Question about Jenn-Air 24 in. JDB2150AWP Built-in Dishwasher
We have a 6 year old Jenn Air dishwasher model JDB2150AWP We had a cracked door close unit which we replaced but got a short while restoring connections I am wondering if there is an internal circuit breaker, relay or fuse on these machines that we need to check and possibly replace since we cannot get it to run at all. No power or lights at all. I believe all connections are secure and we replaced the door close unit with new parts.
SOURCE: I need a wiring diagram for my Jenn-air dishwasher
I removed the circuit board and reinstalled it.
Now is works fine. Bad connection, I guess.
Posted on Jun 03, 2008
SOURCE: Jenn Air Dishwasher Model JDB1100AWS Light Normal/Extra Rinse are the only two buttons that work.
have you solved youre problem ? i have a dead 11000 series unit no one has any input so much for trying to save a buck.time to switch to paper plates i had a bosh before this i went through 3 contol boards then threw it out i miss the old manual controls
Posted on Jul 14, 2008
SOURCE: JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
Posted on Oct 11, 2008
  • 338 Answers
SOURCE: JDB1100AWS not rinsing
if your filter assembly is clogged you are going to need to clean it. if it is really bad then it should be replaced. the part number is 99003292 and would probable cost about $30. the other thing is start your dishwasher on a rinse cycle and see if you have suds in the bottom do not put additional detergent in while checking this. if you have suds run vinegar in the dishwasher to help get rid of the suds as that can cause the same problem. Let me know if you need additional info
Posted on Jan 11, 2009
  • 258 Answers
SOURCE: door spring on dishwasher broke
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
Posted on Jan 15, 2009
Does the water supply hook up to hot or cold input line?
Cold water in ... the machine will heat it if necessary ...
Nov 16, 2010 | Jenn-Air 24 in. JDB2150AWP Built-in...
How do I get an owners manual for this model JDB 2150AWP
Go to then choose owners center from top page and you can download it by model number.
Oct 13, 2010 | Jenn-Air 24 in. JDB2150AWP Built-in...
Leaves sand like mixture in pots on lower rack
Buy a dishwasher cleaner (which asks you to run the machine hot and empty with the soap inside).
This should clean the machine out.
Sep 15, 2010 | Jenn-Air 24 in. JDB2150AWP Built-in...
Am negotiating a home inspection on a house with WW30430P Jenn Air Wall Ovens; neither of the doors close. Is there a solution?
There are several models of Jenn-Air ovens that had issues with the door closing. The only solution is to replace the door hinges (unless the doors themselves are bad, you can see this if you open the door, the porcelain on the door will be bulged and cracked right where the hinge joins the door). If the doors are bad, the hinges and the interior door panels need to be replaced. Hope this helps!
Dec 16, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
All lights are flashing but he dish washer wont start.. was working fine before I went out of town this last weekend..
It might be that you had a power surge try unplugging the unit for a few minutes or trip the breaker.
good luck,
Oct 12, 2009 | Jenn-Air 24 in. JDB2150AWP Built-in...
Need user manual for jenn air dishwasher - model JDB2150AWP
Go to and type in the model number you provided under the "Manuals" link. Your owner's manual is available in a .pdf format that you can print or download for FREE. I hope this helps you.
Sep 15, 2009 | Dishwashers
Leaking under the motor
-Drain hose connections are lose or drain hose needs to be replaced.
-Hole in the bottom of the dishwasher.
-Water line into the unit is leaking.
Jul 29, 2009 | Jenn-Air 24 in. JDB2150AWP Built-in...
Jenn-air 1250 AWP won't start- lights don't come on
I am going to say it sounds like either bad connections on the controller circuit board, or a failing controller.
I can't find you model on the JennAir site not on SearsPartsDirect, so can't help you much further. If you want to confirm your model number, then I'll look deeper.
Jan 26, 2009 | Jenn-Air 24 in. JDB2150AWP Built-in...
White resido on my dishes
this is most likely soap residue try a different type
Dec 12, 2008 | Jenn-Air 24 in. JDB2150AWP Built-in...
Jenn-Air 24 in. JDB2150AWP Built-in Dishwasher Logo
51 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
