Question about Daewoo FR-147RV
DAEWOO REF. MODEL MCBR101W THE FREEZER KEEP GETTING FULL OF FROST AND ICE SO THE REFRIGERATOR GETS WARN DUE TO ICE BUILD UP?
2 Suggested Answers
  • 79 Answers
SOURCE: Freezer section is iceing up
There are 3 things that will cause a defrost free refrigerator to do this, the defrost timer, the defrost heater, or the defrost termination sensor. I would start with the timer. You will need to look the cabinet over closely. Look inside by the cold control, you are looking for a hole with a plastic screw that can only be turned one way with a flat blade screw driver, if not there look in the back, once found turn it till the compressor shuts down, if you find the drip tray full of water, you know the other two items are good, and replace the defrost timer
Posted on Jun 23, 2009
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
Tip
Simple thing you can do if the ref is not getting cold enough.
1. Defrost the freezer if you see ice on the inside wall.
This is a very common problem. Before you call a technician do this.
Defrost the freezer completely, and when you put the items back, make sure that the vent are not being blocked. The fan needs to circulate the air inside the freezer to keep it from having frost. Ice build up causes circulation problem which causes the ref and even the freezer to not get cold enough. Since the thermostat senses that it is not getting cold enough the refrigerator runs constantly and producing even more frost. Then the owner turns the refrigerator to coldest setting which actually do not help, or maybe make the problem even worse, all the while running up the electric bill as well. So there you go.
on Feb 18, 2010 | Refrigerators
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
There is water leaking from front right and left periodicaly. its a no frost daewoo fridge freezer
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Aug 24, 2011 | Daewoo Refrigerators
My freezer keeps defrosting even on high settings. On high settings the freezer fan get stuck because of frost build up.
try to set your ref on normal setting due to hi setting frost is easily build up that thermo disc sense it that trigger your defrost heater to energized.or adjust your defrost timer.
Mar 05, 2011 | Electrolux Refrigerators
Only the freezer is working the bottompart wont
The cooling in the ref. section is done w/ a vent that passes air from the freezer. The adjustment maybe labeled "freezer temp". When you locate it, check w/ hand for cool airflow. Insure that it is not blocked. Set vent control @midpoint and give it 24 hrs to stableize.
P.S. If you have a defrost problem, the coil will frostup and not allow proper airflow. Check rear panel for frost build-up, and check if your freezer can keep ice cream hard. If either, leave unit off overnight w/ doors proped open, then re-check operation.
Dec 30, 2010 | Daewoo Refrigerators
Frost build up around ice dispenser in freezer
Suddenly having the same problem. Any solution?
May 16, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Refrigerator is not defrosting right..whirlpool ref..
is it frost or ice.if frost you will need an ohm meter to check continouty on the heaters and term thermostat.term thermo must be cold to check.if ther ok check voltage to the heater system from the defrost timer.if no voltage replace timer.if its ice it could be a blocked defrost drain.unblock clean out
Dec 31, 2008 | Whirlpool GD2SHGX Refrigerator
Freezer temp 7-20, ref temp steady 35. Ice on return line
HI thanks for your question. the way that frost builds up on the return line is the freezer is running too long . you have the temp set at too cold a setting 34 deg is too cold. it should be 36. 37. other wise frost builds up.thanks the appliance doc. please rate my answer. thanks.
Aug 13, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Daewoo FR-147RV Logo
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
