I have a Nordyne/Intertherm electric furnace #E2EH-012 in a mfg home I just moved into. The Handy Man removed a 16 x 20 x 1 filter (very dirty) from "somewhere". I'm not sure where a replacement filter should go??? An outside "pump" was installed before I moved in (several years ago). I don't know if the inside unit was altered??? There are two covers for the inside unit. The one at the top has the fin openings. The bottom cover is solid and has "Ventilate" above an "auto/fan-on" switch with "Intertherm" just below. I sure would appreciate any help with this I could get. Sorry for the long, drawn out question. Please help me!!!! Thanks!!!!
  • Brian Niten Oct 10, 2010
    You want the air to be filtered before it goes through the a/c coil. Figure out which way the air is moving then start looking from there. Some units may have a small door that opens and you slide the filter in. Others may not have a door for the filter at all.
  • Vicky Oct 25, 2010
    Thank you for your help!
  • 6,674 Answers
The filter will go in to the backside (inside) of the cover with fins in it. There is a 1" (approx) bend (lip) there to hold filter in against backside of cover, in front of air vents. You may have to bend it slightly to get it in there but it will eventually fit in there snug. Incoming air will then be filtered as it is drawn through that filter, into blower area.
As far as fan switch goes, "auto mode" will be used when furnace is on, and fan will come on & off as necessary to dissipate heat as required. "Ventilate", should be basically same as "On", where the fan comes on to circulate the air throughout the home, just for airflow, and you control it manually.
So, when using furnace, have fan in "auto Mode".
Posted on Oct 11, 2010
  • Mike Butler
    Mike Butler Oct 25, 2010
    Your filters should have an arrow on end or somewhere, to show flow direction. When inserted on back side of the cover with fins, the arrow(s) should be pointing toward furnace.
I HAVE A INTERTHERM NORDYNE E2EH-015H EVERYTHING WORKS GREAT BUT IS REALLY LOAD WHEN IT IS ON
It is probably a refrigerant copper line vibrating and touching the exterior cabinet or interior frame. It would have to be taken apart to move the copper line out of the way by a very small amount.
May 12, 2014 | Haier HWR12XCB Air conditioner
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
I have a mobile home furnace and I have no manual. I think it needs a filter but I can't tell where it is supposed to go or what kind of filter I should use. Is there a diagram available I could look at?...
The filter is usually located in the door or front cover. If you have trouble finding material you can measure opening and get one or more 1 inch thick high effiency filter. You can set these filters on their sides or upright,it really does't matter as long as you have direction of air flow going the right way. Arrows pointing into blower compartment. I have taken two or more filters and duct taped them together to get the right size. Not pretty, but it works.Hope this helps. Thanks
Nov 14, 2010 | Intertherm Heating & Cooling
I have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Mar 17, 2009 | Heating & Cooling
Bad sequencer or fan relay?
does ANYTHING come on when set to heat?
Feb 28, 2009 | Heating & Cooling
I think I have the wrong air filter in electric furnace
Measure the width and length, then buy a filter that size.1" is correct for thickness.
The arrow points into the return. Not into the room.
Feb 18, 2009 | Intertherm P3RA-048K Air Conditioner
Wiring NO, NC relay on Nordyne furnace
NORDYNE , GOODMAN, AND NUTONE ARE ALL BUILT BY SAME MFG SO IF YOU TRY ALL THESE MAYBE YOU CAN FIND THE HELP YOU NEED
Jan 12, 2009 | Electric Circuit Breaker Kit for Furnace
We have a Intertherm Nordyne heater/airconditioner. New, we just moved into a mfg home. The air is really loud, is there a fix for this. Someone suggested we get a different squirrel cage...
Theres all kind of answers.. close off the return grill and re route the return air system, get anouther unit, Have the realator to fix this problem or give you an adjustment, and you do it your self, ask a reputable ac man..ect, ect,,!
Sep 06, 2008 | Heating & Cooling
Heating & Cooling Logo
335 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
