Question about Microwave Ovens
Instruction manual for Sweda juice factory model# JF 2000
Hugin sweda 1800
aLOT OF OLD MICRO WAVES ARE LEFT IN TO CIVIC AMENITY SITES / RECYCLING CENTRES YOU SHOULD GET A PLATE THERE
Aug 08, 2013 | Microwave Ovens
MH1150XMB
It's important that high-current devices like microwaves be on their own dedicated breaker.
I would suspect the 20A fuse and then the oven cavity thermostats, in that order.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components (such as the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
Oct 11, 2012 | Whirlpool GH8155XJ Microwave Oven
I have a Singer Juice Giant II but no instruction manual. Where would I find the instructions?
HELLO.
Way out to the problem.
The best place to get the microwave oven manual guide is to visit the manufacturer website to order for the manual stating the microwave model number and give our house detailed address.
However microwave manual guide can also be purchase at any microwave oven authorized dealer around your local area with the model number for compactibility(easy use).
Thanks.
Sep 19, 2011 | Microwave Ovens
Are all vegetables can be transform into juice?please give me instructions how.
Yes. But the quantity depends on the vegetable's juice contents. Use a juicer to extract the respective juices of vegetables.
May 05, 2011 | Microwave Ovens
I HAVE NATIONAL MICROWAVE/CONVECTION OVEN MODEL NN-C781 JF.IT IS NOT TAKING POWER SUPPLY..LOCAL REPAIR SHOP SAYS MAGNETRON IS NOT WORKING...WHERE AND HOW CAN I PROCURE THIS SPARE PART?
You can try MCM electronics, Digikey or Newark as they have replacement magnetrons. Also, replace the high voltage diode that is associated with that magnetron or you will probably burn up your newly acquired magnetron.
Energies associated with magnetrons can be fatal. Know what you are doing prior to replacement.
Apr 13, 2011 | Panasonic Microwave Ovens
I need a instruction manual for a Deni Factory Automatic Ice Cream Maker. Is there one available?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 19, 2011 | Microwave Ovens
Looking for a power juice manual
Mention the Make/model of set so that we are able to help as many models are available.
Respond
Sep 24, 2010 | Microwave Ovens
I would like to know whether the factory blower orientation for MMV4205AA had changed since 2000. Was it changed from top vent to circulating (into the room)? If it did, when did this change...
Here are the instructions for re-orentation of the blower.
The unit is shipped in the room vent configuration. The blower is re-orented for a wall vent.
http://www.youserguide.com/wiki/Whirlpool_8101P641-60-011
The page numbers for the manual are changed at the top of the document.
For roof vent configuration:
http://www.youserguide.com/wiki/Whirlpool_8101P641-60-012
Wall plate installation is on page 13
Here are the instructions for the wall plate.
http://www.youserguide.com/wiki/Whirlpool_8101P641-60-013
Thanks for choosing FixYa
Kelly
Sep 13, 2010 | Maytag MMV4205 Microwave Oven
I am looking for the manual for milex mean juice machine MMJ001
Did anyone get the manual for the Milex mean juice machine...Ours works but is awkward to take apart.. and we were just looking for manual to see if it was explained.....
Aug 19, 2010 | Microwave Ovens
I want instruction manual in english for NN-K573 JF/NN-K573 MF
hi sir \just i put the time 1mint after20sec tuch the sw stop but m\ovn is not cut of relay sum time but key pad all sws ok
Mar 07, 2009 | Panasonic Microwave Ovens
Microwave Ovens Logo
1,140 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
