Question about Ariens 21 In Classic Walk Behind Push Lawn Mower ()
Ariens A173K22 self-propelled. Fill up before starting, Do not overfill won't start, air filter soaked and engine flooded. Remove filter and will grudgingly start. Ok after that. Why is engine flooding?
  • Ariens Master
  • 7,482 Answers
Your engine is flooding because you probably have some debris under the inlet float needle valve causing the carburetor to flood as you described.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Oil leak on deck of Lawn Mower
Because you mentioned the smoke and hard to start it could be that the engine is flooding or overfilled. Check for fuel in the crankcase. Be sure cranckcase is not overfilled. An engine with too much oil will force excess oil out somewhere. If the mower has been turned on its side lately it could have put oil in places that it should not be and its trying to burn off this oil. Be sure your air filter is not saturated with oil or fuel.
If all that checks out we will look for oil leaks.
As far as oil leaks go the three most likely places for your engine to leak are from the head gasket, dipstick tube seal, or the sump gasket.
Check for proper torque on the head bolts ( 125 inch pounds). Headbolts can come loose over time. After that check that the seal at the bottom of the dipstick tube is in good shape and a tight fit. This seal usually leaks when the engine is running because at rest the oil level is just below this seal. Lastly, if everything else checks out then the sump gasket is leaking. To replace the sump gasket drain oil from motor and remove air filter. remove blade and self propel belt. remove engine stop cable. remove the three motor mount bolts from under deck and remove motor. place on work bench upside down. some fuel may run out carb or tank cap. remove sump bolts from bottom of motor and remove sump. Do not remove governor gear or cam gear from cranckcase. At this time it will be obvious where the gasket has failed. Remove old gasket. It may need to be scraped off. Take care to keep material from going into crankcase and clean out any that does fall in. install new gasket and torque sump to proper specs and reassemble.
Jul 20, 2014 | Briggs & Stratton Garden
How can I get a airfilter for a Ariens model 911077
Generally you can get away with a different brand that shares the component. Just take in the old one to compare when you purchase. They need to be the same size.
Jul 19, 2014 | Filter Queen Defender Air Purifier
Model A173K22 Primer Where?
What? !O_O!
Oh,.....................I was going to say, I don't remember any laptops coming with a priming feature, lol!
In answer to your question there is no priming feature, for an Ariens walk behind gas lawnmower, model A173K22,
Page 9,
http://www.managemylife.com/mmh/owner_manuals/134166/ARIENS-Walk-Behind-Lawnmower-Gas-1011731L
Regards,
joecoolvette
Aug 28, 2012 | Computers & Internet
Mower starts and runs but has no power acts like its flooding it burns a lot more gas can barley pull it self
Sounds like maybe the choke is stuck closed. If you remove the air filter the choke is the first butterfly valve you can see. The throttle looks similar but is a inch or so deeper into the carb, and you can't see that unless the choke is open. Try removing the air filter and starting the mower. It might run just a little better without the air filter since it will get a bit more air, but if the choke is stuck it still won't run right. But you will be able to see if that's the problem right off. If it runs great without the air filter, and the choke is not stuck, then the problem is a clogged air filter and you need to replace it. Good luck, Al K
Jul 26, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
Snapper rider gas flooded engine wont start?
Why did it flood? That problem may need to be delt with. But for now remove plug, crank over to clear cylnder, Replace or clean the plug making sure it is clean and dry. Try to start.
Oct 06, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a Toro 1984-85 self propelled pull start lawn mower and I can get the fuel and air mixture just right it won?t stay started, it runs great but gets flooded now (I think), does anyone have the fix-it...
If the mower floods, it may be a float problem, if you have a carb with a float. New fuels can destroy older floats, dirt and gum can keep them from closing off the fuel supply. If you are comfortable taking your carb apart I would start there.
You will need the engine make and ID to get a manual.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
Wont start and mixture of oil and gasoline coming out of air filter
Remove the air filter and observe which carburetor is flooding into the cleaner. When you have found the problem carb, remove the float bowl and clean the float needle and seat. The oil is probably arriving from the crankcase vent and may be due to overfill of oil, or a large amount of 'blowby' from worn rings in the cylinders. You may have to replace the air filter if it is soaked with oil and fuel. Hope this gets you running.
Dec 16, 2009 | 1981 Yamaha XS 400 Special
Lawnmower wont start
your carbeurator is gummed up. a common problem after the lack of use in the winter season. Since you havve a new plug you are partway home. Empty out any old fuel and put in new fuel which you buy now at the gas station. Then buy a can of carbeurator cleaner. Remove the air filter. Look and see if it is dirty, if it is replace it also. Spray two short ssquirts of carbeurator cleaner into the air intake opening exposed while the air filter is removed.
Pull the cord and try to start the engine. Even if it won't start you will be drawing the cleaner into the carb. so it can start to dissolve the problem gummy deposits. Wait half hour and repeat the spray and the attempt to start. If this fails after four attempts you will probably have to remove the carb. and soak it in carb. cleaner for three hours to dissolve the gum.
May 23, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Ariens 21 In Classic Walk Behind Push Lawn Mower () Logo
1,296 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
