Question about HP w19e 19" Monitor
My hp w19e will turn on and the desktop screen will also come on then after 3 or 4 seconds the screen goes black
  • 11,361 Answers
It can be many things that causes the problem. You need to inspect the caps, voltages, solder joints.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 10, 2010
Hp 2509m picture stays on for a few seconds then goes to Black
I had the same issue, It actually turned out to be the backlights themselves. An easy way to check this is by shining a bright light on the screen while its on. you should be able to see the picture.
Feb 20, 2012 | HP 2509m 25 in. TV
My monitor is turned on displays then goes black. Off and on same thing happen after a few seconds. I replaced most capacitors 470uf, but i didn't replace a 22uf 50v. and a 100uf 450V. after...
Hello Richard Strong,
Welcome, and thank you for using FixYa!
To answer your question: I believe you need to replace the two capacitors that you skipped.
Then touch up every soldier joint on the power supply board. Lastly, I would look for the replacement part for the +5V and -5V transistors on the power supply board. They may need replaced as well. If you have an Ocilliscope you may be able to test out where the power is failing.
Have a great day!
Oct 28, 2011 | Computers & Internet
Fix my desktop monitor HP w19e goes black after a few seconds. the screen displays then goes black. I changed most capacitors 470uf. I didn't change two other capacitors A 22uf 50V and 100uf 450V. I...
w19e (2006) 12 year old relic, legacy monitors, sure. CCLF junk.''
(1440 x 900). (not over this resolution)!\
HP does not sell parts this old !!!
get a new monitor, fixing cost more than new and for sure refurbs at $50. (unless labor is free, ? even then too much)
first off its too old , the CCFL are no good now.
"back lamps"
are you going to replace those. some are near impossible to remove and not wreck the LCD array.!
1: turn off power saver and timer in the menu OSD yet.
that is first first. (the book shows this feature missing) yours.
2: then does the flash light trick show there is data there, omg
the data is there, the CCFL lamps are dead. or the inverter.
see your boards here, see the brown one bottom 2 cream connectors. those are the 2x 500vdc power jacks to the CCFL tubes
if that is dead, ebay has it for 15 bucks. (what deal no)
but if the tubes are bad good luck there.
the first test would be the flash light test
w19e-ysl4vcr25ekwcyxfuustmq5b-5-0.jpg why own such a monitor if the ccfls can not be removed.
I avoid them all an buy 2010 and newer with LED backlamps.
flashlight test
http://www.pcdied.com/monitors.html#flashlighttest
Jan 13, 2018 | HP Computers & Internet
I turn on my computer and i get a box that sais adjust screen and gives a resolution and then goes black, nothing else happens no beeps no booting noise. F10 pops up another screen for 2 seconds then goes...
try to boot in safe mode.To do that.
restart your computer continues press F8 key it will show the option select safe mode
and you can work with that and change the reasoluition and restart the computer work with normal mode..
Nov 13, 2010 | HP Pavilion A610n (PC106A#ABA) PC Desktop
I reformated my computer and had it on hibernate and went to sleep.I woke up and now the screen on my desktop pc just flashes about every 3-4 seconds.the screen stays black the flashes with white streaks...
Hi there
i read your report. OK go to your power options and turn off your hibernate and restart your computer.allot of times after you have reformatted your hard driver. the hibernation doesn't work correctly. Try this tip and let me know how it goes. Thank you for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | HP Pavilion F1703 17" LCD Monitor
My screen goes black after startup
Try a different monitor, I am sure this sounds overly simplistic to you but, I have seen in my customers have just that, a bad monitor.
If another monitor does the same thing, then you should try another video card. If the video in on the motherboard, there should be a AGP, PCI-e, or an empty PCI slot to put a video card in.
Aug 08, 2009 | HP Computers & Internet
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
May 26, 2008 | HP w19 19" LCD Monitor
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP w19e 19" Monitor Logo
208 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
