Question about SunBriteTV 4600HD TV
Our brand new sunbrite tv has a large black spot in the picture. It appeared after two days use.
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
To remove a black spot on a old sharp model TV?
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years,
and the price is USD190
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Apr 30, 2014 | Sharp 4500HRS ECO/3K HRS STANDARD 180W...
Sunbrite tv 32 " 2 yrs old. Blue light comes on ,
Hello Joe Harlinski,
Welcome, and thank you for using FixYa!
To answer your question: Your television will have to be checked for bad (cold) soldier joints on the power supply board, as well as bad capacitors and resistors.A local Television Repair Professional should be able to handle this for you. If the board cannot be repaired, it can be replaced for roughly $75.00 to $95.00 plus the labor to install it.
Have a great day!
Nov 10, 2011 | SunBriteTV Televison & Video
Lcd sreen has a black spot in it. can it be repaired or is it best to buy a new one
If the spot doesn't actually appear on your pictures, don't worry about it. If the spot is really large and bothers you, it's probably not something that can be cleaned and a replacement of the screen would be expensive...you would have to decide if it's worth it.
Nov 13, 2010 | HP Photosmart M547 Digital Camera
I have a new diamond series 73' mitsubishi TV. I had it set up on a Tuesday and played it off and on for 5 days after with no problems. On the sixth day (Sunday) when I went to turn the TV on, I noticed...
U buy this tv as a brand new tv not as an open box product?Yes.U have the wright to return this tv and get a replacement tv from that store.If tv was bought as a open box product,call mitsubishi for a warrenty repair.
Oct 25, 2010 | Mitsubishi WD-73927 73" HDTV
Just got a new bulb assembly in today brand-new inserted it made sure everything was seated properly after about 45 minutes a large black spot appeared never had this trouble before put the old assembly...
dcamp77262, you mention that the new lamp worked for 45 minutes and then the dark spot appeared, was this the same with the previous lamp and was the previous lamp the original that came with the projection unit? If you're using a replacement lamp(not original equipp) won't be the first time that they send a lamp that does not match the ome lamp, it also could be (very possible) that you're going to need light engine replacement or repaired.
Jul 30, 2009 | InFocus Televison & Video
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Black squares or rectangles over picture
It's the closed captioning. The reason it doesn't go away when you press the "caption" button is because there are four option for closed captioning: Text 1, Text 2, Text 3, and Text 4. The fifth option, which has no designation, is the "off" option. Using the remote, just click on the "caption button until the option has no designation.
Mine was a large black rectangle in the middle of the picture. It's not like Nina3's problem.
Feb 01, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Whirlpool Oven, Ceran stove top
I want to say that since I posted my original problem with black spots appearing on the Schott Ceran top, I took pictures of the top and attached them to a complaint sent to Maytag. Approximately 3 days later, a Maytag representative phoned and offered a brand new top-basically stating that there is a fault with the tops. They would not pay for the labor to replace the top. My husband downloaded the instructions from Maytag website and installed it himself. These spots actually appear from within the surface and are not the result of a boil over, etc. The spots on my burner grew to the width of the burner. If you search the internet, you will see many others with the same problem with the Schott Ceran tops. I will never buy another!
Nov 20, 2007 | Cooktops
SunBriteTV 4600HD TV Logo
143 people viewed this question
Top SunBriteTV Televison & Video Experts
Electro Med Services...
Are you a SunBriteTV Televison and Video Expert? Answer questions, earn points and help others
