Question about Mavic Speed City Road Bike Wheelset
Free hub is very sloppy and I cannot get the hub off, Is a special tool needed?
  • 186 Answers
Yes
Posted on Oct 11, 2010
Harley 5 finger clutch hub will not come off its like someone welded it on the tapper shaft any tricks ,,,can i heat hub
Hi, Paul there is a special tool for pulling clutch hubs for this scenario you will need a service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Cycles Clutch Hub Puller 6100040
Free Harley Davidson Motorcycle Service Manuals for download
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Jul 07, 2016 | Motorcycles
Tools needed to change the left front pressed wheel bearing on 2008 jeep patriot
so working FSM free,,so you ask us to read our for you.?
sure. (last page (fsm) on front bearing page covers tools.)
"special tools not normal mech tools? {"
so are you 100% tool free shop , we cant guess your shop, not ever.
Book on MK 08 (jacks, wrenches, sp. jeep tools, torque wrench)
quote, partial, just removal. parts
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Raise and safely support the vehicle. (jacks and stands)
  3. Remove the front wheel. (lug wrench)
  4. Remove the steering knuckle assembly from the vehicle. Refer to Steering Knuckle, removal & installation.
  5. Position the locator block for Special Tool 9712 Fixture, as follows:
    • For left side knuckles, place the locator block to the left side on the Fixture. The side of the locator block with the angle cut goes downward, toward the Fixture. Install the mounting screws and tighten them to approximately 40 ft. lbs. (54 Nm).
    • For right side knuckles, place the locator block to the right side on the Fixture. The side of the locator block with the angle cut goes downward, toward the Fixture. Install the mounting screws and tighten them to approximately 40 ft. lbs. (54 Nm).
    • Install the knuckle in the Fixture as shown, guiding the steering arm to rest on the locator block and the brake caliper mounting bosses on the two Fixture pins.
    • Place the Fixture with knuckle installed into an arbor press.
    • Position Special Tool 9712-2 Remover/Installer in the small end of the hub. Lower the arbor press ram and remove the hub from the wheel bearing and knuckle. The bearing race will normally come out of the wheel bearing with the hub as it is pressed out of the bearing.
    • Remove the knuckle from the Fixture and turn it over.
    • Remove the snap ring from the knuckle using an appropriate pair of snap ring pliers.
    • Place the knuckle back in the Fixture in the arbor press ram.
    • Place Special Tool MD-998334 Installer on the outer race of the wheel bearing. Lower the arbor press ram and remove the wheel bearing from the knuckle.
    • end , i stop here,
log in to alldata.com and read.
or buy the FSM
https://www.techauthority.com/en-US/Pages/Home.aspx
if lucky use youtube to find persons doing this , tool free.
Jerryrigging happens
Mar 10, 2015 | 2008 Jeep Patriot
Free wheel hub
replace the hub with a new one. It requires a special tool that can be obtained by purchasing one online and is cheaper than having a bike shop replace it.
Aug 02, 2013 | Mongoose Cycling
Need to replace 2003 corola front wheel bearings. need step by step instruction please
Removal & Installation To Remove:
  1. Remove the front wheel.
  2. Remove the front axle hub nut.
  3. Disconnect the front stabilizer link from the strut.
  4. Disconnect the speed sensor (with ABS).
  5. Remove the front brake caliper and rotor.
  6. Disconnect the tie rod end.
  7. Remove mounting bolts and nut and separate the lower control arm from the ball joint.
  8. Using a plastic hammer separate the front axle shaft from the hub.
  9. Remove the 2 mounting bolts from the strut. Remove the knuckle and hub assembly.
  10. Remove the lower ball joint from the knuckle.
  11. Remove the axle hub snap ring from the knuckle. toy_car_cor-02-04wheelhub2.gif
  12. Remove the axle hub from the hub bearing using special tool 09520-00031 or equivalent hub puller.
  13. Remove the inner race from the axle hub using special tool 09950-40011 or equivalent puller.
  14. Remove the dust shield from the knuckle.
  15. Remove the axle hub bearing from the knuckle using special tool 09520-00031 or equivalent and a press.
To Install:
  1. Install the axle hub bearing on the knuckle using special tool 09950-600020 or equivalent and a press.
  2. Install the dust shield on the knuckle with 3 mounting bolts.
    • Tighten 73 in-lb (90 Nm).
  3. Install the axle hub on the knuckle using special tool 09950-600010 or equivalent and a press.
  4. Install the axle hub snap ring.
  5. Install the lower ball joint on the knuckle.
    • Tighten the ball stud castle nut 76 ft-lb (103 Nm).
  6. Install a new cotter pin.
  7. Install the knuckle on the strut with the 2 nuts and bolts.
    • Tighten 162 ft-lb (220 Nm) (except '03-'04) 113 ft-lb (153 Nm) ('03-'04).
  8. Lift the knuckle and hub assembly over the axle shaft and into the hub splines.
  9. Install the lower control arm on the lower ball joint.
  10. Connect the tie rod end to the knuckle.
  11. Connect the stabilizer link to the strut.
  12. Install the front rotor and brake caliper to the knuckle.
    • Tighten the 2 caliper bolts 79 ft-lb (107 Nm).
  13. Install the ABS sensor if equipped.
  14. Install the front axle hub lock nut.
    • Tighten 159 ft-lb (216 Nm) and stake the lock nut.
  15. Check the axle hub backlash and run-out.
  16. Install the front wheel.
  17. Check the front wheel alignment and adjust if necessary.
Feb 17, 2011 | Toyota Corolla Cars & Trucks
Do i need any special tools to remove and replace the rear wheel bearings on a 1991 ae95r corolla? or can i manage with a pretty basic tool set? cheers.
the rear wheel bearings have to be pressed together, you have to remove the hole hub assembly and then have some one press the hub apart and back together, so what i am saying is that you can remove the hub assembly with just some basic hand tools but unless you have a press you can not replace the bearing.
Feb 04, 2011 | Toyota Corolla Cars & Trucks
How to replace a Jaguar X Type fron wheel bearing
Jaguar 2000-06
Wheel Bearings
  1. Remove the brake disc.
  2. Remove and discard the retaining clip. Detach the ABS sensor.
  3. Remove and discard the O-ring seal.
  4. Remove the wheel hub and bearing retaining bolts.
  5. Remove the wheel hub and bearing.
  6. Prior to applying sealer, clean the ABS sensor sealing surface and the ABS sensor aperture sealing surface.
  7. Install a new O-ring seal.
  8. Apply a 2.5mm bead of Loctite Ultra Blue 587 Silicone (RTV) sealer to the ABS sensor sealing surface.
  9. Install a new ABS sensor retaining clip.
  10. Install the hub/bearing assembly. Tighten to 90 Nm.
  1. Remove wheel knuckle.
NOTE When removing the wheel hub from the wheel knuckle the bearing will be destroyed and the bearing inner ring will remain on the wheel hub.
Fig. Using special tools, remove the wheel hub-X-Type
  1. Using special tools, remove the wheel hub.
  2. Using a suitable tool, remove the bearing inner ring.
  3. Using special tools, remove the wheel bearing.
    Fig. Using a suitable tool, remove the bearing inner ring-X-Type
    Fig. Using special tools, remove the wheel bearing-X-Type
To install:
Fig. Insert special tool 204-312 in to 204-309-X-Type
  1. Insert special tool 204-312 in to 204-309.
  2. Support the wheel knuckle on special tools.
NOTE Make sure wheel bearing is correctly orientated with the colored side facing inboard.
  1. Align the bearing over special tool.
  2. Using special tools, press bearing into wheel knuckle.
  3. Change special tool 204-312 to 204-313.
  4. Align the bearing and wheel knuckle over special tool.
  5. Slide wheel hub over the guide and align to the bearing.
  6. Using special tools install the wheel hub.
  7. Install the wheel knuckle.
    Fig. Using special tools, press bearing into wheel knuckle-X-Type
    Fig. Change special tool 204-312 to 204-313-X-Type
    Fig. Align the bearing and wheel knuckle over special tool-X-Type
    Fig. Slide wheel hub over the guide and align to the bearing-X-Type
  1. Raise front of vehicle and support on stands.
  2. Remove appropriate road wheel.
  3. Using wire or string, secure brake caliper to road spring to take weight off brake hose.
  4. Raise vehicle sufficient to provide access for special tool 204-111.
  5. Install special tool 204-111 in road spring.
  6. Slacken tool adjuster to suit spring length.
  7. Install adaptor and thrust collar.
  8. Position stem of tool in center of spring passing dowel through slot in suspension turret.
    Fig. Install special tool 204-111 in road spring-XJ Range and XK Range
    Fig. Position stem of tool in center of spring passing dowel through slot in suspension turret-XJ Range and XK Range
NOTE When turning tool adjuster, ensure that tool stem does not rotate and disturb position of dowel in suspension turret.
  1. Engage dowel of special tool 204-111 in suspension turret and rotate to position across slot.
  2. Lower vehicle onto stands.
  3. Rotate tool adjuster to tension spring.
  4. Remove wheel speed sensor securing screw and withdraw sensor from vertical link.
  5. Remove nut securing tie rod outer ball joint to steering arm.
  6. Release ball joint from vertical link.
  7. Install special tool 211-098 on tie rod outer ball joint.
  8. Tighten tool bolt to release taper pin from vertical link.
  9. Remove special tool from ball joint and position tie rod for access.
  10. Remove nut securing upper control arm ball joint to vertical link.
    Fig. Install special tool 211-098 on tie rod outer ball joint-XJ Range and XK Range
continue...
Aug 03, 2010 | 2002 Jaguar X-Type
How do i change front wheel bearing on a ford focus st2
SECTION 204-01: Front Suspension 2000 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 03/18/2003 Wheel Bearing
Special Tool(s) 15064.jpg Installer, Wheel Hub Bearing Cup
204-023 (T73T-1217-A) 21171.jpg Remover/Installer, Bushing
204-180 (T93P-5493-A) 15064.jpg Installer, Drive Pinion Bearing Cup
205-140 (T80T-4000-F) 205153.jpg Adapter for 303-224 (Handle)
205-153 (T80T-4000-W) d84l1123a.jpg Puller, Bearing
205-D064 (D84L-1123-A) 21217.jpg Installer, Wheel Speed Sensor Ring
206-054 (T93P-20202-A) Removal
  1. Remove the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
  1. NOTE: When removing the hub from the wheel knuckle the bearing will be destroyed. The bearing inner ring will be on the hub and the bearing outer ring will be in the wheel knuckle.
    Using the special tools, remove the wheel hub from the wheel knuckle.
  1. ani_caut.gif CAUTION: The special tools must be used to prevent damage to the hub. If the hub is damaged a new hub must be installed.
    ani_caut.gif CAUTION: Do not use heat to remove the bearing inner ring.
    Using the special tools, remove the bearing inner ring from the wheel hub.
  1. Remove the circlip from the wheel knuckle.
  1. Install the old bearing inner ring.
    1. Install the bearing cage on to the bearing inner ring.
    1. Install the bearing cage and inner ring assembly to the wheel knuckle.
  1. Using the special tools, remove the bearing outer ring from the wheel knuckle.
Installation
ani_caut.gif CAUTION: Avoid any impact on the wheel speed sensor ring.
ani_caut.gif CAUTION: Make sure the wheel speed sensor ring is clean.
ani_caut.gif CAUTION: Avoid any contact between the wheel speed sensor ring and a magnetic surface.
  1. ani_caut.gif CAUTION: Make sure the wheel bearing is installed into the wheel knuckle with the wheel speed sensor ring, colored black, at the wheel speed sensor end of the wheel knuckle.
    Using the special tools, install the new wheel bearing to the wheel knuckle.
  1. NOTE: Make sure the circlip does not cover the wheel speed sensor.
    Install the circlip to the wheel knuckle.
  1. Using the special tools, install the wheel hub to the wheel knuckle.
  1. Install the wheel knuckle. For additional information, refer to Wheel Knuckle in this section.
Apr 05, 2010 | 2000 Ford Focus
1996 caravan broke all bolts free hub assembly still will not
Rear hubs? according to book, need a special tool to pull them... according to a loal shop, bang on it til it releases... you will need to replace it anyways.... might look for a rental place that rents the tool.
Peace
Feb 27, 2010 | 1996 Dodge Caravan
Vitara freewheel hubs stuck in drive position . ( jx4u2 mod.)
Yes you can strip them down but its not easy and you need to be mindfull that there are two large springs inside. You will prob find that there is a part inside that has disintergrated causing the hub to stay in drive. Not sure if you can buy the pars singally though.
Feb 03, 2009 | 2000 Suzuki Vitara
Mavic Speed City Road Bike Wheelset Logo
80 people viewed this question
Top Mavic Cycling Experts
Eric Hidle
Level 1 Expert
Michial Gueffroy
Mack Baxter
Are you a Mavic Cycling Expert? Answer questions, earn points and help others
