Question about Seagate 3YR WARRANTY BARRACUDA 50GB 7200RPM FIBRE CHANNEL HARD DRIVE 1.6 HEIGHT - ORIGINAL LABEL AND... (ST150176FC3YR)
I've jsut booted up my pc and the HDD was 'over spinning' , so I re-booted and the HDD is now operating in what i would consider to be normal peramitters( spell check please), I have had this problem with other HDD's and it has resulted in failure ultimately, as this HDD has been in my system for only 2 days i'm a little concerned that this might become a regular and unfixable problem
  • Seagate Master
  • 27,725 Answers
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
Posted on Oct 10, 2010
  • 1,606 Answers
The speed of a hard drive is controlled by the on board hard drive controller (on each drive) and the voltage it sees. Since it is unlikely that you've seen 3 bad controllers then the problem has to be the power supply. You need to check that the voltages are not high. There isn't much you can do other than replace your power supply. If this is the problem then you may be seeing problems in other devices connected to the power supply. It may have also stressed other parts that will fail sooner than expected.
Having said that how are you measuring the overspeed condition? The 7200 drives make a lot more noise and the seagates are a bit noisier than others. So you have to be sure that the drive is actually over speeding and not just making more noise than you are used to. Having had problems before it is pretty normal to get a little paranoid about it happening again. I haven't seen this lately but the few times I have it was actually caused by the outlet power fluctuating and had nothing to do with the computer itself. So you may want to check the volts on the outlets for a while. It might only fluctuate a few times during the day so you need to use a meter that records highs and lows. If this is the cause then you need to use a battery UPS. These charge the battery which then powers the pc. It isolates those from any fluctuations in the power. And if the power goes out then you have a few minutes to save everything and shut down.
PC won't boot
Have you tried reformatting on the broken machine?
Oct 22, 2007 | Dell Dimension 8100 PC Desktop
WHY DOES MY DELL INSPIRON 2650 SAY OPERATING SYSTEM NOT FOUND?
This usually is cause when the computer cannot find the boot program on you HDD. But there are other causes also. Before going to the boot program let's check other things first. Your primary boot sequence in the CMOS setup is not set to you primary HDD and the computer looks for the boot system in the CD/DVD/Blueray disk drive or USB and couldn't find any boot program. But normally it would skip those and go to your primary HDD. But if you have those CD/DVD or a USB stick, external HDD plugged in then remove them and try rebooting again. If that doesn't work, than you have a defective HDD. Check your HDD, try recovering with windows recovery disk. Worst thing, Reinstall windows again, install new HDD and reinstall windows.
Sorry for the later suggestions.
Good luck
May 27, 2014 | Dell Computers & Internet
CHKDSK /r fails to complete to resolve Hard Drive Error 2000-0142 / 2000-0146
This is a regular problem on Win XP computers. They are old so the hard drive is also old. You may need to do a reinstall of your operating system. But you could try running RKill first it is a rootkit killer. This may find the problem in your software, but don't hold your breath, With chkdsk failing it is a reliable indicator of a physical failure on the hard disk. You need to consider that a hard disk is metal plates spinning very fast and while they are designed to take some knocks, over time a laptop takes more knocks than you would expect. The plain truth is, stuff breaks and need s replacing.
May 01, 2013 | Dell Latitude E6500 Laptop
Unmountable boot volume
get a copy of hirens and run HDD regenerator I think you have some bad sectors and a corrupted windows.
Feb 03, 2013 | Dell Latitude D410 Notebook
File operation freezes pc and dvd spins
well not anytime i copy or move a file, but i've had that happen when i click send to or something along those lines.
Jul 18, 2012 | Computers & Internet
Hi I've Vaio VPCSC1AFM with Win 7, boot is impossible -"Operating System Not Found", HDD is also not visible in BIOS. I can hear that HDD is working.
* Look in your BIOS, I've it can detect the HDD.
( Press the F1 or F10 key after restarting the computer) * Make sure all the cables are connectedproperly.
* It might be a jumper setting.
I've you have 2 HDD's on 1 cable, you need to have 1 Master & 1 Slave,or else your HDD(s) wont show up & other problems.
Jumper settings below (Yourjumper settings might be different !)
I've this all didnt work, either your HDD or your MOBO is broken.
Jun 03, 2011 | Computers & Internet
Whenever I am trying to boot my desktop....it is going to hibernation...I have checked the monitor, which is working good
press F11 on start and see if it wants to boot in safe mode.. ..if you manage to boot it ..it means that it is just a setting from the video card made wrong ..and I suggest to reinstall the video card ..
If it do not boot atall ..and just beeps a sec and shuts down ..open it and see if the CPU cooler is spinning ...and also check the Ram memory ...If you have more than one units for ram ...remove them one by one ..and try to boot the computer with one at he time and see if any of them is damaged..
In case the ram memory is damaged..the computer will actually not boot at all ..and will not show the device check on start ...but just spins the hdd and clicks in a loop ..
If the computer shows the devices..but goes off when windows is trying to start it needs eiter the video driver to be reinstalled to correct any odd settings ..or the operation system is unable to start and this is cause by the hdd not being detected or a malfunction of the operation system ...In this case..check the HDD to work well ..or reinstall the OS..
Dec 24, 2010 | HP Compaq Presario SR1265CL-B...
Sir my laptop is does not start. error ir operating system not found.
If the laptop does not find the operating system on boot up it's ether the HDD has failed or the Operating system is corrupt the only answer is to reinstall the operating system or change the HDD.
You could try getting into the Bios on boot up normally by pressing F12 after pressing the power on button and checking if the laptop is seeing the HDD.
I say F12 but without knowing the laptop model it's a guess.
It should tell you on the boot up screen which function key to press to enter the Bios.
Once in the Bios check to see if the HDD is listed if it is the laptop is seeing it so it should be a simple matter of reinstalling the OS if its not then the HDD is faulty you will need to replace it and reload the OS.
Sep 12, 2010 | Computers & Internet
Operating system is .............
power on the computer, immediatly tap f8 until you get to the boot menu. Choose "last known good configuration". If this fails, your master boot record is corrupt.Boot into safemode, copy all of your data to an external hard drive, then reload your operating system from the secondary partition on your hard drive or insert your OS restore disk and follow the directions.
Mar 20, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
62 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
