Question about Iomega 1TB Home Media Network Hard Drive (34337BN)
I can see the Imogega Home Network Drive in my workgroup, including viewing the system info. I try to open one of the folders and I am told: \\Imoega-090c8b\pbsafebup is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found.This has been working for several weeks without problems. Using the home storage manager I see that no Network drive letters are displayed and when I try to map a network drive I am informed that the network path is not acceptable. Therefore I cannot access my valuable backups.
This (and other problems having to do with accessing the drive or its folders) can be solved by:
1. Removethe drive from its case
2. Plug it into a computer
3. Boot the computer to a Linux-based OS -- if you don't have a PC running Linux, download one of many Live CDs images available, e.g. Knoppix, and burn a CD with it (Live CD images are bootable), then boot the PC using the CD
4. Login as the root user and open a terminal session
5. If necessary, 'umount' the drive, e.g. 'umount /dev/sda2'
6. Run 'xfs_repair -L <partition>' where <partition> is the partition to be repaired - in my case it was /dev/sda2, so running...
xfs_repair -L /dev/sda2
...was the command to do the repair. Note that the command is cAsE sEnSiTiVe.
You may get a message about destroying a log file (that's what -L does) -- it's OK -- I've had to do this several times and no harm has come of it.
The process can take several minutes, and at the end there may be a message about a bad superblock -- this is also harmless, so far as I've seen.
7. Power down the PC
8. Remove the drive, put it back in its enclosure, and Voila! -- all should be OK upon booting it up!
Posted on Aug 25, 2012
  • 4 Answers
So Unreliable iomega, I repent for buying this product
Posted on Jan 12, 2013
3 Suggested Answers
SOURCE: permissions of access
No.
Posted on Oct 06, 2007
  • 74 Answers
SOURCE: the folders for the iomega storage drive no longer
Make sure you are logged in as the Administrator of your computer. Power cycle (turn it off and back on) the device. If that doesn't fix the problem. Try factory resetting the unit (depress the reset button on the back of the unit for 4-5 seconds).
Posted on Dec 24, 2010
How to I set up my dell laptop in my house to print wirelessly from a canon mp780 printer?
Basicallyif you have a wireless router with several laptops and desktop PCs, which canaccess the Internet at the same time, then you have working network withthe laptop and PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.
Mar 25, 2012 | Canon PIXMA MP780 All-In-One InkJet...
VISTA Business cannot 'see' XP machine in same workgroup
Check that the two machines are in the same workgroup on network settings.
Oct 14, 2008 | Microsoft Windows Vista Business DVD...
How to hook up a hard drive from one computer to another
You need to connect the computer together in a network and then share the hard drive and or folders between eash computer.
FILE SHARING BETWEEN COMPUTERS ON A NETWORKBasicallyif you have a router with several laptops and desktop PCs, which can access theInternet at the same time, then you have working network with the laptopand PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.
Jan 14, 2012 | Gateway DX441X Intel Desktop PC - Intel...
I want to start a network between my laptop and desktop
There are lots of guides on the internet...
BUT as a minimum you will need...
All the computers on your home network connected through the same router (Wired or Wifi).
All the computers on the same "Workgroup"..Choose a workgroup name and change all the computers to the same workgroup.
You will then need to change the properties of any drive/folder or files to enable sharing.
You can also drag stuff into the shared folder.
This can still be quite hit and miss, especially if your computers are using different versions of windows.
Good luck
Jul 21, 2010 | Dell Dimension 4700 PC Desktop
How to network
Basically if both the laptop and the PC can access the Internet at the same time then you have working network with the laptop and PC.
First make sure the laptop and PC have the same Workgroup name (it may already have Workgroup as the Workgroup name, you can change it if you wish). To change the Workgroup name open Control Panel - System - click on Computer Name tab - click Change and you can change the Computer name then select Workgroup and enter or change the Workgroup name - click OK and OK again.
Next enable Sharing on both the PC and laptop open My Computer - right click on the C Drive - click on Sharing tab - tick Sharing this folder on the network - add a Share name to identify the computer/folder (eg C drive on PC).
If you do not enable sharing on the drives or folders then they will not be available to the computers on the network.
If you have more drives,them repeat this for the other hard drive and or CD or DVD drives.
Re-boot the computers and you will be able to see the comuters on your network through My Network Places.
Dec 21, 2009 | Computers & Internet
Windows Vista not accessing shared folders on network. It keeps asking to log onto network PC and keeps saying cannot log in when trying accounts on the network pc. Both PC's are on the same workgroup and...
This is a usuall problem when connecting Vista and XP, specially when your vista is a 64-bit and your XP is 32-bit. What you need to do is to manually map the folders on the vista by opening windows explorer and then clicking on Map network drive, you need to put in the exact folder location. Next thing is you need to add user not only activationg the allow access, you need to add the user on the shared folder, you are only using workgroups, unlike domain networks, you just have to give them permission.
Sep 05, 2009 | Computers & Internet
Windows Vista
In the start menu click network,on the bar on top click network and sharing center,scroll down and enable network discovery.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
Wireless router
I cann't get my desk top and my laptop to connect so I can get to the internet I'm running a 624 router in the system
Aug 24, 2008 | NetGear WGT624 Wireless Router
How to i configure my system Belkin Wireless G Plus MIMO to allow a home network to see all the PC on the netwrok plus my Network Storage. My internet conection works fine?
For each of your computers, right click on 'My Computer' then click on 'Properties'.
Under the 'Computer Name' tab, make sure each of your computers are members of the same workgroup ID. Just make a name up and use it for all of your computers.
The information that you want to be shared between your network computers should be placed in the 'shared' folder.
After doing this, make sure all of your computers are running and that they each have a working internet connection.
Go to My Network Places, click on view workgroup computers.
You should be able to see all of the computers in your network.
As far as configuring the router goes, if you haven't changed the settings in the past, Nothing should have to be altered in order to view other computers on your network.
Apr 12, 2008 | Computers & Internet
Home network
hi, 1) Check the status of the "computer browser" and "netlogon" 2) check the network configuration on both end IP=? Netmask=? Workgroup=? if these are not in same range make it same range any verify if pinging is happening. 3) Check if any firewall is causing the system, if firewall is exist try to open all ports for temporary to check. 4) go to control panel==> double click the network setup wizard==> "and follow the steps" remember that you are keeping same workgroup. 5)run antivirus and antispyware if any network threats are causing the problem if it didn't help you, write your OS version and applications name that have been installed on the system. thanks Arun
Aug 30, 2007 | Microsoft Windows XP Home Edition
Iomega 1TB Home Media Network Hard Drive (34337BN) Logo
1,407 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
