Question about Polaroid i1035 Digital Camera
My polariod t1035 camera has fully charged battery, reset to factory settings, and reformatted memory. but when i turn on the camera, the screen is just black, no picture, except when i look at the pictures on the camera. i have taken a picture, and it comes out just black. please help.
    Novelist:
  • 82 Answers
Unfortunately this faulty cant yoou fix it alone...why this is a ccd crash the ccd is faulty...you must change the ccd or the entire lens block... you must now see if you have convenience to adjust the camera, why it s possible that the fixing cost is higher as the vaslue of a new camera. if you have a little eletronic knowledge it s possible to search on ebay the same camera with another faulty lcd faulty or other, so you can disassemble the lens bloc, but if you dont have any specific knowledge is possibl that you spend other money and cant fix it alone.. i make this fixing ion italy with a not so high price... but you must know that only the lens cost from 25---to 40 euro ...only the spares...and you have to count the work of the fixer..if the professional fixer are onest you can fix it with 55 -60 euro.. but i have see that all the fixer ask for this job 80 -90 euro
Posted on Oct 10, 2010
When I turn my camera on, the screen is black and makes beeping sound? Also lens is stuck
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | Cameras
Hp photosmart 945 camera problem
First try this
  1. Remove the memory card.
  2. Turn off the camera.
  3. Open the battery compartment and remove the batteries.
  4. Wait at least ten seconds.
  5. Reinsert the batteries and close the battery compartment door.
  6. Turn on the camera. When the camera is turned on, you will be prompted to input or verify the date and time.
Sep 24, 2008 | Cameras
LCD screen is blank in normal picture mode. I
This Camera has an CCD issue. It seems that the CCD of the Camera is gone bad. However, you may try resetting the Camera to the factory settings. If the issue persists, try power resetting the Camera. To power reset, remove the battery of the Camera and press and hold the power button for 30 seconds and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Jul 26, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
After charging my battery I installed the battery and turned the camera on. The lens came out and the screen came on. All of a sudden the screen turned solid white and faded to black. Now the camera will...
1. Ensure batteries are fully charged.
5. turn on camera and see.if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Apr 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
I have a sony cybershot dsc-f707 Icant zoom in or out only after I take a picture. I also wanted to know if I need to charge the lense to zoom?
Option 1:
Reset the Camera and check if it helps to resolve the issue.(Resetting the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera).
The RESET button is located inside the battery/ Memory Stick cover. The Camera should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
Option 2:
If issue persists try Power reset the Camera by removing the battery from the Camera and inserting it after 1 minute.
Use a fully charged Battery in the Camera so that the Zoom function work normally.
Aug 27, 2009 | Sony Cameras
When i turn on my camera the lens goes in and out but it wont let
Hello!
First, check if the Battery inserted in the Camera is fully charged. If not then charge the Battery to its fullest then insert it in the Camera to check its operation.
Next, remove the Battery from the Camera then press and hold the Power button for 30 seconds. Then, reinsert the Battery pack in the Camera and turn it ON and check its operation.
Finally, please check if the menu screen is accessible by pressing the menu button directly or while reviewing the captured images. If the menu screen is accessible then reset the Camera to the original factory settings.
Perform the steps given below to reset the Camera to the original factory settings:
(a) Please press the menu button directly or while reviewing the images to access the menu screen.
(b) Then, press the right arrow on the control button to select Setup option.
(c) Next, use left/right/up/down arrow on the control button to select "Setup 1" option.
(d) Then, select the "Initialize" and OK.
(e) Finally, follow the on-screen instructions to set the clock on the Camera.
performing all the above steps will reset the Camera to the original factory settings.
If, even after performing all the above steps, the issue persists then the issue is related to hardware malfunctioning and service will be required.
Please feel free to contact for further information or any clarification.
Aug 21, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony DSC-W55 Access Message - lenses going in & out automatically
Please remove the Battery from the Camera then reinsert it after two minutes. Make sure that the Battery is fully charged. if menu options are accessible on the Camera then reset it to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings:
(i) Please turn ON the Camera.
(ii) Then use the control button on the Camera to the select the Setup (setting) option.
(iii) Next, select the Setup1 option then "initialize".
Performing the above mentioned steps will reset the Camera to the original factory settings. If the issue persists then service will be required.
Jul 13, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera stuck when using memory card
hi, i had a problem with my camera where i put in memory card and it said 'out of memory' i took the card out turned on camera went to set up mode and found one that said 'rest to factory defaults' pressed that and then put card in and all ok, might be worth a try :-)
Mar 13, 2007 | Nikon Coolpix 3200 Digital Camera
Polaroid i1035 Digital Camera Logo
149 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
