Question about HP (0950-3952) (09503952) 425-Watt Power Supply
I HAVE A HP PAVILION SLIMLINE (S5310F) AND WANT TO PUT IN A VIDRO CARD, SO I NEED A LARGER POWER SUPPLY. HOW DOO I DO THAT?
    Novelist:
  • 206 Answers
Replacing the Power Supply DEPENDING on the power needed? you might have to settle for a slower, weaker performing video card. Make sure you check the video card power supply specs needed.
Chances are you will max WATT at about 300WATTs less then what you'd need to power a gaming video card. OR you could do as I'd do.
Remove everything and place it all in a standard tower case - install a 650WATT power supply in to the new mid/full size case and BAM solution found.. Have fun and a great day to ya.
Posted on May 13, 2014
3 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: I have a burned out Bestec ATX-250-12z power supply
Hello there:
That is a pretty good choice for a replacement you just have to make sure that it will fit exactly like the old one did and that the cables are exact and have the same hookups as the old ones do ok but you should be fine from there ok
Hope this is very helpful for you
Best regards michael
Posted on Jan 10, 2010
Dumaine
  • 112 Answers
SOURCE: I need Power Supply unit
You dont have to replace it with the exact one...just shop around and find a 300 watt ATX power supply. You can find a few good deals around the internet. (tigerdirect.com...newegg.com....etc)
Posted on Jul 30, 2011
I put new power supply in my hp pavilion slimline but still wot turn on
the first thing you should do if it don't start is unplug everything (memory, cards - the lot) from the mobo apart from the power supply and turn it on.
if you get nothing, it's either the power supply or the mobo. check the power supply actually works, if not that then it's mobo.
if you get beeps, plug things in one at a time, when you arrive at the condition you started with, that's the bit that's wrong.
Mar 15, 2015 | HP Pavilion Slimline s5-1414 Core i3-2130...
What are power supply specs for hp Slimline s5200z
HP say only that the psu is rated at 220W
(http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c01911671&lc=en&jumpid=reg_r1002_usen_c-001_title_r0002#N121)
I
I rather think the specs are the same as this one and that themodel number is the model in yours
http://www.ebay.co.uk/itm/HP-Pavilion-SlimLine-s5000-220W-PSU-Power-Supply-HP-P-N-504965-001-PC8044-/221182783648
HP Pavilion SlimLine s5000 220W PSU Power Supply HP P/N: 504965-001 taken from computer when hard drive died in full working order has been cleaned ready to be reinstalled Model:PC8044 HP P/N:504965-001 AC INPUT:100-240V, 50/60HZ, 6A DC OUTPUT: +3.3V 16A +5.08V 15A TOTAL110W MAX +12.0V 16A TOTAL210W MAX -12.0V 0.3A +5.08Vsb 2.0A
However to certain take the panel off yours and have a look at yours
The are plenty of higher power replacements available search the internet for eg "what psu is in a hp s5200z"
20.December.2014
May 20, 2014 | HP Computers & Internet
Hp dvd lightscribe
download the driver ( software) update . and install it from HP . go
www8.hp.com
God bless you
Oct 10, 2012 | HP Pavilion Slimline s5310f PC Desktop
Computer is dead. hp slimline. anything I can do to jump start it.
A Totally dead PC can usually mean that the the power supply has quit.
If you've ever replaced a power supply
in a desktop (or Slimline) PC, it takes about an hour, but if its your first time, take your time, and
allocate half a day.
3 vital tips:
(1) use proper anti-static techniques, just in case you might happen to touch the motherboard or a card in the option card backplane.
(2) get (or order online) a replacement power supply with a wattage rating equal to or greater than the wattage rating of power supply being replaced - so you can be sure that the new power supply will handle the load offered by your system.
(3) always keep the power supply module from old PCs - they can come in handy when one dies in a PC that you really want to run (even though the older ones dont have the SATA connectors).
Sep 10, 2011 | HP Hewlett Packard Pavilion Slimline...
Hi. I was buying HP Pavilion slimline 5310sc and want to put a new graphic card in it, to play games. What cards would fit best? Bjarki
Graphics cards are of many companies. For my opinion, Ge-force and N-vidia graphics cards are best. 512 mb graphics cards are well for playing games. As your need of gaming, buy high capacity graphics card as 1 gb or 2 gb.
Jul 30, 2010 | HP Pavilion Slimline s5310f PC Desktop
Upgradevidio card in a s3120n Hp slimeline to 9600 GT low profile, do i need anew pwer supple(160 w Presently).and what kind is recomendited (must be Quite)
You are not the only one having this problem with the HP slimline systems. The facts are HP doesn't make a 300watt power supply for your slimline. To make things worse HP uses a special small 24-pin main power connector. Power supply, Slimline dimensions are:
3.25" Wide X 1 5/8" Tall X 6" Deep. The highest PS I could find that will fit in your case is 270watts. Also made by HP;
http://www.atxpowersupplies.com/270-watt-HP-slimline-power-supply-FSP270-60LE-SL.php
This should work for you. The only other option would be to replace your slimline case with a standard ATA size case. Than your options for power supplies is endless.
Cheers!
Mike
Oct 03, 2009 | Computers & Internet
Change HP Pavilion Slimline s7520n Video Card?
The on-board RadeonXpress 200M graphics is a dog. It offloads a lot of work to your cpu, and shares system memory which ties up the bus and detracts from the memory available to the OS.
The s7520 suffers from thermal problems due to it's size and poor ventilation. It also has a very limted power supply. Therefore, your choices are also limited. If you could score Radeon X600 or X1300 with 128MB for cheap somewhere it would be a worthwhile upgrade. It does need to be PCI (not PCI-E) and half-height (low profile).
Jul 23, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
HP (0950-3952) (09503952) 425-Watt Power Supply Logo
87 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
