Question about Cameras
I need a small battery that slides into the bottom of the camera. It must be used for the still photosl
  • kakima Oct 10, 2010
    What make and model camera? Different cameras take different size batteries.
    Brigadier General:
  • 11,967 Answers
We can't help you if you don't tell us the make and model of the camera.
Posted on Oct 10, 2010
There is no button on front to release battery compartment
No, it is on the bottom
Page 3
Slide the UNLOCK switch on the bottom of Camera and use the knob to pull the slide-out
Battery Tray. Install eight (8) AA size alkaline or lithium batteries with polarities as
indicated in the Battery Tray. Re-install the Battery Tray and insert your SD card.
We recommend that you format the SD card inside the camera before taking pictures
http://images.ebsco.com/pob/moultrie/catalog/m-990i_manual-english_web.pdf http://images.ebsco.com/pob/moultrie/catalog/m-990i_manual-english_web.pdf
May 08, 2016 | Moultrie Game Spy M-990i
How to open battery door?
Hold the camera upside down. In the middle on the bottom side is a small grey tab. Push and hold that down and at the same time slide the compartment door to the left. Its tight and might require the use of a knife blade wedged down in the crack between the arrow and the screw the first few times. Yeah it could be easier but it is a watertight seal remember. It only slides about a quarter inch then it opens towards you.
Aug 27, 2014 | Bell & Howell Splash Wp7 Waterproof Camera
How do you open the battery compartment Bell & Howell Splash Wp7 Waterproof Camera
Slide the battery cover on the bottom of the camera to open the battery compartment. Use fresh 2xAAA bateries
Jun 12, 2014 | Bell & Howell Splash Wp7 Waterproof Camera
How to remove Canon A570is broken battery door
I had the same problem and found nothing online to fix it so based on what little I could find and some common sense I got it done fairly easily. Here's what I did...if you need more detail on any step either re-read it to see if you missed something or let me know 'cause maybe I missed something.
Standard warning - you are dealing with small screws, small parts and things that might break. If you damage your camera trying this repair - please don't blame me! <G>
1) remove batteries and memory card
2) carefully remove screws around the outside.
There are: 3 on the bottom, 1 under the plastic usb cover on the left side, 3 on the right side. Once those are out, remove the clip that holds the wrist strap and you'll find 1 more on the top of the camera under the wrist strap clip.
3) starting at the bottom of the camera, gently separate the back cover from the camera body. YOU DON'T NEED TO TOTALLY REMOVE THE COVER!
4) (note the small spring on the battery hatch - when you complete the next step that spring will come out so look at where it is, which way it is and don't lose it!) While holding the cover and camera body apart slightly, use a pair of fine needlenose pliers or possibly tweezers & slide the pin that holds the hatch in place toward the back of the camera until the spring and door come off. You don't need to totally remove the pin.
5) take your new door assembly and put it in place. the fun part is the little spring - the shorter end of it has to go through a small hole at the back of the hinge area, the longer end puts pressure against the hatch. Once the spring is in place, hold it there and slide the pin back into place (I found that just allowing the cover and body to come back together moved it into place).
6) try the hatch to make sure it opens/closes freely and latches
7) put the screws back in place - note that one of them is shorter than all the others - that one goes on the top of the camera under the wrist strap clip
Hope this helps!
Please note - this is the only digital I've taken apart so I'm not likely to be able to help with other makes and models but feel free to ask!
Jun 14, 2010 | Canon PowerShot A570 IS Digital Camera
Cannot find batteries that work. I have replaced the batteries with different brands and it still wont turn on. What is the problem.... Its not reliable.
It is possible that there is a small amount of corrosion on the contacts in the camera. Use the eraser end of a common pencil to clean these contacts. Also, make sure you are using the correct batteries. It shows here that you have the polaroid i830. this camera uses two AA batteries: Open the battery door, located on the underside of the camera (use your thumb to slide the door outwards). Install the two AA batteries into the battery bay. Install the SD card into the slot located next to the battery bay. Close the battery door.
  1. Step2Press the power button located on top of the camera. Locate the "Playback" button on the rear of the camera, under the "W" button; this button switches the camera between "Capture" and "Playback" modes. Set the camera to "Capture" mode.
  2. Step3Press the button on the bottom right of the rear of the camera to open the mode selection window. Use the navigation buttons to select "Still Image" mode. Press the button labeled "Set Disp" to confirm your selection.
Nov 02, 2009 | Polaroid i830 Digital Camera
I want to take the phone apart
remove cover and battery and sim etc remove 4 screws that you see using a opening tool or an old sim card run it round the first seam and it will seperate. remove the centre screw and the plug next to it and remove the block by lifting up.carefully free the camera button and volume flex from there position at the side then lift the lock on the thin flex at the top of the board. lift the board from the bottom of the phone and turn it over towards the top so that you can undo the plug flex then the board can be removed the small thin flex should just slide out. next remove the six small screws off the slide part and lift that clear,then remove the two screws that hold the last plate run opening too; up the sides and the plate will free lift it out from the bottom up.whats left is the screen and camera remove and replace what you need then rebuild in reverse using new flex
Jul 16, 2009 | Samsung SGH-G800 Cellular Phone
How do i replace internal battery on the minolta maxxum 7000? i replaced the AAA batteries, but it still just flashes ''film'' in window.I have no manual and dont know how to get the film out.HELP!
Unscrew battery compartment on the right grip, and remove the battery holder (AAA's in most Maxxum 7000's) In the compartment you should see a silver colored metal plate, held on by 6 small phillips screws. Unscrew these, and carefully lift the plate, and move it aside (there's a tiny wire soldered inside the plate, so don't break it off).
Inside there should be a CR2016 lithium button battery. Replace it, and reassemble in reverse order.
NOTE: This probably won't fix any issues regarding the removal of the film, as the 2016 is just a memory backup battery for when the main batteries are removed.
to remove the film, install fresh main batteries, turn on the camera via the "Lock" switch and rewind the film. on the back of the camera, just behind the LCD screen, above the film door, you will see a grey button marked "R". Push and hold it, while sliding the gray slide switch immediately to the left of it to the left. The film should now rewind.
When the film is done rewinding, open the back via the sliding latch on the left side of the body with the gray button in the middle. Push the button, while sliding the latch down.
To insert film, place the cartridge in the same place and orientation as the old roll, and pull the leader over to the red dot on the bottom right of the film compartment, and close the back. it should advance to the first frame if done correctly, or blink 0 if done wrong.
If you need anymore assistance, contact me via email cwrrailfan at yahoo dot com
Have Fun with your 7000!
Mar 11, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Cannot remove the battery from by new nikon d300
Hi Dee and thanks for coming to FixYa.
Hold the camera like your going to take a picture. Now turn the camera over to look at the bottom. On the right hand side is a small latch. The latch secures the battery hatch door. Pop the latch and the battery door should open.
Turn the camera back over carefully and the batter should slide out.
Then plug the battery into the charger and you can charge it. Have fun with your new camera!
Rob
Feb 28, 2009 | Nikon D300 Body Only Digital Camera
How to remove battery from a nikon d40 camera
on the bottom of the camera, look for a small latch. Open it and a door will swing open. Slide out the battery
May 12, 2008 | Nikon D300 Body Only Digital Camera
I have a canon XL1 which has red icon in the viewfind looks a bit like a small cell with a line through it. any ideas
That symbol means that the backup (date) battery needs to be replaced. This is a button style battery and the replacement number is CR2025. It is located in a holder that slides out of its slot on the bottom of the camera. To keep your current settings, make sure you have the normal battery installed and put the unit in STANDBY mode when changing the backup battery.
May 06, 2008 | Cameras
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
