Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Top Load Washer - clanking noise when spinning
Load clanking noise when spinning.
  • Anonymous Mar 25, 2014
    there is a clanking noise when the washer is dispensing water
No spin cycle or agatator movement , fill cycle and pump cycle works
Posted on Jun 02, 2008
Washer makes loud noise at start of each spin cycle
sounds like ur o erloaded. but did u run a diagnostic test??
Jul 08, 2014 | Maytag MAH2400A Front Load Washer
Whirlpool duet is about one and half years old and starts making a loud metal to metal noise while trying to start after the water had run in. Clank, Clank, Clank Loyd
Hi Loyd.
If the metal noise is like rattling, as first thing check the object trap located behind the trim at the base of the washer. Check also through the basket holes and inside the tub if there is any foreign object stuck that may be causing the noise.
From the description the noise looks more like that of a broken spin basket support, which is a common fault on Duet. This fault will result on a rithmical loud clank that occurrs more or less when the basket is passing through the same position.The basket supports are located at the back side of the basket.To reach the part an almost complete disassembly of the appliance is required. The spin basket and its support is covered by long term warranty (ten years or lifetime).
Call Whirpool at the number listed on the manual, tell them the symptoms and eventually mention that a technician suggested the problem being the basket support, and check conditions for repair. The repair will be probably covered by manufacturer.
Regards.
Ginko.
Dec 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clanking machine
Sizeable repair. Basically the seal and 2 bearings need replacement. Very possibly the spider assembly has broken away from the drum. Quickest way to check is to run machine once bearings and seal have been replaced to see if you are still getting any noise and imballance.
Jun 15, 2010 | Indesit W 123 Front Load Washer
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Samsung washer WF409 is making a clanking noise at spin cycle
CHECK THE TUBS AND MAKE SURE YOU HAVE NOTHING THAT FELL OUT OF A POCKET ALSO CHECK BETWEEN THE BOOT AND TUBS.OTHERWISE CALL FOR SERVICE THATS WHAT WARRENTYS ARE FOR! GOOD LUCK!
Jan 16, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
341 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
