Question about Black & Decker B2300 Bread Machine
My machine counts down time, but the paddles don't rotate, they are free to do so as I took out the pan. when I restart the setting I get a Hor notification on the time area.
    Genius:
  • Black & Decker Master
  • 1,280 Answers
That may mean that your machine is detecting that it is not at the right temp and some machines heat up for a few minutes before the paddles start to turn. Try pushing the start button for the Basic bread program and wait 5 or 10 minutes. The paddles should start to turn.....Let me know if this works thanks!
Posted on Oct 10, 2010
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from breadmachineshelp.com
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
I bought a model 1183X yesterday at the goodwill and the paddle won't turn. control panel lights up and counts down but nothing is happening in the actual cooking area. Any suggestions?
Hi...It could be a few things. 1) take the bread pan out of the machine and go to a kneading cycle. Look at the motor shaft through the lid and see if it's spinning. If not then the belt is loose or has fallen off. 2) Keep the bread pan out of the machine and see if you can spin the paddle freely by hand. It should spin smoothly. If it sticks or does not move then it could be the sealed bearing that the paddle shaft fits into has failed and a new bread pan is needed. 3) Make sure the pan is inserted in the machine correctly. Good luck..Hank
Jan 23, 2011 | Toastmaster Kitchen Appliances - Others
Hi, I had all my ingredients in the pan and was bringing it to the machine to begin making bread. When I noticed the liquid was leaking out from the bottom. I had a mess everywhere. Come to find out the...
Hi, The leaking is from the sealed bearing that the paddle shaft rotates on. It wears out over time. It can not be repaired and you will need a new bread pan. Sorry Hank
Nov 23, 2010 | Breadman TR2200C Ultimate Bread Maker
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
The paddle doesn't seem to have a strong enough "push" behind it
Hello, Either the blade is sticking or the belt is loose. Take the pan out and see if you can spin the paddle freely by hand. The paddle should turn nice and free. If it doesn't then the lubricated bearing the paddle rotates on is sticking. This could be due to wear. Put some warm water in the pan and let it sit. Try a few times...DO NOT put the whole pan in water...just fill it. If that's a no go the lubricated bearing is frozen and the pan needs to be replaced. If everything is fine in the pan, then the belt is loose. Belt, pulleys and motor are located in the base of the machine. Remember to unplug first before working on it.. Hank
May 25, 2010 | Toastmaster TBR15 Bread Maker
I have the Black and Decker All-In-One Deluxe Automatic Breadmaker B1600 Series and it's worked well for years. Today I put the ingredients for a loaf in the bread pan and when it started to mix the paddle...
There is a sealed bearing in the bottom of the bread pan. The paddle sits on the sealed bearing shaft. Over time the bearing begins to fail and the paddle does not turn freely or it may even freeze up. If you are sure everything is installed correctly this may be the problem. See if the paddle moves freely by hand and is not really loose. Sealed bearings can not be replaced. Eventually you will need a new bread pan. Sorry Hank
Apr 21, 2010 | Black & Decker Bread Machine
The axis in the bottom of the pan, which holds the paddle, won't turn. The axis in bottom of the machine does seem to rotate when I try it without the pan. Is there a way to fix the pan?
Try putting warm water in the pan and let it soak. Try it a few times. If you can't turn the paddle by hand, then the sealed bearing that turns the paddle is frozen and can't be repaired. Sorry Hank
Feb 16, 2010 | Oster 5834 ExpressBake Bread Maker
The paddle does not rotate
Hey Alex,
It could be 2 things. Take out the bread pan and see if you can spin the paddle by hand. If you can't then the sealed bearing on the bottom of the pan is frozen or failed. Fill the pan with warm water and soak it. If after a few times you still can't turn it, then it's history. New pan is needed. If it does spin freely then keep the pan out of the machine and run a kneading cycle. Look through the lid window to see if the motor shaft is spinning. If not it's probably the belt fell off or has snapped. Hank
Dec 12, 2009 | Welbilt Kitchen Appliances - Others
Blade in my Kitchen Pro 6725 does not turn
You probably need a new belt. Either that or as a result of adverse temperatures in that cabin the motor is gone.
Unfortunately Regal does not make bread machines any more and that belt is very difficult to find.
Maybe if you can measure it you an find something close.
What a pity...
Hank
Sep 03, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Black & Decker B2300 Bread Machine Logo
127 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Irene Tulloch
Gerry Harvey
Gerry Harvey
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
