Question about Friendly Robotics RoboMower 21Inch Automatic Cordless Electric Lawn Mower and Docking Station
My rl500 robomower will not charge when pluged in-just a row of dashes desplay on and off and a sound of a clunck or a click is heard.
  • 11,896 Answers
Sound like a problem with the power inverter board. It may have swollen or blown or leaky capacitors which control the current flow through the board. This board is attached to where the plugin cord attaches too.
Posted on Oct 10, 2010
  • stintenalle Jul 05, 2011
    i have the same problem, looked at the board and it seemed fine to me. i have never used the mower before, and i live in norway. using an AC converter so i thought maybe something was wrong with that, wrong voltage or something. should i perhaps try to change that board or is it easily fixed if some electrician looks at it?
It's just the battery is too low to charge. If battery goes below 21v it won't charge.
Either plug it in leaving it to try and charge for a few hours. Then unplug it remove battery. Leave 24hrs and try again
Worst case split the two batteries and charge them using car charger. Once believed to be charged. Test the voltage. If less than 10v on either battery. Then you need new batteries.
Posted on Jul 21, 2015
How to diagnose vehicle will not start. Turn key and makes a click sound heard from dash or under hood.
Sounds like possible low battery. Could also be bad connection in starter switch, but test the battery first. Batteries do get old and don't hold charge. Check charging system, too.
Sep 22, 2015 | Cars & Trucks
Juki LU-562 I heard a clunck and the bottom walking foot doesn't work right .
Hello, I have a different model Juki but it sounds to me that your safety clutch has been tripped. The safety clutch functions when an excessive load is applied to the hook or the other components during sewing. At this time, the hook will not rotate even if turning the handwheel. When the safety clutch has functioned, remove the cause and reset the safety clutch by pressing and holding the push button on the top surface of the machine bed, while strongly turning the handwheel in the reverse direction of rotation. The resetting procedure is completed when the handwheel clicks.
Jan 07, 2014 | Juki Sewing Machines
Robomower gives 'no signal' and docking station gives only red signal when pushing button. No fault on cable when measuring with multimeter and problem identical when replacing green cable with...
I found one of the weak points of the older robomow to be the little green L shaped connector that joins the boundary wire to the signal unit/docking station. The older ones were prone to rusting inside. I replaced mine and all was well again.
Sep 10, 2011 | Friendly Robotics RoboMower 21Inch...
My r reg xsara 1.9d has a loud clunck when driven over a bump or hole in the road, its only heard from the rear left. thanks for your help
Sounds like a shock absorber is heavily worn, or something may be loose.
Check the exhaust mountings (the rubber bands that hold it on!) to make sure that they are all there, and fitted correctly.
Jul 23, 2011 | Computers & Internet
Washer was running, Heard "clunck: sound. Washer turns on, but will not advance to any cycle. Just hear a "humming" sound
Welcome to FixYa.
Based on your description I suspect the belt may have come off or broke.
If you remove the back you should see something like this below...just an example and not necessarily your model...
Check to insure the pulley is tight as well.
Let me know what you find, good luck.
Macmarkus :)
Sep 02, 2010 | Kenmore HE2 Plus Front Load Washer
Robomower doesn't charge battery
Check the connection of the three yellow cables underneath the remote control. Because of moving the remote control a lot (flip up and down), the cables might be broken (although still connected but the copper might be broken!) Check if there is a voltage on the two connectors in the battery compartment (take out the battery when charging and measure).
Aug 16, 2009 | Robomower - Rl 850 - Stc 80850
I broke my zr2 4wd! i was on the gas @ 30mph an heard a clunck?
check your u joints first if not that then you did blow your transfer case.
Mar 02, 2009 | Chevrolet S 10 Cars & Trucks
Unknown calls
that sounds like it is coming from the other end meaning from your friends' phone....i have never heard of a phone making incoming calls private or unknown.......speak to your mobile provider about that.
Dec 25, 2007 | Motorola Mobility RAZR V3
Friendly Robotics RoboMower 21Inch Automatic Cordless Electric Lawn Mower and Docking Station Logo
550 people viewed this question
Top Friendly Robotics Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Friendly Robotics Garden Expert? Answer questions, earn points and help others
