Question about Porter Cable C2002 150 Psi 6 Gal Compressor
Brand new, just bought it. Actually had to take it back and exchange; this one is doing the same thing. The gauges to do not go past zero. Would adjust regulator, but still nothing. What is going on?
  • 30 Answers
Is the tank actually filling up with air? Have you checked the drain valve on the bottom of the tank and made sure it is tight. Porter Cable may ship these with the drain valve open because part of their break in procedure is to run the unit for 15 minutes with the drain valve open. This procedure can be found around page 12 of your owners manual. Weather or not the drain valve is open I would run though this break in procedure and see if the gauges start working. If still no luck with the gauges it can be other issues like The gauge supplier sent PC a batch of faulty gauges and because you bought your units back to back they both came off the same run. Before going back to the retailer and risking a 3rd set of bad gauges I would contact a local DeWalt/Porter-Cable Factory Service Center, they can be located at www.dewaltservicenet.com and see if they have a resolution or can ship you new gauges.
Posted on Oct 11, 2010
  • Artlee123 Oct 16, 2010
    Odd, my owners manual does not list the breakin procedure. I found that on-line.
Bought a brand new Bostitch 18 gauge GBT1850K and won't dispense nails
Go straight back to where you bought it or return him to check out if you have not bought the wrong nails for this model.
Warranty is not the way to let it repair if an option to handle so is only by malafide sellers . Always exchange with the receipt within 8 days .
May 12, 2016 | Tools & Hardware - Others
My new zeepad will not turn on
bring it back & exchange it for a another one. tell them it is factory defective. you did say that it was new and that means it is in warrantee and can be returned & exchanged for a new one that does turn on.
if it is not really new ,like only 2 weeks old, then you cant bring it back to the store where you bought it & exchange 4 a new one,
you can still send it to factory service 4 a free repair if it is only 90 days old or 1 year old. You did save your reciept ,right and can find it for free factory service. No reciept,try filing your item in the garbage dumpster.
maybe some one who who has actually owned an android instead of only having glanced in passing , at the tv commericial, while not really paying any attention, can come up with a better solution for you.
Oct 13, 2013 | ZEEPAD Brand 7inch 4gb Android 2.3 Tablet...
My check gauges light is on, oil hands goes over to zero, moves up, light goes off, when it drops back to zero, gauge light comes back on.
Well the warning light is supposed to come on if any of the gauges display a dangerous condition, such as no oil pressure.
You may have a faulty sending unit for the gauge, or a wiring problem, or the engine may actually be loosing oil pressure when the gauge drops.
You could replace the sending unit as a test, or have someone check the oil pressure with a mechanical gauge.
Dec 13, 2012 | 2001 Jeep Grand Cherokee
I purchased the reebok zigs for my son for his birthday after about 2 months they started to wear away on the inside and the pastic piece rubs against my son's ankle giving him blisters. I tried to...
Best thing to do would be to contact Reebok directly. If they are aware of the problem, then they would have a solution for you. Make sure you still have your receipt, they will want it if they can do an exchange.
Sep 14, 2011 | Toys
Brand new camera will not work
Can you return it or exchange it? That would be the best thing to do. I've bought stuff from Hong Kong, but found it doesn't take long before things start going wrong in some cases, depends on the item. There are some serious issues going on with this camera, and it wouldn't be worth the cost of having it repaired. Get your money back, if you can, and return it. Look for a name brand next time, at least you can get parts for them off ebay and the net. Good luck.
Mar 27, 2010 | Cameras
I replaced my oil preesure sensor and my gauge
Your problem may have nothing to do with the sensor but in fact, the pressure relief in the pump may be stuck. Install a mechanical gauge on there temporarily and check the actual pressure. If normal then the gauge wire may be grounded somewhere. If it reads the same as the one on the dash then the relief is stuck (sometimes it can be freed up by draining the oil filter, filling it with marvel oil and re-starting, sometimes takes time though...otherwise you'll need to take care of the pump)
Jan 19, 2010 | 2001 Jeep Grand Cherokee
Ran ok at 70mph but the gauges all went to zero for approx 10 sec
If it happens again, smack the top of the dash above the gauges with your hand. If the gauges come back on then remove the gauges and clean the plug contacts. This usually will restore proper operation. Some people actually put a slight bend in connectors to get a tighter fit...you can do that but don't get radical or it won't go back together.
Nov 19, 2009 | 1999 Jeep Wrangler
Brand new X Box360 but it only works for 5 minutes and then switc
Honestly if its brand new I would just take it back and get it exchanged while its still under warranty since you do not want to do anything to void that.
Apr 30, 2009 | Microsoft Xbox 360 Console
Temp gauge off charts
Both my temp and tach have gotten stuck like all of yours. When either does not zero out after you turn the engine off there is one thing that seem to work every time: 1) put key in ignition, 2) turn the key until you start to feel resistance and then turn it back (turn the key so that the battery is on and stop just before the engine is about to turn over.)
The temp and/or tach will slowly fall a little closer to zeroing out each time you do this.
Generally I have to repeat this half turning of the key a up to a few dozen times before the temp or tach will zero out. From what I have read this is a result of poor wiring that is common with cavaliers of the early 2000s.
Nov 16, 2008 | 2003 Chevrolet Cavalier
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
206 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
