Question about A.O. Smith SQ1102 Pool Pump Motor
I am trying to replace the motor on a pool pump. How do you remove the front end or impeller to install a new motor?
  • 1,340 Answers
It may have a left hand thread screw in the front of the impeller turn this screw clockwise to loosen, to loosen the impeler just use a 7/16 or a 9/16 wrench to hold the back of the motor shaft look close you will see a slot in the shaft for the 7/16 wrench just under the centrifugal switch , this will hold the rotor still so you can turn the impeller counter clockwise to remove it
Posted on Oct 11, 2010
How to replace seal on a
remove the motor from the wet end of the pump remove the cover on the impeller then remove the impeller screw it it normally backwards thread then spin off the impeller this has a regular thread split the motor from the backing plate then remove the seals and replace with new ones then reverse process
Jul 13, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
Remove impeller pool pump
look to make sure there is no ***** in the center of the impeller, if so, it loosens to the right. the impeller will come off by turning it to the left (facing the impeller) if you still have trouble with the impeller, search your area for your ''local pool pump motor repair guy'' with free testing.
he should be able to save the impeller and install a new seal for around $20.
remember to prime the pump with water after any repair !
Jan 03, 2014 | A O Smith Motors Pool & Spa
Replace usq1202 pump
It looks like since you have a square flange motor you have either a Tri-Star, a Maxflo II pump or other model by Hayward.. Either way the process is very similar.
Replace the seal, o-rings and gaskets with new ones. Use a teflon based lubricant on all rubber parts, including the seal, but try not to get any on the ceramic (white ring).
  1. Shut power off at the breaker.
  2. Remove the bolts connecting the motor plate to the pump housing.
  3. Back motor assembly out of pump housing making sure that the diffuser and its gasket also come out.
  4. Disconnect the electrical supply.
  5. Remove the diffuser if still covering the impeller, (there may or may not be screws to remove).
  6. Remove impeller ring (if one).
  7. Holding the impeller firmly remove the impeller screw. This is in the center of the impeller and has a REVERSE THREAD, meaning turn screw clockwise to loosen.
  8. Remove the end cap on the opposite end of the motor and use a 9/16" open end wrench to hold the shaft from turning.
  9. Unscrew the impeller CCW.
  10. IMPORTANT -- Note how both parts of the seal are oriented to assure the new one is installed likewise, then pull off the seal and seal plate, and discard old seal parts. Also note which way is UP on the seal plate relative to the motor.
  11. Reassembly to the new motor is basically reversing the steps above.
NOTES:
The impeller ring (if one) is a ring with a lip around one side. This goes over the center of the installed impeller with the lip facing outward, away from the impeller.
Do not over tighten the bolts! You can damage the pump by doing this. Snug plus about a quarter turn is plenty. In the event you have leaking after startup, open the pump back up and check you housing gasket.
Jan 20, 2013 | Smith 2hp Pool Pump Motor A O Electric...
Trying to replace seals for a hayward sump pump and can't remove inpeller
Thank you for posting your question here on Fixya.com.
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. You will also need to check for an impeller screw in the center of the impeller inlet. If a screw is present they are usually left hand thread. Back out the screw first, then proceed to remove the impeller.
To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Once you remove the cover you will see a slot for a screwdriver, a flat for a wrench, a hex hole for a hex key or some combination of these. Lock the shaft and spin off the impeller. Some are so tight you will end up breaking them in the process. Simply replace it and the seal. Be sure the motor shaft is in good enough condition to allow the new seal to work properly. If too much shaft material has rotted away the new seal will leak soon after it is installed; you would need a new motor at that point.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
May 14, 2011 | Hayward 1 Hp Super Pump Inground Swimming...
How do I remove the pb460 booster pump in order to install the new one? Does the water have to be turned off from the pool?
You are trying to remove the pump so you can replace the impeller correct?
To remove the impeller you do not need to remove the whole pump. Turn off the electric first. Then just remove the several bolts and separate the back half from the front. Then disconnect the electrical from the motor and your can pull the motor with the seal plate, and impeller all the way out and work on it. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white and black ceramic surfaces 100% free of any dirt, grease, etc while working with them
Sep 17, 2010 | Polaris Pb460 Polaris Booster Pump...
How to seperate pump from motor
Disconnect all power. Remove the six bolts holding the seal plate to the wet end. Remove the two small allen screws to remove the diffuser. Remove the dust cap from the end of the motor and secure the shaft from moving. If installed, remove the Phillips head screw in the center of the impeller by turning clockwise (left hand threads). You can now remove the impeller by turning counter clockwise, note that you may need an impeller wrench to remove it and a specific tool to hold the shaft while you remove the impeller. Once the impeller is off you can remove the four bolts that hold the motor to the seal plate. This process just needs to be reversed to re-install but you will need a new shaft seal (PS-1000).
Jun 30, 2010 | Pentair 1 hp WhisperFlo InGround Pool Pump...
How do I get old motor off pump to install my new motor?
The front of the wet end must be removed to access the impeller. Then remove the rear electrical covering to expose the rear end of the motor shaft. Look closely at the shaft. It has two flat sides. A 12mm open face wrench will fit onto the shaft. Lock the shaft in place with the wrench and unscrew the impeller. The rear housing behind the impeller pops off to reveal four 9/16 bolts. Remove them and the motor is free. Reverse the process with the new motor.
Apr 22, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
How to get impeller off hayward power flo sp1525
Once you have the housing apart, 6 screws/nuts I believe, make sure you have the power completely shut off at the breaker. Remove the rear housing on the motor to expose the armature (shaft). Depending on the motor, you will need a 7/16" open end wrench to hold the shaft, be careful not to damage any components, you may have to remove the capacitor or switch to access the shaft. Once the shaft is being held, try to remove the impeller by turning counter-clockwise facing the impeller. If it will not move, you may have to use an impeller removal tool. c85eef7.gifMost pool supply places have them. Be sure to install a new shaft seal, its best to replace the seal anytime you mess with the impeller. Having a good shaft seal will save your motor bearings.
This video helps, although its not the same pump..
I hope this helps....
Sep 18, 2009 | Hayward Pool Products Hayward Power Flo LX...
How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
May 01, 2009 | Pool & Spa
Changing motor hayward 1.5 HP
Super pumps are very easy. If it is a northstar it is more difficult. Super pump. You will need 1 motor, 1 pump seal, 1 diffuser gasket, 1 housing gasket. turn off breaker, disconnect wires -noting whether it is 110 or 220 volts- , unscrew four bolts on back of pump housing (shaft side of motor), pull out motor with rear housing and diffuser (sometimes diffuser sticks inside), on wire side of motor hold shaft with wrench (flathead in some cases, but it is harder), unscrew impeller counter clockwise (like normal screw - you will nee a big pair of channel locks or a strap wrench), there are two pieces of the back housing and once the impailer is off you can remove the half that is closest to the end of the shaft to reveal four more screws, unscrew those four screws. screw back part of rear housing onto new motor. Install new pump seal to front part of rear housing and impeller, slide on front part of rear housing and then screw on impeller while holding shaft on wire side with wrench (only hand tight), replace housing gasket, replace diffuser gasket, slide into front housing and screw in four bolts. If electrical was 110 you will need to move the jumper on the wire end..if it was 220 then just hook kup wires...doesnt matter which is which as long as green or bare goes to the ground screw.
Mar 14, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
A.O. Smith SQ1102 Pool Pump Motor Logo
367 people viewed this question
Top A.O. Smith Plumbing Experts
Donni Steen
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
