Question about Frigidaire ATF6700F Front Load Washer
Error code e47 - Frigidaire ATF6700F Front Load Washer
2 Suggested Answers
  • 3 Answers
SOURCE: Washer has error code E47
I have the same problem with the E47 code. I had the service guy over and he brought a troubleshooting sheet. Basically, you must remove the door switch assembly and check the PTC (the white plug on the door switch assembly). According to the diagnostics sheet, if the switch is open or locked, then it is a doorswitch problem, but if the reading on the switch is ~ 1500 ohms, then its the control panel.
The reading on my PTC was ~ 1400 Ohms (which is close to 1500) so I ordered a new control board. I'll post again when it's re-installed.
Posted on Jan 14, 2009
What is error code e47?
Hey Ervin, thanks for your inquiry!
From the information you have provided your Frigidaire washer is displaying an error code of "E47". An "E47" error code means that the board thinks the door circuit is open in spin. This could be potential issue with the door lock or main control board. A reset could help correct this issue and to perform a reset you would need to disconnect power from it for at least ten minutes. We hope this information is helpful to some degree. -Matt
Jan 23, 2016 | Frigidaire Washing Machines
What corrective action for e47 code?
Hello. I need the model number to help you accurately but I'll assume you have a Frigidaire washer. If so, then the E47 code is telling you that the main board thinks the door is open on spin. Go to this web address and it will tell you how to check the electric door lock mech. http://forum.partsdr.com/showthread.php?1-Frigidaire-Washer-E47-Error-Code. If you *don't* have a Frigidaire unit, please post a comment with the brand/model number so I can give you exact information. Thanks!
Sep 11, 2015 | Washing Machines
WHY DO I GET ERROR E47 WHEN THE SPIN CYCLE IS SUPPOSED TO START?
Good Afternoon Friend,
I understand you are receiving an E47 when the spin cycle is supposed to start, on your Frigidaire Affinity washer, model# ATF7000E. The E47 code states that the control board of you appliance thinks that the door is open. This could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Once power is restored, start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Affinity ATF7000E Front Load...
LTF2940ES E47 code repair
The E47 error code is usually an indication of a failed door lock/latch. To verify this, you will need to ohm out the PTC on the door lock. If the door lock does not ohm out correctly, then it will need to be replaced.
How to test the door latch on your washer
Nov 18, 2011 | Frigidaire ATF6000ES Front Load Washer
E47
go to this website "http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm" and read through the page and try find your hidden error code it will be more specific with your problem also that type of error has been added to microsofts warranty plan so you may be able to get it under warranty
Sep 18, 2009 | Microsoft Xbox 360 Console
No spin
E47 and E48 are door lock error codes, also check the wire harness connections too.
Oct 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
E47 error
Go to www.frigidaire.com
>Customer Service
>Product manuals>your model number
>right click to download tech data, (which will give a repairmans info )and any other manuals you think you might need.
These are in PDF format. so if you don;t have adobe acrobat, you need to go to www.adobe.com/acrobat and download the free software so you can read the manuals. Once you have the manuals you can click on the little icon which is a stack of pages on the left column to go through the infomation,. Good Luck.
Jun 28, 2008 | Frigidaire ATF6000ES Front Load Washer
No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Feb 22, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6700F Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
