Question about Car Audio & Video
My eclipse 33250 premium amp keeps blowing fuses when I then it on
  • 195 Answers
If you have wires connected to it may be connected improperly. Check power and ground connections if they are connected properly then disconnect all RCA cables and re turn on amp if fuses blow then an internal problem exist and you must send it in for repair.
Posted on Oct 10, 2010
2003 eclipse and gauge fuse keeps blowing
you may have a broken wire in between the doors. there is a rubber boot the harness runs through u will have to take it off to inspect. hope this helps.
Apr 16, 2010 | 2004 Mitsubishi Eclipse
Radio quit working
does your system have power amplifier aside from your built in amp on radio? if yes, disconnect all supply then put new fuse. try this time, should not blow the fuse. then one by one, connect the supply fo your radio only, if ok, then next is the amplifier, if it blow the fuse, your power amplifier has an issue.
Apr 03, 2009 | 2001 Mitsubishi Eclipse
30amp motor fuse keeps blowing
remove all the other fuses and relays and plug them in one at a time to se which circuit the short is in.
Mar 25, 2009 | 1996 Mitsubishi Eclipse
Help my fuse is blow!
If the amp blows fuses only AFTER you send remote turn-on voltage to the amp, the amp probably has blown output transistors. To eliminate other possible causes, read through the following page.
Amp Troubleshooting
Let me know if you have any other questions.
Aug 25, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Fuse to the radio in my 2007 eclipse keeps blowing?
check your wires if you have or had a aftermartet cd player the wires may be touching or if its been stock they could have warn through thats all i can think of because in order to blow a fuse you have to have too much power running through the wires witch could make them wear through over bumps and such im not 100% sure but i think this could be your problem i hope i helped you man
Jun 24, 2008 | 2007 Mitsubishi Eclipse
Main fuse
you migh have a short in the alternator or the alternator circuit, but take a look in the owners manual to see what this fuse feeds, and we go from there, you can start unpluging thing by thing that this fuse feeds and see where the short is.
May 27, 2008 | 1996 Mitsubishi Eclipse
Amp turns on and off
loose power connections. check your terminals.
May 19, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Information on the Eclipse Premium 34230 Car Audio Amp
Specs: 370x2 RMS@ 4 ohm STEREO (the AMP DOES NOT BRIDGE) CLASS A/B (also do not run it 2 ohms unless you like smoke) 0.004% THD @ 4 ohm 105db S/N @ 4 ohm weighted 200 damping factor 11.85" (width) x 2.05" (height) x18.50" (length) 16lbs Worth somewhere is the 200.00 range if it is in really good condition
Jun 03, 2007 | Eclipse Premium 34230 Car Audio Amplifier
Car Audio & Video Logo
142 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
