Question about Philips HTS-3565 Theater System
I have a phillips HTS-3565 DVD theater system that will turn on, and run for about 5 minutes, then turns off. If you wait a couple of minutes, it will turn back on, and will do the same thing again. Whats your opinion?
  • 1 more comment
  • kerrybrentdu Oct 11, 2010
    I have a phillips HTS-3565 home theater system. When I turn it on, it will run for about 5 minutes, then it will turn off. I can wait a couple minutes, turn it back on, and it will do the same thing again. its like its overloading, or overheating or something. what do you think the problem is?
    what is an IC?
    THANK YOU
    Genius:
  • 1,035 Answers
HI, Try to plugged in the unit to other wall socket. If it is doing the same thing then open the unit and check the board for burnt IC and replace the IC.
Posted on Oct 11, 2010
  • Angelito Rabago
    Angelito Rabago Oct 11, 2010
    its the micro chips inside the unit. I recommend that you seek help from electrician. Do not plugged the unit anymore to prevent further damage.
  • 10,594 Answers
You mean unit turns back On itself when it shuts down for some reason?
It seems problem with power supply circuit that shuts down and turns On and doing wired things with home theater system.
Unplug unit for some time to get it reset, replug back in and check that might solve your issue.
Thanks
Posted on Oct 10, 2010
  • Shahid Electronics
    Shahid Electronics Oct 11, 2010
    OK, little bit details in your next post shows it is problem with amplifier output section and most probably sound amplifier output chip heated up and cause activation of protection circuit.
    Replace bad chip to fix the unit.
My Phillips HTS-3565 system will not come on what can be wrong?
May be the power supply section is Burnt
show it to a technician
Nov 24, 2014 | Audio Players & Recorders
How do i connect my pc to my phillips home theatre system through an hdmi cable
The best way is to connect your laptop to a spare HDMI input on your TV first, then use the AUX OUT from your TV to the AUX IN1 of the Phillips Home theatre system using a standard RCA cable.
The only catch with this is that you will have stereo analog audio, NOT digital surround. However, by pressing the "SURROUND" button of your Phillips HTS remote you can switch the audio output to multi-channel surround, stereo or party mode.
What is the model number of the TV you are using?
Oct 23, 2012 | Philips HTS-3565 Theater System
It may be possible that this DVD is not from the same region as my DVD player. PHILLIPS HTS 3265. But my question is how do I make out that my Video CD of violin brothers from ASHA AUDIO FALLS IN WHICH...
Hello Dhrubajyo,
[...] The VCD format has no region coding, so discs can be played on any compatible machine worldwide. Many VCD players can compensate for the differing frame rate and pixel count between NTSC and PAL/SECAM TV systems. [...]
http://en.wikipedia.org/wiki/Video_CD
You might have a problem with PAL/NTSC system here, but I assure you that it is not the matter of the region setting. Also - please, be careful when changing the region. Many players offer possibility to change it only several times. 5 times as the most often option. After 5 changes, the setting is locked.
Mar 01, 2011 | Philips HTS-3565 Theater System
I GOT YOUR HELP PREVIOUSLY. RECENTLY I AM HAVING FOLLOWING PROBLEMS WITH MY PHILLIPS HOME THEATRE MODEL-HTS-3265. **** I HAVE BOUGHT ONE VIDEO CD OF VIOLIN BROTHERS LIVE CONCERT FROM ASHA AUDIO BUT...
It's possible that this DVD is not from the same region as the DVD player.
For instance, a DVD from India (region 5) will not play in a DVD player from the US (region 1).
You may want to check into that and post a reply here.
No sound
I have a similar problem. After about 20 minutes, it begings to heat excessively, though it does not malfunction (i consider myself lucky).
Mar 19, 2010 | Philips HTS-3565 Theater System
I have tried now 5 different Transformer 2 DVDs in my stand alone DVD player and NONE of them work. Every other recent release DVD (Star Trek, etc.) work just fine - what's up???
Are you using an HDMI cable? Make sure all your devices are HDCP compatible. This is a copywrite protection encryption created by Intel protecting digital entertainment content.
Dec 30, 2009 | Philips HTS-3565 Theater System
Want to make my philips DVD HTS 3265 a code free one. it is region 3 and I want to see DVD region 2
Open Tray
Place different zone DVD into player tray
Press 99990
Press Play
Enjoy
May 30, 2009 | Philips HTS-3565 Theater System
Philips HTS 3565 system doesn't play MPEG-4(.mp4) formate. TV screen doesn't show the mp4 file, but DIVX files are readable. Can u help me to solve the problem.
HTS 3565 this model does not supports the MPEG4 video format, but you can play MPEG1, MPEG2, DivX 3.11, DivX 4.x, DivX 5.x, DivX 6.0, DivX Ultra, WMV all these formats.
Mar 26, 2009 | Philips HTS-3565 Theater System
Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "0" TO UNLOCK ALL
PRESS "OK"
Aug 20, 2008 | Philips HTS-3565 Theater System
Philips HTS-3565 Theater System Logo
258 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
