Question about Conair WW60 Weightwatchers Scale
How long the lithium batteries last for Conair Model WW60X?
  • 1,606 Answers
Lithium batteries should last about 3-5 years. That really depends on the amount of use, the way the unit is stored and even things like temperatures. If you replace the battery you need to make sure that the battery is fresh and not old stock. Thats another thing that will cause premature battery death is old stale batteries. Unfortunately the original batteries tend to fall into two types, better than you can find or a lot worse. If you are using the scale a lot ie several people using it then the batteries will also drop off pretty quick. Even in heavy commercial use the batteries should be good for well over a year.
Posted on Oct 10, 2010
My conair model th300 is giving me a reading of 288.8 then it goes to err.
I was thinking there were too reasons for this, but I can't find the specs on this scale. One reason may be that its upper weight has been exceeded, but I think that is unlikely. My other thought is that the battery is failing. It is enough to make it come one, and to register your weight, but not enough to continually display it. The instructions indicate it has a 3 volt lithium battery in a compartment in the back.
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=0ahUKEwjintjyt97RAhVU1mMKHdGnCQQQFghCMAY&url=http%3A%2F%2Fwww.conairscales.com%2Fcatalog.php%3Fproduct_id%3D428%26ib%3Den&usg=AFQjCNEp2iyMiCxDasXeoxeI_3r1no7RTA
Jan 25, 2017 | Conair Health & Beauty
We tried a new battery but not working
Is the lithium battery placed the correct way?
Dec 28, 2015 | Conair TH402 Thinner Digital Body Fat &...
Model ww66
In the event that the scale battery needs to be replaced, (display shows "Lo"),
open the battery cover on the bottom of the scale and replace the old battery with
a new 3V lithium battery.
Jun 04, 2014 | Conair WW60 Weightwatchers Scale
Model 0304y will not hold battery charge very long
2 possible reasons for this.
First, if you've had the rechargeable razor for a long time, after awhile lithium ion batteries eventually don't hold their charge as long and you'll be forced to replace it. It's not anything wrong with the product. These things just happen.
Another possible reason could be due to the outlet your using needs to be reset. This is pretty common. Just hit the reset button and the output power will increase drastically.
And last but not least it could be defective in which if you have had it for a year or less, normally on the higher quality products they offer a 1 year warranty. They'll replace it or fix it in order to keep you as a loyal customer. Just call their service department and they'll be able to help.
Their service number is 1-800-211-9611
Hope this helped!
Jun 18, 2011 | Conair 14 Beard & Mustache Trimmer
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
Battery always going dead use 4 regular lithium batteries
in this camera and most of fuji AA batteries, the batteries keeps draining even with the machine off .
if the camera is not on use REMOVE the battries.
i will recommend regular recghargable batteries with at least 2700 Mah type NiMH.
you can recharge them several times and they will last almost as those lithium batteries on that model. plus they will be cheaper
Oct 08, 2009 | Canon PowerShot S1 IS Digital Camera
Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Apr 24, 2009 | Conair WW60 Weightwatchers Scale
Conair WW60 Weightwatchers Scale Logo
279 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
