Question about Acer Computers & Internet
I want to reformat myextensa 2300 laptopanits not working by the method in the booklet on the info disk can you please tell me how to clear the hard drive and restore the system to original
  • 21 Answers
You will still need the original drivers and OS using this method first you need to remove your hard drive, determine wether it is an IDE or a SATA or other connections and get a USB IDE or SATA connection connect this to your hard disk open you HD to another PC like a USB flash Card back up all DAT using this technique then reformat you HD return your HD to you laptop reinstall OS and drivers then you have a fresh laptop. Buying a new Hard disk will also be easier then you can just use your old HDD as a backup. Best of luck read manuals and be careful.
Posted on May 31, 2008
Hard disk sector problems
Yes, and maybe.
How's that for a clear, concise answer?
When using the Restoration Disk, or a fresh new Installation Disk; if there are bad sectors you will be advised that CHKDSK, is about to run. (Or instructed to use CHecKDiSK, and how)
CHKDSK will then see if there are good sectors that it can move info over to, OR; you will be advised that you have an irreparable hard disk. (Harddrive)
Reformatting is using the Restoration Disk, or Full Installation disk; and when asked choose Full Install.
(Destructive Installation)
Do NOT click on Format in ANY other way.
USE the Restoration Disk, or Full Installation disk.
(Otherwise you will wipe the harddrive clean, and you do NOT want to do this)
For additional questions please post in a Comment.
Dec 16, 2012 | HP Pavilion a6645f Verde Special Edition...
How can i reformat my acer aspire 4520 without cd rom?
Try this method it may work.
If you can boot up with the external USB hard drive on your Acer, then use a working computer and copy the Windows installation CD onto the external hard disk then connect the USB externak hard disk to the USB port on your Acer and boot up using the external hard drive.
Feb 18, 2012 | Acer Aspire 4520-5141 Notebook
Hi, i have a Seagate Expansion 1 TB USB 2.0 Desktop External Hard Drive and i want to backup my macintosh by using disk utility. However it seems like as i plug the hard drive in, i cannot put anything...
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in Mac OSX Journeled Format.
6. Click Apply.
7. Done.
P.S. : It will erase everything from your HDD so remember to backup all data before doing this.
Hope it Helps..!!
Jul 13, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
What is the maximum size of hard drive for the travelmate 2300
Please keep in mind this unit uses IDE hard drive instead of SATA. The default 2300 uses a 30 GB high-capacity Enhanced-IDE hard disk. With latest BIOS upgrade, this unit will be able to have anything installed. 80GB, 160GB, 250GB, 320GB, 500GB.
However, I believe that IDE hard drives are slowly but surely becoming obsolete and legacy and they seem to be more expensive as well.
May 16, 2010 | Acer TravelMate 2300 Notebook
Getting a blue screen stop error, but cant log
Please try to start from the beginning and reformat the hard drive by shutting down the system with the cd drawer open. Then insert the windows disk and turn on the pc then the drawer closes and when it tells you boot from cd press enter. Then windows will load. It will give you a couple of options. Always choose format partition. Then you should not have any problems. Unless your hard drive is bad.
Dec 14, 2009 | Microsoft Windows XP Professional With...
Avertec 2300 will only power on to a black screen and says Read disk error, press control alt, delete to reset, but when you do this the same thing apears over and over, Will not take any disk windows or...
Sorry, a Read Disk error means the disk is dead or dying. At a minimum, you have to reformat it and reinstall Windows. If it doesn't reformat, then you need a new hard drive.
Oct 27, 2009 | Averatec 3200 Notebook
My Acer Travelmate 2310 freezes
Problem with the Hard Disk. either replace it or Format the Hard Disk to clear the bad sectors.
Jun 11, 2009 | Acer TravelMate 2300 Notebook
Setup did not find any hard disk drivers installed on your...
dear friend
you need to goto bios and search for and option "sata native support"
set it to disabled
if you cant find that , then you need to splitstream sata drivers into windows xp cd, if this is the case please ask me to tell you the method
Apr 10, 2009 | Toshiba Satellite M205-S7452 Notebook
Hard disk partation not found
better to dump your data from main hard disk then once reformat your main hard disk then that external hard disk work properly .............
Feb 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
