Question about Arris Broadband Voice Gateway VT2442 (612572131848) Router
Need to open ports on a motorola router from vonage
How to connect Wireless router to Cabel Modem and Vonage Modem?
First of all: it would be good to know which devices you are using. This would help to be more specific.
But anyways:
  1. Connect a normal Ethernet cable from your DSL or Cable modem to the Internet (or WAN) port of your vonage router.
  2. Then connect another Ethernet cable from one of theLAN ports of the vonage device to the Internet (or WAN) port of your Linksys (The one that is separated from the 4 LAN ports.)
  3. Make sure that the Linksys is set to DHCP (Dynamic IP Address), soit can get it's IP address from the vonage router! (Look at your manual. If you don't have one, you can get it here. Choose the right version number - you can find that on a sticker at the bottom of the router - and download the user guide)
  4. Connect your computer to one of the LAN ports on the Linksys.
If you have any more questions or this desciption is not clear to you,just come back here and leave a comment - I'm happy to help.
May 22, 2009 | Linksys Wireless-G WRT54G Router
Can't connect reliance ec325 on ubuntu7.1
This can be a real challenge.
If you cannot get on, then get the D-Link box as a quick fix.
You may , just may need to open what is called a UDP port for the router, which if you can get in then set the udp port to accept your vonage.
Vonage is pretty rock solid and most boxes have all udp ports open.
You issue is that you are using a PPP and that is a real source of trouble. You have to be able to tweak the incoming router box. Some ISP 's want you to use there phones and will block ports so you cannot do much.
Complain to your internet provider. Make them fix it or replace a box that will allow open communications with the Linksys / vonage box.
e
Jan 12, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
Can't call home phone
Make sure your the internet is working fine on the router. If it is, you need to call vonage and have them activate the phone ports of the router. The phone ports on the back of the router needs to be registered first through vonage. That should do it.
Oct 14, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Vonage ip voice will not work with internal firewall turned on
then iot seems that your fire wall is not compatible with it, try installing a different one, or try port forwarding that will fix your problem
Aug 15, 2008 | Arris SURFboard SBG900 Wireless Router...
Help!!!
Do you have the Vonage in front... or behind the router?
Behind: http://www.vonage.com/support.php?article=88
In front: http://www.vonage.com/support.php?article=1154
Also may need to log into your Router and setup port forwarding
http://www.vonage.com/support.php?article=1098&topic=20
Need more help.. let us know.
www.techvisitor.com
Jul 06, 2008 | Arris Wireless G Broadband Router (wr850g)
Vonage does not work with D-Link router
If you plugged a telephone into your D-link router, unplug it - that can not work!
You have to plug your vonage router (WAN port) into the D-Link (LAN port) and connect your phone to one of the LAN ports of the vonage router.
If you do not need the wireless capabilities of the D-Link, you can simply take that one out and only use your vonage router.
If you need more help, I would need more details form you:
Which vonage adapter are you using?
How is your setup (i.e. modem -> D-link -> vonage & computers)
What connections are you using (wire/wireless)?
You can also find help here.
Jun 17, 2008 | D-Link DI-704P Router
Nat
First call microsoft and tell them that your nat is moderate. (for me it still works on moderate...???) Tell them your router and internet service provider. They will tell you a port number which will have to be opened in order to make your connection stronger. then call your router manufacturer. (or vonage) And they have to help you.
Mar 24, 2008 | Computers & Internet
How do i port forward to open it so that i can use my vonage device
Chances are there refering to the ports page in your lynksys router page. By opening the correct port you should be able to get a connection. But your going to need to find out the correct port from the company.
Dec 29, 2007 | Linksys Wireless-G WRT54GS Router...
Can't connect to the Internet
iam workinh for vonage and so its ur phone working then change the ether net cable>and and delete all the temp files and cookies and clear history>and also if still its not works change teh ether net port bet ween the pc to teh vonage devie>and still if its works then u need to check with the ether net card driver or ether net card>rate me solved if its help full
Oct 31, 2007 | Arris WR850G Router (DHWR850G)
Arris Broadband Voice Gateway VT2442 (612572131848) Router Logo
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
