Question about Car Audio & Video
Where the sway bar llink is on my 2002 chevy cavalier
  • 4,350 Answers
The anti sway bar fastens in 4 places, two on the frame and two fasten via links to the moving suspension part.. Look for a fairly thick bar running side to side.
Posted on Oct 10, 2010
How to change rear sway bar bushing chevy 2005 malibu
The sway bar bushings are easily replaceable ....remove the 2 bolts that hold the mount and remove the old/damaged bushing.....slip the new one over the sway bar and replace the bracket....done.
I would replace both while I was under the car....here is a picture for reference....
Feb 12, 2015 | 2005 Chevrolet Chevrolet Malibu LS
Sway bar rubbing on tie rods
Usually suspension lifts utilize longer sway bar links or relocates the sway bar lower to accommodate the change in distance between lower control arms and the frame.
Mar 13, 2014 | 1988 Chevrolet K1500
Bar that should be connected to front driver side wheel, it is broken off .approx.4-6 inches from the wheel, and I need to know for sure what the bar is
2002 Chevy Monte Carlo; connected to wheel (or steering knuckle) is:
-lower control arm, connects from frame to bottom of knuckle
-tie rod end, connects from steering gear to knuckle
-sway bar link, connects from strut to lower control arm
Nov 11, 2013 | 2002 Chevrolet Monte Carlo
I have an issue with my 04. Chevy Cavalier ! We were driving and all of a sudden it pulled to the left! Took the car back home to check things out.... Looks as though the control arm is broke. It seems...
A sway bar issue wouldn't make it suddenly pull anyway.
It sounds like what you're seeing is a failed ball joint. THAT will cause the problem you're having, AND it fits the description of what you're looking at.
Thanks for using Fixya.
Jul 29, 2013 | Cars & Trucks
2002 Chevy Trail Blazer. Loud pop sometimes in rear when turning. Noticed sway bar is loose, bushings worn out . Could that make the pop noise or is problem possibl worse?
sway bar bushing could be problem. I would replace it before trying anything else and yes that will cause it to pop from time to time. In some cases if not replaced in time the bar itself could break
Aug 12, 2012 | 2006 Chevrolet Trailblazer
How much should new fron sway bars cost for my 2003 escape?
You must be asking about the front sway bar links. It would be very unlikely that you would need to replace the sway bar, unless you got in an accident.
I had to replace the sway bar links on my 2002 Escape. They rattled like crazy.
The bars are pretty cheap; about $10 each, from Autozone, for example. But they can be difficult to replace. The upper nut can be tough to get off.
May 15, 2010 | 2003 Ford Escape
2002 chevy cavalier has check engine light on. Got it checked and said vapour lock. How do you fix that? Also, how do you fix a barring? Is it just better to take it on to get fixed
Vapour lock could be a bad gas cap..
reset the code and get a new gas cap,,
I never changed a barring on this car. but get the book for the car $20 at autozone for help with this..
Mar 12, 2010 | 2002 Chevrolet Cavalier Coupe
99 chevy venture front sway bar broke
The sway bar is pretty easy to fix. Here's a video that will show you exactly how to change the one in your Chevy Venture.">
Feb 22, 2010 | 1999 Chevrolet Venture
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
