Question about Salton Melitta MEK17W Electric Kettle
Melitta Express Kettle won't heat water any longer. Any suggestions? It still lights up when set on the base and the lever is pressed down.
I need a spout filter, part # 31036 for my express kettle MEK 17W
  1. New: Melitta Kettle Parts - buycheapr.com‎
    Admelitta-kettle-parts.buycheapr.com/‎Melitta coffee maker parts: BuyCheapr.com
  2. Melitta Kettle Parts - bizrate.com‎
    Adwww.bizrate.com/Melitta+Kettle+PartsVacuums
  3. Microwave Ovens
  4. Coffee Makers
  5. Heaters
  6. Melitta Cordless Kettle - Amazon.com‎
    Adwww.amazon.com/kitchen‎rating for amazon.com
    Up to 50% off Melitta cordless kettle Free Shipping on Qualified Orders.
    Ratings:Website 10/10 - Shipping 10/10 - Selection 10/10
Search Results
    Need replacement filter for Melitta Express Cordless Kettle ...
    www.fixya.com/support/t6685355-need_replacement_filter_melitta
    Nov 3, 2010 - Need replacement filter for Melitta Express Cordless Kettle Model MEK17W - Salton Melitta MEK17W Electric Kettle question. ... Question about SaltonMelitta MEK17W Electric Kettle ... Video; Photos; Link; Replacement Parts.
Jan 06, 2016 | Kitchen Appliances - Others
Kettle not heating up water but electricity is reaching the kettle
How to fix an electric kettle part 1 - YouTube
? 4:51
https://www.youtube.com/watch?v=P4dcq5p0FyU
Apr 15, 2013 - Uploaded by Anthony Findlay
how to troubleshoot and fix an electric kettle. ... I am using akettle had small problem the switch was not working so I have tried to fix it but I am ...
HOW TO REPAIR ELECTRIC KETTLE - Fix Your Electronics ...
electronicsolutn.blogspot.com/2012/10/how-to-repair-electric-kettles.html
Oct 25, 2012 - Electric Kettle is a kitchen appliance that contains a heating properties used for boiling water, cook food etc. It is made up of a metal or plastic ...
electric kettle light but not heating Questions & Answers - Fixya
Dec 08, 2015 | Hamilton Beach 40996 Programmable 1.7...
I have a Cuisinart CPK17 won't heat water and all the blue lights are flashing
I had the same issue with all lights blinking, but nothing else working (buttons would not respond or beep). I took the base off and used a small pair of pliers to bend the contact as Scott Cowen mentioned. Worked like a charm.
Jan 07, 2013 | Cuisinart CPK17 Electric Kettle
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
I need to buy filters for the spout. Where in the San Jose area are they available?? Melitta MEK 17W electric kettle.
If you can no longer find this scale filter online or from the manufacturer, then you can still repair your original one and make it better than new! This fix has worked perfectly on my MEK17W kettle and it turns off properly when the water boils.
Buy a piece of 3"x3" 100 mesh (150 micron, must be stainless) on Ebay - under $3 inc shipping. Carefully cut the old plastic mesh out of the original filter frame with an exacto blade and very lightly sandpaper the triangular face of the plastic frame that faces into the kettle. Then temporarily hold the stainless mesh to this inside face of the filter frame with a couple of clothes pegs and use a pencil to mark the
triangular outline of the mesh so that it will fit flush against the plastic and also be no wider than the frame. Carefully cut the triangle of mesh to size with scissors. Thoroughly mix up a small portion of 5-minute 2-part epoxy glue (Loctite or JBWeld) with a thin wooden coffee stir stick and apply just a smear of glue to the frame. As soon as the glue starts to get tacky, gently fit the mesh to the frame and clip it there lightly with 5 plastic clothes pegs, 2 on each side and 1 at the bottom. To ensure their release, you can first wipe the pegs (where they pinch together) with the faintest skim of Vaseline or sewing oil. Let the assembly set for 24 hours and then carefully ease off the pegs. You will now have a filter that will last longer than the kettle.
Oct 09, 2011 | Salton Melitta MEK17W Electric Kettle
Hi, your filters can be bought from amazon. here: Amazon com melitta filters I hope this was helpful. cheers
Nov 03, 2010 | Salton Melitta MEK17W Electric Kettle
Melitta MEK17W Electric Kettle: The little filter that fits into the spout disinte...
Call 1-800-233-9054 and ask Salton/Toastmaster for part number 31036 for the MEK17W kettle. You may as well buy 2.
When this scale filter in the spout of a Melitta MEK17W or Toastmaster TEK17W (identical kettles) gets torn the kettle does not hold in enough steam to trigger the auto off switch. Same thing happens if you do not fully close the kettle lid. With a new and spare scale filter you will get way more life out of this inexpensive and handy kettle.
If you still have the old original filter, here is an inexpensive and permanent repair option using stainless mesh:
www.fixya.com/answer/answerpageslideview.aspx?thid=10641367&ctg=163&lst=1#answer-section
May 06, 2010 | Salton Melitta MEK17W Electric Kettle
I need directions for the TFal Vitesse cordless electric kettle. 7845162 Thanks
Fill with clean water to fill line. Have base plugged in. Place kettle on base and press down button on top of handle. Water should boil quickly and turn off automatically when done.
Mar 09, 2009 | Tefal 78451 Vitesse Cordless Electric...
Salton Melitta MEK17W Electric Kettle Logo
116 people viewed this question
Top Salton Kitchen Appliances - Others Experts
Gareth Cockram
Gareth Cockram
Jerry Greenberg
Jerry Greenberg
Robert Plante
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
