Question about HP P2360AA Keyboard/Mouse
A red light comes on my hp touchpad and I loose all control, and can't get it back. How do i re-gain controll of my touch pad?
It shows that you have accidentally shut off the touch pad. In the upper left corner of the touch pad is a dimple/circular depression. Tap it twice, the light will go out and normal touch pad function will return.
Posted on Jul 31, 2014
2 Suggested Answers
aceltix
  • 119 Answers
SOURCE: touch pad
well,it seems it is  phisical problem.It is,in poor word,quite damaged.by steping on it some internal circuit might have  been broken.
try to consult a specialized in leptops and hardware
good luck
Posted on Feb 04, 2008
Touch pad light doesn't come on
Download and reinstall the touchpad drivers.
Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Touchpad drivers.
Apr 24, 2012 | Computers & Internet
My mouse pad in my computer wont work when i tap it
It will depend on what touch pad (and related software) is installed on the particular computer, but you will find the tap option under the Control Panel. Open your control panel, select "Mouse" There will be a TAB in the mouse properties called "touchpad" (surprise, surprise!) where you can toggle tapping on/off.
Hope this helps. PS: if you DONT see the touchpad option - you will first need to install the drivers/software for your touchpad. Most HP touchpads are the Synaptics Touch Pads - Find the drivers here: --> Click here!
Feb 07, 2011 | HP Computers & Internet
Touch pad on hp pavilion dv4000 not working. Driver installed touch pad not visable in control panel. How do I re-install.
somewhere on the keyboard there should be a button that disables the touchpad to use an external mouse.you should be able to locate that button.sometimes it will lite up red.
Jan 12, 2011 | HP Pavilion dv4000 Notebook
How do i turn off zoom function of synaptics touch pad Hp laptop
Are you talking about the two finger zoom by spreading your fingers apart on the touchpad to zoom out or pinching them together to zoom back in?
This works for Dell touch pads so below where it says ‘Dell touchpad’ it probably says HP touchpad?
· Goto your control panel
· Click on ‘Mouse’
· Click on the ‘Dell touchpad’ tab
· On the resultant popup screen, double click on the main touch pad region
· Click on the ‘gestures’ setting
· Uncheck the zoom
Good luck…Chris
Jan 16, 2010 | HP Pavilion Dv3-1075us Notebook
I am using my phone to ask this question.
the touch pad is usually controlled by synaptic.
To turn it on back, press start menu from your key board and scroll to control panel.
From control panel, use the tab button to select the icons on control panel and go to mouse.
From mouse, use your keyboard to control to device settings.
From device settings, you would see synaptics touch pad, then press enable and that's all.
You touch pad would then be enabled again.
All the best.
Jan 05, 2010 | HP Compaq Presario 2200 Notebook
My HP Mini touch pad is locked up. There's a red light right above the touch pad that is usually white.
on the new hp mini - you double tap the touchpad indicator (upper left) to toggle the touchpad on & off
Oct 30, 2009 | HP 2133 Mini-Note Notebook
Cannot tap touch pad
There is not a whole lot of information that you are giving us. There would be two reasons the touchpad does not work...one, there is a small button above the touchpad and if it is red (orange) the pad is off and you have to tap that button until the light turns blue. If the light is blue, then the tapping part of the pad has been turned off in mouse properties. Open control panel > mouse Properties > device settings > click on settings button and enable tapping. All other touchpad settings are in there to modify also.
Sep 12, 2009 | HP Pavilion dv6000z Notebook
A BEEP COMES ON - F 1 READING - HAD REPAIR MAN OVER 3 TIMES- CHANGES PART KEEPS ON HAPPENING
Usually if the symptoms stop with the touchpad disconnected from the clock, that touchpad is often the cause. If the error continues even with the touchpad disconnected, the clock itself is usually at fault and will need to be replaced to correct the problem. On some models it is not possible to disconnect the two in which case the electronic control/clock would have to be replaced regardless.
There is a tool that allows testing of the touchpad (on models where they're separate parts) but is kind of expensive for a homeowner to purchase them self. If you contact a technician so equipped, they should be able to test the touchpad before replacing any parts.
BTW. On most models, the control keypad is only sold along with the whole control pane.
You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor - check carefully the wires to and from the oven temp sensor!! This has been a new occurrence to us in the last 2-3 years or so
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 01, 2009 | Magic Chef CGR3725 Gas Kitchen Range
F1 Error Code
F1 generally means the touchpad or ERC (Electronic Rage Control) is bad. This is what Maytag recommends as a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1: - Disconnect power to the range. - Gain access to the back of the ERC (electronic range control, or "clock"). - Unplug the touch pad ribbon connector from the ERC. This will be a flat wire about 1 ½" to 2" wide. - Make sure everything is clear and will not short out when power is turned back on. Replace any covers removed to gain access to the ERC. - Turn the power back on to the range. - Watch for the F-1 and listen for the beep. - If you get the F-1 and beep, replace the ERC. - If after approximately 60 Minutes you do not get the F-1 fault, replace the touch pad. NOTE: Some models incorporate the touch pad and the clock control as one part so F1 = bad clock control. I hope this may help you, but it looks like you may have an expensive repair. Double check your wiring just to be sure.
Jun 18, 2007 | Maytag MGS5770 Gas Kitchen Range
HP P2360AA Keyboard/Mouse Logo
857 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
