My daughter has pressed something and my sreen layout has been turned 45 degrees, how do i get t to read from top to bottom again, cara xx
    Problem Solver:
  • 12 Answers
Use cntr and arrow
Posted on Oct 11, 2010
Viking refrigerator drawers - top drawer freezing contents (not bottom drawer). Any ideas?
there must be a air flow blocking. defrost for a day, then start again. make sure the spacing or arrangement inside has gap for the circulation of air flow
Dec 16, 2017 | Viking Refrigerators
I need to rotate my pattern by 45 degrees on my brother pe 770. I've tried going to layout but it only does 180. Any ideas?
Get software such as Embird Design to do it and then export the .PES file and transfer to the machine. Unfortunately the low end machines do not have this capability.
Apr 02, 2013 | Brother PE770 Computerized Sewing Machine
We purchased a Denon v310 to play multi format dvd's and the message we get is wrong region, how do I unlock?
  1. Turn the unit on
  2. Press the OPEN/CLOSE button
  3. Press CLEAR, 1, 4, 7, 0, CLEAR - "TEST MODE" will appear on the display.
  4. Press UP; "00 XX" (XX is a numerical value) will appear on the display. The first two digits are incremented by one, every time you press UP
  5. Press the UP key until you see "12 XX" (default is 24) on the display
  6. Press 2, 3, ENTER
  7. Press UP key again and you will see "13 XX" (default is 23). If it does not say "23", press 2, 3 on the remote and then the ENTER button
  8. Press the UP key again and you will see "14 XX" (default is 01).
  9. Press 0, 0, ENTER
  10. Press RETURN
  11. Press CLEAR twice
  12. Press RETURN ("END" should appear on the display)
  13. Press OPEN/CLOSE
May 10, 2011 | Denon DN-V310 DVD Player
Screen turned sideways
Hi there. Your daughter mus have press on something on the keyboard. Inorder to get the screen back to normal . Try to press and hold the crtl + alt + uparrow key at the same time. This will take your screen back to normal position.
May 31, 2010 | Dell XPS M1210 Notebook
I have a subaru ej20 turbo engine i am changing the head gaskits will be replasing them with steel head gaskits and need two know the tork settings can you help
Information taken from Subaru Impreza workshop manual.
Apply a coat of oil to washer and bolt threads.
First tighten all bolts to 29nm (22ft lbs) in this order.
Looking at head with front of engine on your left hand side
Top Middle
Bottom Middle
Top Left
Bottom Right
Bottom Left
Top Right
After doing this tighten them further to 69nm (51ft lbs) in the same order as above.
Back off (loosen) all bolts 180 degrees in same order as above.
Then back them off again another 180 degrees.
Tighten all bolts in the order above to 29nm (22ft lbs) followed by a further 80 to 90 degrees
Tighten all bolts in order as above a further 40 - 45 degrees
Tighten bolts Top Middle and Bottom Middle another 40 - 45 degrees
Job done.
Sep 15, 2009 | 1995 Subaru Impreza
My Kitchen Aid Supuerba top covection oven will heat to set temp 350-400 then drop over 100 degree's but still read on digital display 350 or 400
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Oct 04, 2008 | KitchenAid Kitchen Ranges
CODE REGION
Turn the player on and open the disc tray. Press [CLEAR] followed by [1][3][6][9] and one of the keys [0]...[8] corresponding to the region you want to set the player for (1 for Region 1, 2 for Region 2 and so on, press 0 for Region 0 or Region Free). Turn the player off then on again for the changes to take effect.
To verify the region code, press [SETUP] followed by [1][3][7][9]. A screen will then pop up with the firmware info and the current region code setting. Using [SETUP][1][3][6][9] did not work for me.
Or
To modify the region, turn on the unit and open the disk tray. Using the remote, press [CLEAR][1][3][6][9][zone code] and cycle power on the unit (not necessary to unplug the unit, simply use the front left <POWER> button. Example: Turn on; open tray; [CLEAR] [1][3][6][9][0]; unit OFF, unit ON and you'll get a zone free DVD player.
To confirm the zone code, turn on DVD player, (unit may or may not have a disc, check that the disc tray is closed, and press [SETUP][1][3][7][9]. You'll have all the firmware information (Version xx.xx.xx.xx SUB-VER xx.xx.xx.xx;
8032 xx.xx.xx.xx; Servo xx.xx.xx.xx; RISC xx.xx.xx.xx; DSP xx.xx.xx.xx; Region Code 0) That's that final "0" that you are looking for!
Mar 17, 2008 | RCA DRC247N DVD Player
Doesn't load DVDs but plays VCDs
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
Mar 03, 2008 | Televison & Video
Cannot reset 2wire 1000hw IP
The fact that you receive an IP starting with 209.154.. could also coming from the fact that the DHCP server inside your 2wire has a problem or that your 2wire changed some setting.
I would like you to open internet explorer and put the following address:
http://gateway.2wire.net/management
If the above address doesn't work, press Start, Run, type cmd and press enter.
At the prompt type    ipconfig /all  and confirm that the Default Gateway has an IP address similar to 172.16.0.1 or something else; if there is no value means that there is no communication with your router and we have to verify the hardware.
If there is an IP address on your Default Gateway, try to ping it by typing  ping xx.xx.xx.xx   change the xx with your Default Gateway IP address.
If you are not getting any reply means that the router doesn't communicate again, if you see some reply means that you can probably access to your router by opening internet explorer and entering the following http://xx.xx.xx.xx  where xx is your Default Gateway address again.
Please let me know up to where you can get some result and then we will continue from there.
Oct 30, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
