Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Problems with my Mitsubishi hd1080
I have had my HD 1080 for about 4 yrs just recently I started getting blue verticle lines across the whole screen. what can I do to fix it or whats wrong with it? blue flickering of verticle line on screen
    Problem Solver:
  • 14 Answers
Most likely you are looking at conversion chip problem. The replacement price on these can varry widely. It may be cheeper to look into purchasing a flat panel lcd or plasma tv.
Posted on May 31, 2008
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
I have a Mitsubishi HD 1080 55
Your unit has some sort of Thermal problem either with the PSU fault, or a thermal problem elsewhere that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. T
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 24, 2010 | Mitsubishi WS-55805 55" Rear Projection...
Why can't I receive in HD? i have the hd1080
Your set will only convert to 480p. There is no way a conventional crt based tv will get 1080p. The proper connections will be using the RGB component inputs on the jack panel ( red,grn,blue ) then the white and red for audio. The picture will be a lot better than standard cable but not as good as HD. ( 720p )
Dec 21, 2009 | Mitsubishi WS-55613 55" Rear Projection...
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
If the Blue lines are blurs or shadows, then your Convergence IC's are going or gone bad.
I have the same TV - it will be 4yrs. old in Dec. Mine started with Blue lines & shadows, then Red, Blue, Green Shadows. This is caused from over heating. The Convergence IC's have to be replaced.
I have had 3 TV Repair shops all quote me a price from $350. to $400. to repair. They all said 4 years is the usual life time for these IC's.
Replace the STK932-110amps with STK394-250-E or STK392-150 for greater reliability.
Use only Original Replacement Parts, there are some cheaper but won't last and can't take the heat.
If you are a "do-it-yourselfer" here is a link with the directions and pics.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Good Luck!
Mar 19, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi hd 1080
The format of what you are watching plays a major part in whether all of the screen is used. If the program is 4:3 the screen will remain pretty much square. 16: 9 would be the most desirable for filling all the area. Go ahead and acquire a manual, they're not much...accordianman
Feb 16, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WD-62825 vertical lines, blue snow, picture jumping
sounds like dm module
http://hdtvoice.com/voice/showthread.php?t=32186
Dec 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
