Question about Frigidaire Washing Machines
I have the Frigidaire Gallery Series washer and dryer and I have a problem with both. The washer has accumulated a nasty layer of dirt, mildrew and who knows what else on the rubber seal and window. The stuff on the window is easy enough to wipe off, but how do I get rid of the other stuff and the smell? The lint basket is very difficult to clean out completely. The liner is now cracked and clothes with thin straps get caught on it, are twisted in the drying cycle to the point of tearing the clothes. Please help!
  • heathermama4 Jun 01, 2008
    Any other suggestions for either the washer or dryer other than taking them apart or buying new ones? They are only three years old.
    Sergeant:
    Champion:
  • 347 Answers
Since i dont know the model you are using, i cant give you a more specific link, but why dont you try to visit
http://www.frigidaire.com/products/laundry.asp
and check if you can solve your issue there, or get into contact with them.
Posted on Jun 01, 2008
    Genius:
  • 1,665 Answers
Hi have a look at troubleshooting tips here:
http://www.repairclinic.com/0088_11_1.asp
    Genius:
  • 3,587 Answers
Hmmm...well..sounds like your unit is eligible for a thorough(honey do) episode, if he is so inclined. Otherwise, you are experiencing what's commonly called wear and tear, from most likely faithful service of a valuable appliance.
maybe it's time to consider a new one?
if not, then taking it apart will require patience, tools, and perhaps some cleaning solutions that are not amenable to the human skin.
Posted on May 31, 2008
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Works in the winter but not in the summer. Particles of dirt come in even though the outside vent is closed.
hello,
All Frigidaire Electric Gallery Series carry out same function when working it pull dust that are around can not be easily see with eye (micro dust) around throngh the air ventilation when it plug on to power .
what you are to do always after use is to clean it very well in other to avoid the accumulation of the dirt to avoid damage of element (HEAT PTOVIDER)hope this help.
thank you and thanks for using fixay.
Jun 24, 2010 | Frigidaire 30 in. Electric Gallery Series...
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Attach washer to pedestal
there should be bolts that come with pedestal so you need to take your legs out of the washer now lay it on its back then bolt the pedestal up to it and if the pedestal dont have feet put the ones out of the washer on it
Dec 31, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
No Manual
Please go into fixya.com and give me a rating,Solution solved ,etc..
Neil
Jul 22, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Washing Machines Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
