Question about Maytag M6Y12F2A Air Conditioner
May tag window air conditioner
Fan will only kick in
    Problem Solver:
  • 8 Answers
Here's a great article that should help you solve this problem:
Good luck,
Posted on Jun 17, 2008
5 Suggested Answers
  • 639 Answers
SOURCE: Window Air conditioner pulls too many amps
ngfam1 At your service!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
We sell appliances for 65 years in a family business!
My customers Tell me every week about the Whirlpool and or Maytag Air-conditioners that they bought for the cheapest price at Lowes,home,depot or a number of the big stores , knocked tapped did not work or had some problem form day one !
We can not shop price now a days cause people will sell ANYTHING IN A BOX! It is not made by that big manufacture!
But the rights to the name have been bought !And used on the box!
THE ROLLS ROYCE IS FRIEDRICH which can run for 20 to 30 years!! YES IN YOUR WINDOW!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
  • 233 Answers
SOURCE: GE Air conditioner cannot kick into airconditioning mode
it sounds like either the start components for the compressor have failed or the compressor itself has failed, since it is not kicking the breaker I would lean towards start components.if it is a PSC only comprssor, you may be able to add a start assist to get the compressor started. I assume that since it is 8000 btu it is 110VAC you can probably get a generic start kit at your local appliance parts house. they have a diagram and are fairly easy to install, just be aware that the capacitor storea charge on the OFF cycle, and can be dangerous
Posted on Jul 19, 2009
  • 8 Answers
SOURCE: fedders A3X06F2G window air conditioner fan does not spin
Fan motor is stuck or defective it might need replacement. Check for broken fan blades or obstruction.
Posted on Feb 04, 2010
  • 251 Answers
SOURCE: Haier air conditioner will not kick on to air
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
Posted on Jun 07, 2011
What is the energy efficient info on 5000 btu air conditioner
Your unit only consumes power on startup.about 10 amps on running it only uses about 5 amps when the thermostat kicks in low power consumption on that unit as it has a small compressor
Sep 28, 2016 | ACE Artic King Window Mount Air...
Fan speed button on window air conditioner
This is mot my field of expertise, in any case here is the user manual. Hope it can help
Feb 25, 2008 | Comfort-Aire EKTC12-150J Air Conditioner
Compressor won't kick on 12,000BTU Frigidaire window A/C After cleaning
Is everything dry? Do you hear any noises like the compressor running it is just not cooling?
Aug 04, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Air compressor does not kick in unless ambient temp is > 80
Do not operate low fan and maximum temperature as the coils will freeze up stopping air flow.
May 21, 2009 | Whirlpool Electronic Window Air...
Fan not working on LG air conditioner su/sz/s3 model
Bad fan motor and or start capacitor are reasons that I suspect......Sea Breeze
Jan 31, 2009 | LG Electronic Window Air Conditioner
Air conditioner
That sounds like the compressor is not kicking-in. Now you need a service tech to diagnose & locate the problem and solve it!
Sep 02, 2008 | Whirlwind FH-778 Air Conditioner
Fedders A3X06F2G window air conditioner fan does not spin
Aug 24, 2008 | Fedders A6Q10F2B Q Chassis Room Air...
Fan speed on cool setting only works on low
If it's in Energy Saving mode, that may be normal.
Fan speed trouble on cool setting
1.check selector switch of airconditioner.
2.capacitor of blower fan motor.
3 wiring of airconditioner.
4.replace selector switch.
Maytag M6Y12F2A Air Conditioner Logo
79 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
