Question about HP Color LaserJet 2600n Printer
Jam in output bin message but no apparent jam
  • randycerf Oct 10, 2010
    This does not resolve the issue. I have cleared all pathways thoroughly, unplugged and replugged in the machine, etc. My hope is that there is a way to reset the machine. Otherwise, maybe a sensor needs to be removed, cleaned or replaced.
  • randycerf Oct 11, 2010
    I have repeated all steps indicated. After removing all toner cartridges, pressing the "X" and check button repeatedly, blowing it clean, I am totally confident there is not the slightest bit of paper in there. I did ONCE get it to print a single sheet before jamming again. It then jammed. I cleaned it thoroughly, reomoved and replaced toner cartridges and... still get the message and can't print.
  • HP Master
  • 4,737 Answers
Follow all the steps mentioned here (click here) [this may take several minutes, but this is the best method]. After you are done with all these, remove all the cartridges, drum, disconnect the power cord and the usb cable. Once again check the passage and the paper path (a hard blow with a blower or air can is also recommended). After you are cleared and done, reinstall everything.. now boot the machine and check the status...
If you need help removing and install the components, you can refer these animated tutorials (click here)
You can also try resetting (Cold Reset) (click here).
If the problem persists even after all these....... let me know.
Good luck.
Thanks for using FixYa.
Posted on Oct 11, 2010
  • HP Master
  • 6,487 Answers
Base from the description of your problem the issue can be really a paper jam somewhere in your printer that you cannot locate.
What we can do here is to make sure first everything is clear on your printer and not even a piece of paper a very small one that is jamming the printer.
You can follow the steps from HP site from this link to correct the problem, just click HERE.
Posted on Oct 10, 2010
How to clear paper jam?
How to clear the jam depends on where the jam is.
If the Jam is in Tray 1:
1. If you can see the jammed sheet, remove the jammed sheet by pulling it straight out.
2. If you cannot see the jammed sheet, open the tray 1 door and pull out tray 2.
3. Push down on two tabs to release the tray 1 panel.
4. Remove the jammed sheet by pulling it straight out.
5. Push up on two tabs to replace the tray 1 panel.
6. Replace tray 2.
If the Jam is in Tray 2:
1. Pull out tray 2 and place it on a flat surface.
2. Remove the jammed sheet by pulling it straight out.
3. Replace tray 2.
4. Press OK to continue printing.
If the Jam is in the Fuser area:
1. Open the rear door.
2. Remove any jammed sheets.
3. Close the rear door.
If the Jam is in the Output Bin:
1. Look for jammed paper in the output bin area.
2. Remove any visible media
3. Open and then close the rear door to clear the message.
It is possible that the paper may tear when clearing the jam. Be sure to clear any paper fragments that tear off.
Dec 16, 2010 | HP LaserJet CP1515n Printer
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
Display reads - " jam in output bin " jam was
look at the output area, make sure that the paper lever is working. Sometimes they come loose after a jam.
Nov 21, 2010 | HP Laserjet CM 1312NFI Color Printer
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Jan 28, 2010 | HP Color LaserJet 2600n Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Jam in bin
this is a common fault. look where the paper was jammed, you may need a torch. There is a black or white sensor there that has been dislodged. Once clipped back into place it will then report to the printer that the paper path is clear and no longer a jam.
Oct 05, 2009 | HP Color LaserJet 2600n Printer
JAM IN OUTPUT BIN
I personally couldnt find the user guide but i found a quick start user guide.
Hope it helps
Cheers
Sep 11, 2009 | HP LaserJet 3055 All-In-One Printer
Jam in Output Bin Message
The output Bin message comes from the sensor that reads when there are to many pages printed and they are sitting on the top BIN. Check the BIN sensor or arm and make sure that it is reading. Most of the time the sensor has a broken arm the the sensor reads to let it know when the BIN is full. You might want make sure that you reconnected the sensor and you have take the top cover off to replace the fuser.
Bruce
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Paper jam
That part is the fuser unit and is hot if the printer is on. Here are instructions for you. Good Luck!
http://www.laserpros.com/pdf/HP%202600-2605%20fuser-etb.pdf
Jul 27, 2008 | HP Color LaserJet 2600n Printer
Jam in output bin
Make absolutely sure there actually is no paper jammed in there.
I came to this page with the same warning, convinced I had a software glitch. Turned out there was a page accordion-folded down to the size of a pencil lead. I didn't know paper could be folded that small.
Of course, everyone here may be a lot brighter than I am, in which case sorry to waste your time. But for me, the obvious first fix needed to be thoroughly explored before cursing HP and their machine.
Jul 08, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
209 people viewed this question
Seeker5211
Seeker5211
