Question about Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05C2A
Is there an ambient temperature range outside of which the freezer won't work well? Will it go down to zero degrees?
  • 10,421 Answers
It seem ambient temperature will not affect so much inside temperature since any freezer has good insulation. Normally freezer will go down to below zero degree
Posted on Dec 15, 2010
I have a freezer bosch log/xx model dc125e12raw5r600 tempretureis only -5 is this normal
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The ideal temperature range for a freezer is -2/+2 degrees F. This temperature range can very depending how full the freezer is. If your freezer is jam packed -5 degrees is good. If it is half full, +2 degrees F. is a good setting.
Too high of a setting such as -20 degree F. will cause freezer burn (bone dry your food).
Your compressor will kick in and cycle until it reaches the temperature setting. You can save on your electrical bills based on your evaluation of the necessary temperature setting.
Oct 19, 2014 | Bosch Freezers
Ambient temperature
This is true of all HVAC type systems. The condensor releases heat from the expansion of the coolant. As long as the temperature is lower than the exchanged heat then there is no impact to efficiency.
Mar 07, 2014 | Woods Freezers
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
Oct 27, 2013 | AEG Freezers
I have a woods chest style deep freeze and the lid is very cold on the outside, but the sides are room temperature and the freezer works fine. Why is the lid cold and how can I fix it
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Apr 18, 2012 | Woods Chest Freezer C1501W3
Can a deep freezer be kept in a garage in Minnesota weather (sub zero)
as a general rule, no. Most all refrigeration is designed to be in an ambient of no lower than 60 degrees. Some can make it below that but do seem to work very well. Get me manufacturer, model, and serial numbers and I can go alittle further if you need me to.
Nov 20, 2010 | Freezers
I have a Frigidaire model GLFU206FWA upright freezer. The temperature control won't go above 10 degree F. This causes freezer burn on some foods after a period of time. Is there a way to regulate the...
Good day,
Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F.
Otherwise people could accidentally set the temp too warm and cause a loss of food.
Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
Jun 21, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
The temperature display is reading 0 degrees
Zero degrees F is the normal operating temperature for a freezer. The compressor should not come on until the time is above that.
Apr 26, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My freeer stopped working after the temps dropped
freezers have a range of ambient temperature uses
most are plus 10c to 35c if using some units in garages etc. they just dont work...too cold for the poor things...
Feb 04, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Our Franklin Chef FIM70 keeps freezing up help please
What temperature is the ambient air?
Mine froze up if the ambient temperature was less than 70 degrees F.
Jun 26, 2009 | Franklin Freezer Chef FIM70 Commercial Ice...
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05C2A Logo
164 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
