Question about Fuji FinePix E550 Digital Camera
CLEANED DIRTY BATTERY TERMINALS..NOW SWITCHES ON O/K! TRY TO TAKE PHOTO..JUST CUTS OUT INSTANTLY..SWITCH ON AGAIN O/K..TAKE PHOTO,CUTS OUT..VERY STRANGE..TRIED HIGH POWER BATTERIES...SEEMS TO BE BETTER BUT STILL CUTS OUT..HELP.! GREG.
    Brigadier General:
  • 11,967 Answers
You have an electric circuit problem that requires service. This could be expensive.
Posted on Oct 10, 2010
  • gregholiday Feb 20, 2011
    HI,SINCE FIXED THE CAMERA..TOOK 30 SECONDS.!! WITH A SMALL SCREWDRIVER I SCRAPED THE METAL BATTERY CONTACTS..FRESH METAL..? IT FIRED UP PERFECTLY,AND DOES EVERY TIME,EVEN WITH ORDINARY BATTERIES..THINK SIMPLE..CLEAN BATTERY TERMINALS..IT COST £1 POUND AT A BOOT FAIR..AND HAD A PAIR OF RECHARGABLE BATTERIES INC..SOME YOU WIN SOME YOU LOSE..!!
What can cause my ford escape not to unlock at times
I'm assuming you are using the key fob remote the contact's inside the remote are not staying in contact with the battery if you squeeze the remote in the center then press the button it should work if you replaced the battery recently if not that battery maybe weak and needs to be changed if your using the door switches inside the car while trying to unlock the doors this also could be the switch contacts are dirty and burned and can be cleaned with alcohol and an emery board lightly to remove the burns from oxidation to get them shiny again
Nov 21, 2016 | Ford Escape Cars & Trucks
When trying to start, why do lights go out but no noise?
what you describe indicates a dirty battery terminal or loose terminals or bad ground wire for the battery
Apr 20, 2016 | 2005 Suzuki Boulevard S50
It wont start . I cleaned terminals and now it wont start.
Disconnect the battery for 5 minutes and then reconnect. It _should_ reset the system.
Jan 14, 2016 | Cars & Trucks
Vauxhall vectra dti cuts out no engine lights just intermittent cuts out leave it a second or two and she fires up again !! help
Check for alternator faults--loose wire and fittings. Check for loose /dirty battery terminals
Aug 31, 2013 | Vauxhall Cars & Trucks
I replaced my battery in my 2004 GMC Envoy last week now the car cuts off/stalls whenever I come to a complete stop. It fires right back up once I put it back in park and start it again.
The throttle body needs to be cleaned, When you disconnected the battery, the computer reset to factory defaults and now with a dirty throttle body, it will run poorly at idle. Make sure both the front side and rear side of the throttle body are cleaned thoroughly.
Sep 08, 2011 | 2004 GMC Envoy
I have a John Deere L110 that won't start. Mowed grass then parked it and it wouldnt start. These are all of the things we have done: New spark plug, solinoid, all 3 safety switches, battery terminals...
problem could be: brake pedal is not depressed; PTO is engaged; battery terminals are corroded; battery not charged; blown fuse; or fusible link in starting circuit is blown.These are the Most Common Causes for your Problem. Recheck your voltage of the battery and then check it under a load....Take a Jumper Cable Set and Attach the Positive Lead to the Positive Post of the Battery. Take the Other End and FIRMLY Touch the Large Post of the Soleniod on the Starter Side. If the Starter Turns the Engine, then Check the Voltage from the Ignition Switch to the Soleniod. If the Voltage is Going From the Switch to the Soleniod When the Ignition Switch is in the Start Position, then Replace the Soleniod. If No Current from the Ignition Switch to the Small Post on the Soleniod, then The Ignition Switch is Bad ....Hope this helps
May 07, 2011 | Husqvarna Viking 1
Rpm gauge stops working and altenator stops chargeing
Thanks for choosing FixYa and welcome to the site. Your alternator is part of the charging system. Make sure your battery is good and holding a charge. Make sure you see no fluid leaks on the battery. Make sure the terminals are cleaned and they are tight to the post. Here is how to check your alternator to see if it needs replaced. Start your vehicle and then take the hot side battery terminal off the post. If your vehicle dies instantly, your alternator is bad and will need changed. If it doesn't die instantly, recheck the battery, wires, and terminals. Make sure the alternator wires are correct, tight, and not damaged. If you have any questions, feel free to ask. Thanks for using FixYa and have a good day.
Apr 01, 2011 | Dodge Ram 2500 Cars & Trucks
Car won't start after battery was cleaned.
what do mean the battery was cleaned ? was the fluids inside removed ?
or was the terminals (where the cables connect) cleaned due to some whitish build up ?
If the fluids inside were cleaned you can try (and this will probably not work). remove the battery from the car.
open the battery (the caps where the water goes in). remove the fluid inside (be careful it may be sulfuric acid) then rinse out the battery a couple of times with hot water.
leave battery in sun with caps off to dry out completely.
fill the battery with battery acid.
Put the battery on a trickle battery charger for 24 hours or until charger indicates full charge.
Reinsert into car and connect the terminals.
See if it worked.
If it didnt -> replace the battery
If the terminal were simply cleaned, lossen the terminals with the correct spanner, pour some hot water over the terminals to wash away any residues, then while the terminal are still wet fasten the terminals once again.
Remember that should the fluid inside your battery gets low (should be checked regularly) fill it with battery water (distilled water) only.
Oct 11, 2010 | 1997 Toyota Camry
1995 2.4 Vauxhall Frontera, fitted alarm immobiliser keeps going off and will not reset. Engine does start eventually, but cuts out when alarm goes off again. Help
check ya battery thats normally the cause
good bat 12.4v bad bat anything below 11.8v
With the engine running
good 13.8-14.8v bad anything below 13.0v
if below 13.0v when running the alternator is broken
Hope i help
bakerboy11@hotmail.com
Automobile
May 17, 2010 | 1995 Isuzu Rodeo
Receiver cuts in and out
Sounds like a cold solder to me or maybe an oxidized terminal but could be something more simple.
1- If the unit still has power but no sound - Try and reseat the jumpers on the back of the unit - top middle (adapter unit)
2- If you are tapping near the speaker button it may have dirty terminals and may be cleaned with some electronics cleaner. One way to diagnose this is switch it off and on several times and see if it changes.
3- If tapping on the front panel makes it start working - can you duplicate it going back out by tapping? This may be a cold solder on the ops panel. If you have some soldering skills this may be an easy find and fix. If not you may need to take it to a repair center. By no means operate on the unit with power to it with the cover off!
Mar 25, 2009 | Kenwood Audio Players & Recorders
Fuji FinePix E550 Digital Camera Logo
126 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
