Question about ViewSonic VX2235wm LCD Monitor
My monitor Hello, I am trying to install drivers to my viewsonic monitor. A window pops up telling me to install them manually by clicking on 'monitor' in the device manager. However, there is no "monitor" heading in my device manager. What do I do?
  • 3 Answers
The "Properties" button for the Monitor tab is greyed out. Can't install drivers. Also in "Device Drivers" there is no monitor listed.
Posted on Sep 07, 2009
    Brigadier General:
  • 6,966 Answers
Try inside your Display Properties. Settings tab, Advanced button, Monitor tab, Properties button, Driver tab, Update driver and follow on screen instructions. Eventually it would ask you where the drivers are located (CD drive?).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 31, 2008
Monitor driver for window 7 64-bit
If Windows Device Manager doesn't deliver try VIEWSONIC.COM. You can find drivers, firmware and manuals there.
Oct 10, 2014 | ViewSonic VE710b 17" Flat Panel LCD...
have you tried if the monitor on another computer?
otherwise it must be bad configuration.. try right clicking on the desktop, click on properties, configuration, and then you will see 2 monitors.. if you go in advanced you can also play there to tell wich one will be the firts monitor..
you could also reinstall the video drivers of your laptop and there will appear an icon on the task bar so you can configure how will the screen be working..
Dec 19, 2007 | ViewSonic VX910 19" LCD Monitor
Removing a pop up window on center of viewsonic monitor 2231ww screen
The pop-up window come due to any software program. This is not related to the monitor. So you have to check the software which causes this.
Generally pop-up window comes from internet browser. You may change the setting of your internet browser to "Blobk POP-ups". If you tell me what browser you are using i can send you the instruction.
If the pop-up is coming from any other program then there is no general instruction.
One more thing you may try. Do a virus clean. That will solve pop-ups due to virus.
Jan 16, 2011 | ViewSonic VX2233WM Monitor
The movie is running slow on full screen
check if the display driver is installed or not in your computer, here is the step to check the display driver is installed or not,
step 1. go to start and select control panel.
step 2. double click on system.
step 3. after this a window pop up select hardware.
step 4. click the device manager and after this another window pop up.
step 5. in this window you can display adapter on 4th row.
if you cant see this display adapter row so you can see something with ? sign in other rows and you can see vga adapter or display adapter down there. if you see ? sign that mean this driver is not loaded you need to load the driver for your display driver. there is no problem in your LCD monitor.
Thank you for using Fixya
Jun 10, 2010 | ViewSonic VX2240W-2 LCD Monitor
View sonic VX900 how do I install monitor
Home ViewSonic Monitor VX900. Download ViewSonic Monitor Driver ... Install Windows Driver How to install a Windows Driver properly and avoid possible problems?
Dec 04, 2009 | ViewSonic VX900 19" Flat Panel LCD Monitor
Can't set 1680x1050 resolution on viewsonic monitor
I found the solution for my problem.
Initially I thought it's a monitor problem and was trying to find the drivers for it.
The problems is not with my monitor but with the video adapter I use.
My video adapter has a intel chipset (Mobile Intel(R) 965 Express Chipset Family). Apparently the driver that I was using was quite old.
The only thing I had to do is:
1. Download the latest video adapter driver
2. Uninstall the current video adapter driver
3. Restart the system (Windows XP)
4. Install the new driver.
5. Restart the system.
May 19, 2009 | ViewSonic VA2026w Monitor
Viewsonic monitor not detected after service
If you are running DVI-D(the white connector) then it isn't getting a digital handshake. If you have inspected the connection between the 2 and make sure there is no bent pins inside the connector that it mates with. If you have another computer, try to connect to that one.
Open windows start menu, right click on my computer, then choose properties. Next choose Hardware, then Device manager. Once there, double click on display adapters to see if installed correctly. If good, click Monitors. If good, then your video card driver must need reinstall or update as usual. Also do you have the correct driver for you monitor? How does it react when you uninstall the monitor driver(can you select 32bit and higher resolution in default drivers?
If none of this works, I would suspect that the replaced component failed due to static or faulty components within the electronics.
Is there any other changes to the PC (new video card, updated Directx9.0?)
Hope this helps and let me know if I can be of anymore assistance?
Aug 20, 2008 | ViewSonic Computers & Internet
Viewsonic monitor ,no video
Black borders on side of screen. Video driver issue or no video driver installed; Resolution was changed and monitor could not adjust. Monitor needs to be manually adjusted.
Getting into Windows Safe Mode For information on how to setup your video card resolution, see document CH000190 ... This is the most basic Safe Mode option and has no additional support.
Good Luck, Please dont for get to Vote/Thank you.
My monitor is not allowing me to display a resolution
If you have the origional CD that came with the monitor, use that to re-install the drivers for the monitor back onto the pc. Then go to viewsonic and look for updates. Do a "system restore" and put the system back to the condition prior to doing all of this. I will re store your files to what they were but "system restore" will not roll back "windows updates". This will tell you if it is something you did or windows did.
Aug 16, 2007 | ViewSonic VA1703wb Monitor
Monitor problems
You need to change down the res. to a minor mode. i.e. 800x600 low quality. For Windows enter the protected mode - i.e. after POST (bootup) press F8 then enter with your account, or the administrator. Right-click anywhere on the empty desktop and enter "Properties" menu. Turn the screen resolution down in there (i.e. 800x600); also, check whether your current monitor is recognized by model in there. Re-adjust to a suitable working resolution. If all fails, you can also de-install the video card driver in admin protected mode to go back to basics. Of course You need to re-install it again afterwards when in your original Windows.
Jan 28, 2007 | ViewSonic VP191b 19" LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
101 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
