Question about Cooper Wiring Devices Aspire Smart Dimmer Switch, Sand
Need visual instructions for 600w-120v ac/c.a./ca 60hz
1) If you are replacing a switch that has two wires, and your dimmer has two screws > then Connect these wires to either screw.
2) If you are replacing a switch that has two wires, and your dimmer has three screws > then Connect one wire to dark-colored screw, and connect other wire to either brass-colored screw.
3) If you are replacing a 3-way switch that has 3 wires > and your dimmer has three screws > then pay close attention: One of the wires on your existing switch is connected to dark-colored screw. Mark that wire. It connects to dark colored screw on dimmer. The other two wires connect to either screw. The dark-colored screw is called the common terminal.
IF you have already removed switch and do not know which wire was connected to dark-colored screw >>> then connect the wires to any screw on dimmer >> turn on power and check if the circuit works >> keep rotating wires until they arrive in the right order >> the circuit simply will not work until the to correct wire is connected to dark-colored screw
THE dark-colored screw is the key
Posted on Oct 11, 2010
Can I use a blender that I got from America here in South Africa it has a different plug and will the wattage be the same
Sheila You most likely will destroy the blender.
The voltage of the blender most likely will be designed for 120v AC and the South Africa power point will be 230v AC . (if internet information on SA is correct )
Check for a label on the blender that tells you what the input voltage AC is. most likely it will show 120V 60HZ
then you need a step down transformer.
https://www.tortech.com.au/step-down-transformer-australia/usa-step-down-transformer
Google search 240v AC to 115V AC step down transformer
Feb 21, 2018 | The Computers & Internet
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
A couple of fuses are out. Can they be replaced? If so, how do find instructions?
Open the set, check the "fuses", replace any bad with oem fuses, hope set does have two or more, see if set works.
May 26, 2012 | Televison & Video
I need specifications about the power supply for for the Maxell FPS-1 2 speakers ...
Input Voltage: 110 V AC
Power Source: Power Supply
Frequency Response: 70 Hz to 18 kHz
Mar 04, 2011 | Maxell Flat Speakers With Subwoofer and...
Need to convert 120V AC/DC current to 120V AC 60Hz 15W
there is no such thing as "ac/dc" current-its either one or the other--if its a 120 Volts then chances are it is AC already-at 60hz---the 15 Watts or any Watts is the amount of draw from the unit-not the power supplied to it- Watts= Volts(supplied)/Amps(being used) if you only want to supply 15 watts then reduce the amps (with a fuse) to .125amps
Mar 26, 2010 | Computers & Internet
Cooper Wiring Devices Aspire Smart Dimmer Switch, Sand Logo
296 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Steve
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
