Question about Ortho Dial N Spray Hose End Sprayer
My ortho dial n spray will not work properly. All that comes out is water from the hose - it is not mixing with the weed killer.
Use rubber gloves to remove the top from the jar and wash completely to remove any poisons. Turn lid upside down and examine suction tube for breaks and clogging. If tube is broken, discard whole thing and try another brand. There are four phillips head screws readily visible. Remove screws to reveal innards of gadget. The suction tube has a spring on it. If tube is clogged you can now try to get water through it and flush . If it is clogged and does not flush, throw the thing away. My suction tube was ok, but the thing wouldn't work. Now look at the dial, which is loose. Note which side is up and, when you take it off, note the hole with the black o-ring under it.Now look at the dial. You will see a series of holes, starting with a big one and progressing to tiny ones. Suction through these holes makes the thing work and a given setting will not work if its hole is clogged. Do not try to poke something in the holes. That would spoil your calibration. Use an air compressor, if you have one, to blow out each hole from each side. No compressor, try a straw. Reassemble, maybe having a helper hold it together against the spring tension while you put the screws in. Put some water in a cup, attach hose, turn water on and see if water disappears from the cup at each setting. Worked for me.
Posted on Mar 12, 2013
SOURCE: I have a ortho tree & shrub spray-ette hose
sound like the inside suction hose is loose or not fitting correctly. i had a similar problem and wrapped some duct tape around the tube then snugly fit it inside the cap. no outside air suction and it works fine. i've had mine going on 15 years and use it constantly.
Posted on Sep 01, 2009
  • 231 Answers
SOURCE: i need the owners manual for the ortho dial n
From forums.gardenweb.com
"The instructions on Ortho Garden Disease Control (Daconil) give directions for use in the dial and spray. Set dial at 4 Oz. Add 1 TBS Daconil and 7 TBS water for each gallon you want. I am using the dial and spray and don't see as much residue as when I was using a pump spray.
Posted on Jul 03, 2010
kirkx
  • 2019 Answers
SOURCE: using Ortho weed and crabgrass
Here is what they say at their site:
How do I use the Ortho Dial 'N Spray Multi-Use Hose-End Sprayer?
Pour product into jar, and set dial to amount indicated on product label and begin spraying. This sprayer siphons product and mixes while spraying; it does not mix inside the sprayer.
http://www.scotts.com/smg/catalog/productTemplate.jsp?bodyCssClass=scotts+blade+scotts+product+faqhelp+en&tabs=help&navAction=push&bodyId=product_faq_help&proId=prod70022&title=p_product_general_help_title&itemId=cat50094&id=cat50008
Which means it is not determined by Scotts, but by the product you want to disperse with the Dial N Spray.
And here is an exact description of the settings:
{ ... There are 14 settings in all and they range from 1 teaspoon per gallon up to 8 ounces per gallon. You will find the dial at the on the top of the sprayer. ... }
http://www0.epinions.com/review/Dial_N_Spray_Hose_End_Sprayer/content_465229876868
Posted on Aug 19, 2010
  • 65 Answers
SOURCE: I am confused. Your driveway
Hey, sorry for the confusion. Actually Ortho GroundClear can not be used in the Dial N Spray Hose End Sprayer because this sprayer will only dilute up to 8oz per gallon. This dilution rate is not enough for the product to be effective in keeping the area clear of vegetation. Hope this clears it up.
Hilary @ Ortho
Posted on Aug 24, 2011
  • 65 Answers
SOURCE: I need a nozzle for
Sorry to hear about the problems you are having with your Ortho Dial N Spray. Please contact Ortho at 877-465-5160 and we will be happy to help you further.
Hilary @ Ortho
Posted on Aug 29, 2011
Ortho Dial N Spray Hose End Sprayer Logo
732 people viewed this question
Top Ortho Garden Experts
raysaw
Nick Olsen
Are you an Ortho Garden Expert? Answer questions, earn points and help others
