Question about Sharp 25R-S100 25" TV
Repeated burn up horizontal transistor
Sharp #25r_s100 25" tv i try to repairing. problem was tv repeated burn up horizontal transistor & making noise from transformer in power supply when i replace back same # horizontal transistor.anyone could help me to solve this problem? i wish! thanks
  • solver gariz Jun 01, 2008
    how i get out of old technology,????dear BUBRUCE.
  • Anonymous Dec 06, 2008
    I have the same problem
    Problem Solver:
  • 14 Answers
Yah get out of old technology.
Posted on May 31, 2008
Tv trouble shooting guide
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Jul 18, 2014 | Sharp 25R-S100 25" TV
My tv made a little noise and then the picture disappeared. The screen is black with a vertical line of picture approx 1/4 inch wide going up the middle of the screen. Is it fixable?
Generally this is not good news. Even in the event this TV is repaired, it will work very long. This TV has a horizontal problem. This is the most stressed area of any conventional TV. The Horizontal Output Transistor will need replace, the flyback transformer is bad, you have bad power supply with horizontal capacitors that are bad, and last, is a possible bad picture tube. This TV is not worth the effort or money to repair. Thanks for asking and show all hands of support!
May 20, 2011 | Sharp 32SC26B 32" TV
Sharp tv primo 21`inch turn on red light only
check your horizontal transistor maybe it's shorted replace horizontal transistor or maybe the fusible fuses are open check for open resistors at the horizontal section of the circuit.
Dec 22, 2010 | Sharp Televison & Video
Tv not switching on just makin noise from power supply & hissing @ the flyback transformer with horizontal becoming extremly hot then afew min later horizontal burns out(D1398)
If the horizontal transistor getting shorted, this could happen.
Check the transistor 2 SD1398. If found faulty replace it.
But replace black colored doides in the circuit as a whole.
Leaky diodes can not be determined easily with the multi meter.
Especialy the small high voltage diode near the small transformer
connected to the 2 SD1368 transistor.
Sep 03, 2010 | Televison & Video
Won't turn on. makes whiney noise. fuse ok
The set has a shorted horizontal output transistor and possibly a bad high voltage transformer. The transistor can be checked with a DVM but the transformer has to have its impedance checked with a "ringer". Also solder all stages in the drive circuit of the horizontal transistor. The power supply is making the noises because of the short on the secondary side. Thanks for using fixya.
Nov 12, 2009 | GE 32GT740 32" TV
Shut off itself
sounds like you might have an auto overvoltage shutdown circuit kicking in. The hivoltage goes to high and the monitoring circuit auto shuts down. More than likely trouble is in hivoltage circuitry. If you have a transformer that will allow you to bring up the set slowly without shutting down and you can look to see what's happening.
Feb 16, 2009 | Sharp 25R-S100 25" TV
Hyundai 14" colored tv no power
if the final flyback is ok ,then check the driver transistor and the voltage in his collector .Probably the flyback transformer is ok.please reply.
Oct 17, 2008 | Sharp 25R-S100 25" TV
Sharp colored tv
check the b+ supply of your flyback if they have check the horisontal transistor. check also if they have 5v supply in the system and 9v in the chroma ic or replace the memory ic.please reply.
Aug 08, 2008 | Sharp 25R-S100 25" TV
Sorry if that sounded kind of kurt. All that i ment is that the price of repeadly fixing an older tube tv may start to outweigh the price of a new flat panel tv. Also samsung (if you like that brand) is still making high definition slim fit tube tv's. Which is an older technology driven tv with new bells and wistles. Also sony's XBR line is an absolutely fantastic tv. When tube tv's were being mas produced sony came up with the XBR line and have been using it ever since. If you can find an XBR series tube tv for a reasonable price you can bet on the fact that it will be a phoneminal tv without spending the mass amounts of money on a flat panel. But as for the repeated burn up of your transistor i cant be of much help. And if thats all you care about doing is fixing the tv you already have well then i just wasted a few min. of your life. I wish i could be of more help on this.
Jun 01, 2008 | Sharp 25R-S100 25" TV
RCA F27669 27"
The F27669 uses the CTC203 series chassis. The most common cause of that symptom is a shorted horizontal output transistor, caused by a cracked solder joint on a small coil connected to that transistor's base. When this happens, the main B+ supply is shorted to ground so the power supply squeels. Every once in a while I also see the horizontal output transistor shorted due to a shorted flyback (high voltage) transformer. A good tech will replace the horizontal output transistor, resolder the coil and drive transformer, test the flyback (replacing it if necessary) and your set will be back to perfect.
Aug 08, 2007 | RCA 27V570T 27" TV
Sharp 25R-S100 25" TV Logo
118 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
