I have a Logic LDVR1608 DVD Recorder. It has gone into some sort of standby mode with a blue light but no clock display. I can't access any of the menu's on the dvd remote or through the dvd set itself. It's like it is frozen.I cannot access any of the digital channels through it either. Can anyone help me please? How do I reset this dvd player? Many thanks.
Switch it off then on again its just like a computer should reset it
Posted on Nov 23, 2010
Dvd recorder in standy wont work - blue standby light showing!
The main power supply board has the fault. It might be replaced. It is best to replace as card basis, rather than making 'surgery' to it.
May 30, 2012 | Televison & Video
Dvd recorder
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Hi. Please help, I have a Panasonic DMR-HS2. The unit doesn't work, it goes back to its standby mode (clock on screen),and the disk tray wont open. The unit wont play and always goes back to its standby...
Sounds like a typical communication error between power supply and main microprocessor, resulting in the unit continuously reverting to standby with no other functions accessible. In this case, the power supply has several faulty/leaky components (no shorts or there would be no clock display at all). Always a good idea to target the PSU in these units first, to eliminate any suspects before diving into the microprocessor (which, I might add, is a high-density surface-mounted IC with pins on all 4 sides and it is glued as well as soldered to the main board).
In the PSU, it is possible many electrolytic capacitors have gone funny, bulged, or leaked. Check and replace ALL caps as required; not just a couple, and check the IC regulator (IC1 is usually a problematic device in many DVD recorders). This IC is usually prefixed with STRxxxx (where x represents its type number) and is a 5-pin standard device. This is obtainable as a part. The cost will depend where you get it from.
If you are not tech. savvy, I suggest you submit the unit to an authorised service centre, for a quote, and a second opinion (on the likely causes and/or how many components are involved in the fault as well as economics of the overall repair), then make a decision afterwards, whether it's worth fixing or not. Up to you, but be warned, it could be an expensive exercise either way.
Apr 18, 2011 | Panasonic DMR-E85H DVD Recorder
It does not turn on
Does the unit show a clock display - or a standby light on the front? if not, then the PSU is likely to be the cause, with several faulty components, including electrolytic capacitors. If there is a standby LED, but it won't go further, the unit is in protection mode; again, from the (suspected) power supply.
You can opt to visually inspect the condition of the PSU (assuming the unit is out of warranty, and if so, have a look at the electrolytics - many may have bulged/leaked), or, if it still has a warranty, submit to a service centre for a quote on likely repair/parts costs, although I don't think it would be economical.
It is up to you as to how much further you wish to go with this - but keep in mind the possible expense involved along with availability of parts/boards. These days manufacturers lean toward board replacement rather than individual parts replacement/repair.
Mar 20, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
HOW CAN i CHANGE THE DISPLAY TIME
the clock setting mode is most likely found inside a submenu found under a setup page which will accessed from your remote control. you will need to refer to your user manual for a more detailed explanation
Mar 17, 2010 | Cyberhome DVR 1600 DVD Recorder
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
Setting the clock on the dvd recorder
Follow this sequence on the remote control:
Press FUNCTIONS/To Others/Setup/Others/Clock to access the clock setting mode. There, you will have the choice of Auto or Manual. Take your pick and away you go!
Apr 02, 2009 | Panasonic DMRES15 DVD Recorder
LG DVD Recorder- Clock settings Model RH277H
The clock settings will only be retained if you power down the unit via the On/Off button on the remote or on the unit i.e. put the unit into standby mode. If you switch off mains power the clock settings are lost as there is no backup battery in the unit. Power consumption on standby is negligible.
Dec 28, 2008 | LG RH299 DVD Recorder/VCR
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Setting the clock on a Wharfedale DVDRHD400F
Try scanning for channels. It may well download time and date automatically.
Dec 21, 2007 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
168 people viewed this question
Top Televison & Video Experts
Electro Med Services...
