Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Makes steam. Leaks where pad goes into pad attachment. Pad doesn't get hot steam...just water but the pad doesn't really get wet but the floor does.
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Oct 11, 2010
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
Streaks on porcelein tile from shark steam mop
Try washing your pads in JUST water and Baking soda or Borax (and only about a tbs). Sounds like a hard water problem. I had the same issue with my wood floors so I put some Murphy's Oil in a spray bottle and it polished my floors while I steamed. Perhaps there is a good tile cleaner/polish you can spray with a spray bottle while you mop? Just a suggestion. I haven't had this particular issue with tile (our floors are concrete and wood) but the streaks went away when I started using just Borax in my laundry with them, no fabric softener, no dryer sheets. My mom used to use Isopropyl alcohol in a spray bottle with her steam mop. Make sure your tile is well seeled too, it gives you a better finish. The alcohol dries on it's own too without leaving residue.
Jul 09, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop S3501: Water leaks out but the steam does not reach the pad even with vigorous pumping. The pad mechanism blew off at one point before I realized there was a problem.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Dec 18, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I got power, lite on, tank is warm, but No Steam to mop pad, just a little water to wet the pad. Whats wrong?
heatman101
Dec 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bonaire steam mop no steam
heatman101
mm
Apr 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have the standard steam mop. It rarely puts out
its under warranty contact bissell the unit will be replaced by a local service center if you have any problem let me know
Dec 10, 2009 | Vacuums
The steam do not get hot it get warm athe water
Sarah, the unit is no good...
heatman101
Nov 16, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Floor Cleaner streaking on pergo laminate floor
Start with a clean pad. A dirty pad wil spread the wet residue around and strek the pergo. After steaming use a clean microfiber dust mop to buff the pergo. It will dry and shine yur laminate.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
260 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
