Repair Tandberg Tape recorder
I have a Tandberg 6000X Tape recorder, about 1970, on which the drive belt has broken. I have another belt, but I don't know how to connect it up. A diagram would be great.
Here is the link for the service manual with a picture of the drivebelt.
http://www.sportsbil.com/tandberg/6000x-servicemanual.PDF
Go to the parent directory to find lots of other info for this and other Tandberg equipment.
Posted on Jan 10, 2010
In terms of "gunk" on tapes, there is much on the web about baking tapes to dry out the hydrophyllic binder, which has weakened and let go of the oxide because it took on moisture from the air. The drying process is easily done with a food dryer. Reactivating the binder temporarily reduces oxide shed and gunking up the heads and tape path, long enough to transfer old recordings to a more stable medium. Most of these problems were with tapes from the 80s. Many original master tapes have been baked before transfer with great sucess. Most of the earlier tapes from 50s through 70s (not not all) didn't suffer from oxide shed. Search for "tape baking" for more info. Good luck.
Posted on Apr 24, 2009
Hi, I have  a 6000x  and gone tru several belts, solution: just go to local O-ring sales outlet and purchase either O-ring right size or 1.5 meter of linear O-ring and superglue the perfectly square cut ends together, believe me it works. The belt runs from under the left reel assembly (you'll se the V groove) to the right hand one and makes a cross over the drive pulley/wheel, the left hand belt goes on the top pulley and then onwards to the RH reel assembly and back tru the lower small pulley ending on the LH reel assembly. It sounds more complicated than it is. Anyway this works for, I tried to use two shorter belts one from each side to the drive pulleys but have not had any good outcomes with this approach. Good luck. ps. anyone have good tips about cleaning gunk of 35 year old r2r tapes, quality of sound pretty good but gunk keeps clogging up the heads.
Posted on Jun 30, 2008
Running recovery searching for a free slot?
The free slot, will be a place where the Library can put a backup tape. It needs to do a cycle, "feeling" every location, to see if, and where tapes are in.
Feb 21, 2015 | Tandberg Data Tandberg StorageLibrary T40...
I have a Tandberg 6000x r to r deck in grat shape except the rubber pinch roller has flat spot in it. I've found someone who can re-work the rubber wheel, but I cant figure out how to remove it from the...
It might not be a type that is meant to be fixed by that method. These type of pinch rollers are often held in place by horseshoe clips. Once that is removed the Roller assembly will often drop out. However to get the worn roller out, might require it being bendered out of shape to remove the wheel.
Jun 02, 2014 | Audio Players & Recorders
I have a Tanberg 6000x. Rarely used, in seemingly mint condition. Only problem is that the two tape reels seem to move in opposing directions. I don't have a clue.
The old Tandberg's are good reel to reel recorders. Unfortunately, that joystick drive mechanism is very complex under the hood. It pushes different levers and such to apply the right combination for whatever mode you select. If you're somewhat mechanically inclined, try sliding the deck out of its case. Move the joystick to see what's being pushed where. That may show you something slipped out or broken. If not, you may have to power it up and watch the difference between play and fast forward. Both should make the takeup spool (right side) rotate CCW. You may be able to see the difference and move or tighten something up. If its not that obvious or you are not so inclined, you may have to search out a person to repair it who knows the Tandberg. They are somewhat unusual beasts (the deck not the techs) so you need someone who knows that joystick mechanism - Tandberg used it a lot but they were about the only one.
Oct 26, 2010 | Audio Players & Recorders
The tape will not eject from Tandberg LTO Ultrium 2, any ideas please?
look closely on the tray,, u'll find a pin hole in it,,, just enter the saftey pin, and it will edject
Mar 23, 2010 | Tandberg Data Tandberg LTO Ultrium 2 Tape...
Where can I buy a Capstan drive belt for a Teac A-4010 tape recorder??
Go to a consumer electronics repair shop, preferably an old mom&pop op and they will have what you need. If not they can order it for you when they do stocking and save you shipping money from any internet company. I used to work at one is how I know. Have a good one
Aug 07, 2009 | Teac Audio Players & Recorders
I have distortion of playing tapes.
Degraded tape, dirty heads (clean with acetone and Q tip but don't get on plastic), dry coupling capacitors.This assumes that the distortion that you refer to is dirty or fuzzy sounding audio.
If a new tape, recorded and played back, sounds ok then your electronics are in good shape. That means your tapes are junk. If cleaning heads takes care of it, well that's pretty obvious. If your capacitors are dried out you will need to bring it in to a repair shop.
Apr 20, 2009 | Audio Players & Recorders
Tandberg LTO HH (LTO-3)
The error is because the driver isn't loaded for the device. Look up how to add the device in symantec help. If windows recognizes it already then usually you can go to devices and add teh device from within symantec.
Jun 03, 2008 | Tandberg Data 200/400GB 420LTO LTO2...
My Tandberg LTO Drive isn't working with Veritas Backup Exec
When you say 'rolled back' did you use a system restore function? Do the backup logs say why they failed?
Sep 12, 2007 | Tandberg Data 420LTO LTO 2 Tape Drive
1,655 people viewed this question
 Grubhead
Grubhead
