Question about Peg Perego 12 Volt Rechargeable Battery
There is a blue cable coming from the inside of the tractor. It is connected to a red cable that connects to the battery. The blue cable was accidently pulled from the red cable. There is also a clear plastic piece between the two. I have attempted to reconnect the two cables with the clear piece in the middle and it still won't work. The battery is fully charged. I need to know exactly how the blue cable should be connected to the clear piece in order for the tractor to work. Thanks.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Let me know if this is still a problem
Posted on Jun 07, 2012
HOW TO WIRE UP BATTERIES
Clean all connections before reattaching cables.
The negative post (shown as - on battery) should connect to the black battery cable or the cable going to ground. The other end should be bolted to a metal surface such as the frame.
The positive post (shown as + on battery) should connect to the red battery cable or the cable connected to the starter solenoid.
Dec 28, 2015 | Garden
No start
Check all battery connections... Follow the Positive cable (usually red) to the starter solenoid. Check connections. There should be at lease 3 wires attached to the solenoid, Battery cable IN, Battery cable OUT and a Smaller wire from the ignition switch. Test to see if you have power at the small wire when the ignition with(key) is turned to the START position. If there is no power, check the Seat kill switch and the clutch pedal switch. On most tractors, the clutch pedal has to be depressed to start the engine. If there IS power at the starter solenoid, check the Battery OUT cable. If there is power at this cable, check your starter. If there is no power at the Battery OUT cable, and there is power at the ignition wire, replace the starter solenoid. Hope this helps...
Jul 15, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Troy bilt pony will not start. replaced 20 amp fuse and battery
OK -- Here's what to do:
TROY-BILT PONY LT CRANKING CIRCUIT TROUBLESHOOTING
NOTE 1: The following tests are to be made with the parking brake applied and the PTO disengaged unless otherwise specified.
NOTE 2: These tests need only be made until the cause of the problem is located. The entire process need not be completed if the problem has been resolved.
NOTE 3: Refer to the wiring diagram below for understanding of all tersts.
NOTE 4: Wiring Diagram references to Key switch A1 and L terminals refer to the same terminal.
1. With all circuits connected normally, connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the battery positive terminal. The voltmeter should read at least +12.6 VDC.
a. If NO, go to step 2.
b. If YES, go to Step 3.
2. Connect a DC voltemeter directly across the battery. The voltmeter should read at least 12.6 VDC.
a. If NO, charge or replace the battery.
b. If YES, check and repair/replace the following items as required, then repeat Step 2 test. If YES on retest, go to Step 3.
-- battery negative cable condition
-- battery negative cable connections at the battery
-- battery negative cable connections at the tractor frame
3. With all circuits connected normally, connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key swttch "B" terminal (Circuit #97 - red/white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, go to step 4.
b. If YES, go to Step 8.
4. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay BAT terminal (Circuit #94 - heavy red wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 4 test. If YES on retest, go to Step 5.
-- battery positive cable condition
-- battery positive cable connections at the battery
-- battery positive cable connection at the starter relay
b. If YES, go to Step 5.
5. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the fuse holder BAT terminal (Circuit #92 - red wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 5 test. If YES on retest, go to Step 6.
-- Circuit 92 wire condition
-- Circuit 92 wire connection at the starter relay
-- Circuit 92 wire connection at the fuse holder
b. If YES, go to Step 6.
6. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the fuse holder protected circuit terminal (Circuit #97 - red & white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 6 test. If YES on retest, go to Step 7.
-- 20A fuse condition
-- fuse holder condition
-- fuse holder wire connections
b. If YES, go to Step 7.
7. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key switch "B" terminal (Circuit #97 - red & white wire). The voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 7 test. If YES on retest, go to Step 8.
-- Circuit 97 wire condition
-- Circuit 97 connection at fuse holdser
-- Circuit 97 connection at key switch
8. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the key switch "S" terminal (Circuit #80 - orange wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 8 test. If YES on retest, go to Step 9.
-- key switch assembly
b. If YES, go to Step 9.
9. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the parking brake switch Circuit #80 terminal (Circuit #80 - orange wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 9 test. If YES on retest, go to Step 10.
-- Circuit 80 wire condition
-- Circuit 80 connection at key switch
-- Circuit 80 connection at parking brake switch
b. If YES, go to Step 10.
10. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the parking brake switch Circuit #70 terminal (Circuit #70 - orange & black wire). With the key held in the START position, the voltmeter should read at
least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 10 test. If YES on retest, go to Step 11.
-- parking brake switch assembly mounting and adjustment
-- parking brake switch assembly condition
b. If YES, go to Step 11.
11. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the PTO switch Circuit #70 terminal (Circuit #70 - orange & black wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 11 test. If YES on retest, go to Step 12.
-- Circuit 70 wire condition
-- Circuit 70 connection at parking brake switch
-- Circuit 70 connection at PTO switch
b. If YES, go to Step 12.
12. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the PTO switch Circuit #60 terminal (Circuit #60 - orange & white wire). With the key held in the START position, the voltmeter should read at least +12.6
VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 12 test. If YES on retest, go to Step 13.
-- PTO switch assembly mounting and adjustment
-- PTO switch assembly condition
b. If YES, go to Step 13.
13. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay Circuit #60 terminal (Circuit #60 - orange & white wire). With the key held in the START position, the voltmeter should read at least
+12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 11 test. If YES on retest, go to Step 14.
-- Circuit 60 wire condition
-- Circuit 60 connection at PTO switch
-- Circuit 60 connection at starter relay
b. If YES, go to Step 14.
14. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter relay MOT terminal (Circuit #93 - heavy red wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, did the relay make a single heavy "click" noise?
1. if YES, replace the starter relay and repeat Step 14 test. If YES on retest, go to Step 15.
2. If NO, connect a DC voltmeter DC voltmeter black (NEG) lead to the battery negative terminal and the red (POS) lead to the starter relay frame. With the key held in the START position, the voltmeter should read a maximum of +0.1 VDC.
a. If YES, replace the starter relay and repeat Step 14 test. If YES on retest, go to Step 15.
b. If NO, check and repair/replace the following items as required, then repeat Step 14 test. If YES on retest, go to Step 15.
-- starter relay mounting
b. If YES, go to Step 15.
15. Connect a DC voltmeter black (NEG) lead to the tractor frame and the red (POS) lead to the starter motor BAT terminal (Circuit #93 - heavy red wire). With the key held in the START position, the voltmeter should read at least +12.6 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 15 test. If YES on retest, but the starter motor does not engage, go to Step 16.
-- Circuit 93 cable condition
-- Circuit 93 cable connection at starter relay
-- Circuit 93 cable connection at starter motor
b. If YES, but the starter motor does not engage, go to Step 16.
16. Connect a DC voltmeter black (NEG) lead to the battery negative terminal and the red (POS) lead to the starter motor frame . With the key held in the START position, the voltmeter should read a maximum of +0.2 VDC.
a. If NO, check and repair/replace the following items as required, then repeat Step 16 test. If YES on retest, but the starter motor does not engage, go to Step 16b.
-- starter motor mounting to engine
-- engine mounting to tractor frame
b. If YES, but the starter motor does not engage, replace the starter motor.
REFERENCE PART NUMBERS PER WIRING DIAGRAM:
Note that your specific tractor may use differnt part numbers. You can obtain a Parts List specific to your tractor online, at no charge, from Troy-Bilt at www.troybilt.com -- your full model number and serial number are required.
Key Switch 725-04228 (common alternatives are 925-04227B & 925-04659)Parking Brake Switch 725-1657A (common alternative is 725-04363)
PTO Switch 725-1657A (common alternative is 725-04363)
Starter Relay 725-04439
Also note that the starter motor is an engine manufacturer supplied part.
Jul 19, 2012 | Troy Garden
How do you get to the accelerator switch on John Deere turf tractor
flip the tractor over and you'll need to pop out the gray plate that holds the foot pedal with a flat head screwdriver and then the wires should be red white blue connected in that order
May 19, 2012 | Peg Perego Power Wheels ACCELERATOR...
How do you start it at the engine?
Please explain what your problem is also... here is how to jumpstart your mower.
  • To get the tractor ready for jumping off the battery, push the clutch foot pedal all the way down and hold it while you lift up on the parking brake lever and then release the clutch foot pedal. This will hold the clutch pedal in the down position.
  • Lift the seat forward to access the battery.
  • Take one Red end of the jumper cable and attach it to the red battery terminal on the known good vehicle battery making sure the other end is not touching any metal surface or the tractor. Put the tractor end of the Red jumper cable to the Red or + terminal on the tractor battery. Next put the Black cable on the Black or - terminal on the supply battery and take the other Black end of the jumper cable and clamp it onto the tractor draw bar at the back of the tractor and make sure is making good connection.
  • With the blade engagement lever in the off position you should at this time be able to turn the key and start the engine on the tractor. As soon as the tractor starts remove the cables in the reverse order. Black from the draw,Black from the power source, Red from the tractor battery and Red from the power source battery.
(from thread)
http://www.managemylife.com/mmh/questions/259663-start-riding-lawn-mower
More helpful info on my thread here.
Please leave comments and questions if needed. Please accept this solution and rate by clicking 1,2,3, or 4 stars for service. This is much appreciated. Thank You. - Premium FixYa Support
Aug 01, 2011 | Garden
I have been jumping my craftsman riding mower off for a while and its always worked. now as i take one of the jumper cables off ,the mower dies everytime.could you tell me whats wrong.
Sounds like one of the battery cables are bad or loose . Start by removing the black cable from the battery. clean the inside of the connector with emery cloth or course sand papper. do the same for the battery post. Remove the red cable and do the same. Attach the black cable to the - neg. post on the battery. attach thr red cable to the + pos. post on the battery. Now follow the black cable andand make sure it is connected to the engine block or somtning metal. remove it and clean the connection point. Also it would not be abad idea to have the battery load tested. It could be that it is so bad that it will not produce enough voltage/amperage. How old is the battery?? Are you jumping it with another battery or a charger /starter?? If charger /starter try a battery. szm230
Apr 15, 2011 | Craftsman Garden
Wiring of the 2-5-10-15 timer to a jucuzee bath tub it has three wires black blue green. Thanks. Terry.
First thing to consider is size of Load.
Leviton countdown-timer Load rating is 1800 Watt, 120Volt.
Look inside Jacuzzi at rating plate on motor.
Rating plate on motor should give Volts, Watts and Amps.
Formula Volts x Amps = Watts.
Sometimes motor shows VA which is Watts
Is Jacuzzi on 240Volt breaker or 120V breaker?
Leviton countdown timer is not for 240V load.
A) If 120Volt electric Load checks out, here's how to wire timer if 1 cable enter box.
Timer-black-wire connects to jacuzzi-black
Timer-white-wire connects to ground.
Timer-green connects to ground.
Timer-red connects to jacuzzi-blue.
B) Here's how to wire timer if 2 cables enter box.
120Volt cable coming from breaker box has black, white and bare copper wire.
Timer-black-wire connects to black-wire-from-breaker
Timer-white-wire connects to white-wire-from-breaker-box.
Timer-green and jacuzzi-ground connect to ground
Timer-red-wire connects to jacuzzi-black-wire.
Jacuzzi-blue-wire connects to white.
I am puzzled why this wire is blue if circuit is 120Volt.
Nov 26, 2010 | Leviton Timer Switch 2-5-10-15 Minutes, 4...
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Bluetooth wiring diagram
you will need to search for a wiring diagram for your model of car radio
car kit blue - connect to ignition cable OR connects to switched 12v cable going to radio
car kit red - Direct to +terminal of battery OR to constant 12v cable going to radio
car kit black - connects to GROUND going to radio
car kit yellow - connects to mute function of radio if your radio supports it.
OR
connect blue and red together and directly to battery
and connect black to Body of vehicle
(not recommended as could result in draining of battery, even thought the kit is supposed to prevent this).
Jun 30, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
I connected the Wii console to my 52" LCD Samsung but it works with black and white only
If your using the component conections (red, blue, green/red, white) to connect you wii console to your lcd then check your connection making sure the red and blue is connected properly within the right inputs, red in red and blue in blue. The red connection next to the white is considered to be the right audio connection rather than the pr connection. If your using you AV or composite (red, white and yellow) cables that comes in the box make sure you connect horizontally and not vertically in its correct input.
Dec 31, 2008 | Televison & Video
Peg Perego 12 Volt Rechargeable Battery Logo
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
