nails. You will find that Harbor Freight is about 1/2 the price of Home Depot or Lowes for those nails.
-Jim
Oct 17, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Nail gun not putting nail in all the way
yes ,should be on head of gun,if not try turning air preasure up.
Aug 21, 2009 | Stanley Factory Reconditioned Bostitch...
Garden Logo
186 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
