Question about Audiovox FPE3205 32 in. HD-Ready LCD Television
Inputs all red...
Ok so i've broke this beast (Audiovox FPE3205) apart and think i've narrowed the problem down to the main input block (I dont know the name of the part, but its the part with the VGA, DVI, and two component ins on it). Which the problem is that all the channels only show red, except for the VGA which works pretty good, most of the time. The OSDs look perfect, its some kind of problem in the inputs. So basically i wanted confirm this and ask where i could get this part.
The Red light stay on, no green light to see screen.
Posted on Jun 13, 2008
I have an Audiovox FPE3205 that the picture doesn't hold the clarity and gets blurry and grainy. Support said that it needed to be reset, but I've done that and still the same issue
I do not want to type the answer to this problem because I do not like to be the bearer of possible bad news. This television having been manufactured around 2006 may have reached the end of its life. As years go by, the picture quality on all LCD televisions diminishes.
Ok, ok, I got that out of the way first. Now forget that I just said all of that for a moment. This television will display a 720p resolution from its component input (green, blue, red, white, red). Make sure that whatever is connected to that input is only set to display images at a 1080i or 720p resolution. A wii or a regular dvd player not a bluray should look ok on the composite/RCA input. I'm not recommending the S-Video input for anything, and of course a computer can be connected to the VGA input still.
If the television looks bad even when displaying content on that 720p input then service can be considered and boards changed if you want to put money into this television rather than purchasing another one.
Oct 08, 2012 | Audiovox FPE3205 32 in. HD-Ready LCD...
I have fpe3205 power comes on but no piture or sound .how do i truble shoot to find problem?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_3_2012_2_01_15_pm.jpg
Look for caps on power supply board puffed up like these--most common issue.
Apr 02, 2012 | Audiovox FPE3205 32 in. HD-Ready LCD...
HL-R4667W vertical lines when I use any of the components and or AV inputs, but is ok with HDMI, any help?
Someone would have to look at a schematic to see where the HDMI comes in in order to know where problem is (what to replace).
Since a/v jacks show same trouble it is well after the tuner and is likely located on the board connected to the jacks for input---an area that deals both with tuner and conventional rear inputs.
A schematic or even a block diagram of signal flow in the set would narrow this way down to what you need to replace.
Try to Google for this with the model number and words like block diagrams, service manual etc.
One last foolish thought---have you removed the HDMI connection to see if other inputs clear up?
Mar 26, 2012 | Samsung HL-R4667W Rear Projection...
Hi We have an Allen & Heath Mixing Desk connected to two Yamaha P4500 audio amplifiers (via graphic EQ and compressor/limiter) which power the 4 main and 4 side speakers in our church. We now want to...
'Splitting' leads is never the best way to distribute a signal. The best solution is to use the parallel inputs of the Yamahas to chain them together: mixer to amp1, amp1 to amp2, amp 2 to the Cloud. You should only need to use one input on the Cloud to drive all the channels, using the input switches at the rear.
Let me know if you need any clarification on this.
Sep 21, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Hello,I have a AUDIOVOX-FPE3205. Red light on front panel flashing didn't count,sisling noise from back. can this be fixed?
It sounds like you may ahve bad power supply, that will be the first thing to look at.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Sep 07, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
My 32inch audiovox flatscrren will not come on but
Now in the front of the tv panel power blue light on and it solid green?Take ur tv aparts.The T-con board, this board sit in the botom in the middle of the LCD screen.This board is defective replaced it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-con board for the replacement.
May 11, 2010 | Audiovox FPE3205 32 in. HD-Ready LCD...
Hello, I have a Audiovox FPE3205 that the power just cut off and won't come back on. I'm thinking it has a blown fuse but I don't know where to look. Can you help?
There is a fuse on the power board labeled F901( 5 amp) for the AC supply. Therre is also a fuse, F902 (3.15 amp) between the large capacitor and the heat sink, for the DC side.
The power supply for these TVs is weak. Many capacitors fail leading to other parts burning out, like the PWM IC, ICE2A180Z and the current sense resistor R959 (2.2 ohm, 2 watt).
I recommend trying to find a replacement power board.
Monitor Mike
Sep 20, 2009 | Audiovox FPE3205 32 in. HD-Ready LCD...
Broke ******** in amp input
If the center conductor of the RCA plug broke of inside the RCA jack of the amplifier, you may be able to push it out from the back. If that's not possible, you may have to remove the jack from the board, disassemble it and then push the center conductor out. If you send me a photo of the jack, I may be able to offer more suggestions.
babin_perry@yahoo.com
Aug 09, 2008 | Sony Car Audio & Video
Mitsubishi Projection TV problem
Hello Adam...
Most likely a bad formatter board, which plugs in vertically on the signal board.
Nov 25, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Audiovox FPE3205 32 in. HD-Ready LCD Television Logo
180 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
