Question about Whirlpool Duet GHW9150P Front Load Washer
Can overloading cause water leaking? I found water (a lot of it) on the floor following the wash of a very large load. (Whirlpool Duet Sport)
  • 36 Answers
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
take off the bottom kick panel locate the drain pump now there will still be water in the washer so take caution when following this procedure i use a shop vac and suck all the water out of the drain hose to prevent a mess then the frount of the drain pump will screw off check it for blockage or damaged impeller blades
Posted on Dec 28, 2007
SOURCE: whirlpool duet sport..vibrates during spin and "walks"..on pedistal.sitting on tile
I just bought this washer and had two problems with it. 1 the vibration at medium spins and 2. a squeeking spring (every time the drum rotates a little squeek, but when spinning the squeek sounds constant.
What I discover in solving both my problems with the same solution. I had to ensure all 4 feet well on the ground and that the top of the washer was perfectly level. At one time I was out only about 2 mm on one side, but the bubble was slightly to one side on the level but still in between the level's markers. I tested with a load, and both problems were still there. Turn feet 1/2 turn on the side needing adjusting. Ran another load and you guessed it, no squeak, no vibration, spinning was quiet, I had to go over to check to see if the machine was going through the cycles. I couldn't believe that a few millimeters could make such a difference.
Now I am pleased with the performance, not to mention how clean the clothes are and the savings on water and drying.
Posted on Mar 04, 2009
  • 10865 Answers
SOURCE: Whirlpool Duet Sport HT - Left Front occ. leaks a lot of water
hello. i dont have to tell you that these intermittent problems are often the most difficult to isolate ...........sooooooooooooo lets look at all of the possible causes for your machine leaking
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Aug 22, 2009
  • 118 Answers
SOURCE: Very Loud and Active Whirlpool Duet Sport Washer
It looks like the transit bolts are still in there at the back and if you take them out it should be more quiet.
Posted on Sep 21, 2009
j_alcaidinho
  • 107 Answers
SOURCE: Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Posted on Jan 20, 2010
Our Duet washer leaks about a cup of water
If this is a Whirlpool Duet series front loader, the following link explains how to access and inspect your washer for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of the cases with front loaders, the door bellow (rubber door seal) begins to leak. A routine inspection of the seal perimeter will tell you if there are any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. Overloading the washer can also contribute to premature wear and tear on the bellow. Always follow the manufacturer's recommendations for proper loading.
Apr 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is on the 2nd floor and when its on the spin cycle it makes a very loud noise...why?
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Nov 13, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Heavy towels don't come clean & smell of mildew - all whites and colours are gray after bleach has been used.
Did you add detergent to the dispenser?
For best results, add detergent to the detergent
compartment. Do not add detergent to the washer drum.
 Did you sort properly?
Sort lint givers (towels, chenille) from lint takers (corduroy,
synthetics). Dye transfer can occur when mixing whites and
colors in a load. Sort dark clothes from whites and lights.
 Did you overload the washer?
Do not overload the washer. The washer can be fully loaded,
but not tightly packed. The wash load must be balanced. Lint
can be trapped in the load if overloaded.
 Check the following:
Was paper or tissue left in pockets?
 Did you use enough HE detergent?
Follow manufacturer’s recommendations for the type of load
you are washing. For best performance, use only High
Efficiency detergent. Use enough HE detergent to remove soil
and hold it in suspension.
 Do you have hard water?
Use more detergent for washing heavy soils in cold or hard
water.
 Is your water colder than 60°F (15.6°C)?
Wash water colder than 60°F (15.6°C) may not completely
dissolve the detergent. Use hot or warm washes if safe for the
fabric load. Make sure your hot water system is adequate to
provide a hot water wash.
 Have you run the Clean Washer Cycle lately?
To freshen your washer and to avoid odors, see “Cleaning
Your Washer.”
 Are you using HE detergent?
Use of non-HE detergent can cause a film residue which can
result in odor.
 Did you leave the door open after use?
This washer has a tight seal to avoid water leaks. To avoid
odors leave the door open to allow the washer to dry
between uses.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10117768.pdf
(see page 20 for washer cleaning instructions)
Oct 10, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
My whirlpool duet sport is leaking out of large amounts of water out of the detergent compartment. it seems as if the water will not travel into the machine. any ideas?
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PW1 very noisy when spinning
its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When I wash comforter in whirlpool duet front load water comes
first an foremost your washer isn't designed to wash comforters, the capacity isn't large enough. only clothes sheets . the reason ur door wont stay closed is the bulk item is pushing it open. overloading washer will cause $$ major problems. simiply take that to the cleaners an save urself some big bucks.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport washing machile leeks out of dtergent area!!
the water is leaking out from the dispensor area??? sounds as if perhaps something has gotten down there blockig the waterwway, try removing the soap dispensor entirely and lookin towards the rear for a possibel obstruction
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking
Sheets Or Comforters? This Normally Occurs With An Overload Such As Pillows And Comforters Due To The Large Circumference. Which Simply Means That Anything That Has A Large Area Will Make The Water Come Over The Top Because When The Machine Is Running The Spin Cycle The Large Area Of Fabric Covers The Side Of The Machine. Actually Causing Water To Spin Off The Top Of The Fabric And Over The Sides Of The Washing Machine Bucket Thus Ending Up On The Floor Below.
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking Water
check your rubber bellow you might have had something go threw it.
Jun 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
175 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
