Question about Niles SI-1260 12-Channel Amplifier
Niles si1260 has a red power light and no outputs.
3 Suggested Answers
SOURCE: No output from Niles amp
did you get an answer?thanks
Posted on Oct 28, 2011
I have the exact same problem. I know this is over a year old, but does anyone know what this might be?
Posted on Jan 03, 2013
COMO CONECTAR DOS AMPLIFICADORES
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 13, 2014 | Niles Audio Niles Si-2125 2-channel...
Niles ZR-6
I had the same issue as Brian, the Niles ZR8630 stays in initializing mode. At first, the unit would not turn on, so opened it and replaced the fuse, power was restored. But now the unit continually stays in INIT mode.
any body has an answer/solution?
Jul 30, 2012 | Niles ZR-6
I have an Onkyo TXNR609 home theater receiver hooked up to a 6 speaker surround sound setup in the living room. I also have 2 speaker pairs outside - one on the downstairs patio and one upstairs. I was...
If you haven't done already, then verify that zone 2 works without the selector. If the speakers definitely work and the zone output definitely works then the speaker selector must be the culprit! It's pretty difficult to mess up the wiring with speakers, as even if polarity is reversed, you will still hear something.
Sep 23, 2011 | Niles SSVC2 Two Pair Speaker Selector...
The protection light came on in my niles amp si250
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 01, 2011 | Niles SI-1260 12-Channel Amplifier
Niles audio zr-4630 powers on then shows error code e1
Power cycling?!?!? Are you serious?!?!? Do you work in tech support?? Power cycling , what a genius.
Feb 02, 2011 | Niles ZR-4630 2 Channels Receiver
Converting 2 channel amplifier to 2.1 amplifier
it is not availlable to do such convertion.
Jul 05, 2008 | Audio Players & Recorders
Niles ZR-4630
Thanks for the update. Did you try power cycling the unit?
May 22, 2008 | Niles ZR-4630 2 Channels Receiver
Adcom GFA-5400 installation
Use the niles for more than one speaker hookup. As far as the sub hookup, use a powered sub with speaker inputs
then use the right or left speaker and tag a couple wires to the sub. Good Luck
BIGRED
Dec 28, 2007 | Adcom GFA-5400 2-Channel Amplifier
Niles SI-1260 12-Channel Amplifier Logo
Top Niles Audio Players & Recorders Experts
 Grubhead
Grubhead
Joseph Hoffmann
Rob
Rob
Are you a Niles Audio Player and Recorder Expert? Answer questions, earn points and help others
