Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Sim card installastion
How do I install the sim card?
    President:
  • 1,738 Answers
1) Remove the back cover
2) Remove the battery
3) Look to the bottom of the battery compartment and find SIM card slot. The slot will be located between the silver metal and black plastic edge. Slide SIM card into this slot with the notch on the SIM to your bottom left. Slide in until it is flush with the edge of the black plastic.
4) Install battery
Replace rear cover.
Posted on May 31, 2008
  • J. Van
    J. Van May 31, 2008
    If your phone is CDMA model (Sprint, Verizon) it will not have a SIM Slot. An easy way to tell is if your KRZR K1 has the 3 lights on the front cover for media control it is a CDMA phone. If it does not have the three media lights it is a GSM phone and will have a SIM slot.
Why does phone display 'install SIM card'?
Just to be sure, remove the SIM card and reinsert it to be sure it is fully seated.
Dec 28, 2015 | Cell Phones
How to install sim card
FROM THE OWNERS MANUAL:
Installing the SIM Card
If your SIM card was not preinstalled, you must install the SIM card before you can use iPhone.
Install the SIM card:
1 Insert the end of the SIM eject tool into the hole on the SIM tray.
Press firmly and push it straight in until the tray pops out. If you don't have a SIM eject
tool, you can use the end of a paper clip.
2 Pull out the SIM tray and place the SIM card in the tray.
The angled corner of the SIM ensures that the card fits only the correct way in the tray.
3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card
in iPhone.
May 19, 2012 | Apple iPhone Smartphone
Were do i put the sim card i have a nokia 6111
Hello fridge,
i have some tips on how to install sim card on your cellphone:
Install SIM card
1. Make sure that the cover of the connector
panel is closed.
2. Slide the phone open.
3. Open the SIM card compartment (1) on
the back of the slide
4. Slide the metal SIM card holder towards
the compartment lid to release it (2).
5. Open the SIM card holder.
6. Insert the SIM card in the holder as shown (cut corner at
the upper right).
7. Close the SIM card holder, and press it down slightly.
8. To lock the SIM card holder, slide it away from the
compartment lid (1).
9. Close the SIM card compartment (2).
hope this helps :D
Apr 24, 2011 | Nokia 6111 Cellular Phone
I put my old sim card in my new phone then I got my old phone back working and put the new sim card into my a107 phone and it read sim crash
Try to reinstall you sim card.
If this does not work, install you sim card back into the new phone.
If the sim card works in your new phone.
The sim card is not defective.
Your a107 may not be working correctly.
Jan 18, 2011 | Cell Phones
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
I have brought a china mobile CITYCALL U800+ from DUBAI TO MUMBAI now i am facing problem invalid sim,i am a vodafone user
Were you using this handset in Dubai or is this the first time? "Invalid sim" has two main issues, 1. sim lock, 2. sim connector problem.
First, open the battery cover, remove the sim card (if it's inside the battery compartment) and clean the metal contacts of the sim connector using a soft brush or ear bud dipped in alcohol or acetone or spirit. After it's cleaned, let it dry and again reinsert the sim card, install the battery and try again.
If it's been used before, then probably you still have the old sim card, if so install it and try again. If it's ok then borrow a sim card from a friend (for few minutes) or use your old or another available (working) sim card and try again. If both the old sim card and the other (borrowed) sim cards are working without any problem, then there's problem with your vodafone sim card which obstructs it to install on the Handset, perhaps voltage issue, in that case, you better get another replacement from Vodafone.
Or if the old one which you were using works, then your phone is sim locked, try to reset it using the default code 1122 or 3344 or 1234 or 5678 (should be on the manual) [click here for more info about china mobile codes]. To do this, go to settings, select "Restore" and enter the code, proceed forward giving positive inputs "yes" or "Ok".
After it's restarted, try again with all the sim cards.
If all the sim cards show the same error, then the handset might needs to be repaired or need to be replaced.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Cell Phones
Asks to install sim card when it's already installed
Here's what you need to do:
1. Remove the SIM card and wipe the gold metal on the SIM with a clean cloth.
2. Re-insert the SIM card.
If the phone still ask to install the SIM, then try another SIM to isolate the problem. If same problem occurs, contact an authorized repair shop and have them repair the SIM card slot.
Have a great day!
Sep 26, 2009 | Samsung SGH-c207
How to put sim card to the iphone?
SIM card slot is in top of iPhone. From iPhone Manual:
Press firmly and push it straight in until the tray pops out. If you don’t have a SIM eject tool, you can use the end of a paper clip.
2 Pull out the SIM tray and place the SIM card in the tray. The angled corner of the SIM ensures that the card fits only the correct way in the tray.
3 With the tray aligned as shown, carefully replace the SIM tray containing the SIM card in iPhone.
Aug 11, 2009 | Apple iPhone Smartphone
I get a no sim message even though sim card is installed. only happened recently. this is not a new sim, i have been using this optus sim card for the last 4 years.
sim cards do fail sometimes , try a new sim card.
try your sim in another phone .
another possibility is dirt in the charging point / data cable connection.
May 27, 2008 | Cell Phones
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
279 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
